Question about Nokia N76 Smartphone
Replacement N76 Faceplate, Front Cover
How do I take apart the old faceplate and install the new one?
  • 5 more comments
  • Anonymous Apr 14, 2008
    I am having the same problem, anybody with solution or helpful link will be appreciated.
    Thanks
    need help urgantly on this taplzthnx.
  • Anonymous Jun 10, 2008
    How to change the faceplate on nokia n76 phone???
  • Anonymous Aug 05, 2008
    how do apart front cover
  • Anonymous Jan 24, 2009
    i dont understand the solution, can be more specific, what shuld i force appart
  • Anonymous Feb 01, 2009
    yes i have the same problem >>please help us
  • babs2919 Apr 15, 2009
    I'm having trouble replacing the Nokia N76 housing with a new one. Can someone help by giving instructions, please?
This might sounds weird, but it clicks into place. force it gently appart. the black around the small screen comes off first.
Posted on Apr 14, 2008
SOURCE:
How do i relace the battery in a remington R5130. I cannot see how to take it apart. John
The plastic cover faceplate on the front where the on/off switch and LED indicator lights "pops" off. (you will need a sharp pen knife blade to get into the seam and start this process.) Once the faceplate is removed you will see 4 phillips-head screws that hold the two halves of the body together. Taking the body apart will reveal the two rechargeable batteries, but the bad news is that these were not designed to be replaced and are actually bonded (glued) to the control circuit board. This is a good example of engineered obsolescence the manufacturer wants their product to be disposable. I am looking for a razor that has rechargeable batteries that are also replaceable.
Nov 16, 2010 | Remington R5130
Xbox wont turn on
Your console should turn on when the eject button is pressed. Press the eject button on the front of your console.
If the console turns on when you press the eject button but not when you press the power button, the console faceplate might not be attached properly. To make sure that the faceplate is attached correctly, you should remove it and reattach it.
  • Position your console horizontally, as you would position a DVD player.
  • Unplug the power cord and any other cables connected to the back of your console.
  • While holding your console firmly, curl your fingers inside the oval USB door on the front of the console.
  • Push the faceplate away from the console with your thumb until the faceplate comes off.
Note You will need to use some force to remove the faceplate.
Once the faceplate is removed, look at the tabs on the back. If any of the tabs shown in red in the illustration below are broken, order a replacement faceplate by contacting Xbox Support.
If none of the tabs are broken, re-attach your faceplate by pressing it firmly until it clicks into place.Try to turn on your console again. If removing and reattaching the faceplate did not solve the problem contact the xbox support.
Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
Accidently removed the tiny screws behind faceplate
It could just be a plastic clip that broke.Most of the car stereo's ive taken apart only have a thin ribbon of wires that run into the contacts that your face plate connects to.If you actually took screws out of the faceplate then id put them back in and put it back into your stereo and see if it illuminates properly,if it does not then id search on E-BAY or contact pioneer and buy a replacement but most the time it would be cheaper to just buy new stereo.You might want to be more specific with the area you took screws out of,the way im reading it sounds like you unscrewed the screws in the face dock, not the faceplate.Hope this helps.
Dec 18, 2008 | Pioneer DEH-P3700MP CD Player
Display issues with Aiwa CDC X207
I had the same problem. There are two small light bulbs that illuminate the digital display, and they are burned out.
You can easily replace them. The Aiwa part number for them is 8Z-KT1-641-010. The bulb is made by Sony, and the Sony part number is U0087654U.
I purchased them from Union Electronic Distributors:
https://www.ued.net/ued/addItems.do?itemCode=SNYU0087654U
Note that the product is not an item they keep in stock, so it may take 1-2 weeks or more before you receive them. Be patient.
Here are the steps to replace the bulbs. You will need a small (#1) Phillips screwdriver and a soldering iron (low heat). A very small flat blade screwdriver (1/8") will also be helpful.
1) Remove the faceplate from the radio and bring it to a well-lit work table.
2) Remove the four Phillips screws on the back on the faceplate.
3) Carefully separate the back half of the faceplate cover from the front half. There are three locking tabs along the top, and three locking tabs along the bottom. I used the small flat blade screwdriver to separate the two halves.
4) Once the back half of the faceplate has been removed, re-install two of the Phillips screws to hold the circuit board in place (one screw on each end). You don't need to screw them down tightly; just screw them in until you begin to feel them stop. These screws will keep the circuit board from separating from the front faceplate and causing the buttons to fall out!
5) Locate the two bulbs. They are labeled PL 901 and PL 902 (may also be labeled PL 1 and PL 2). Carefully unsolder the bulbs and remove them from the circuit board. You may want to do one at a time.
6) Each bulb has a colored cover to change the color of the light (I jokingly refer to them as 'bulb condoms'). Remove the covers and carefully slide them in place on the new bulbs. You may want to slightly dampen the bulbs to aid in sliding the covers on. Be sure to slide them all the way down.
7) Solder the new bulbs in place. They are not polarity sensitive.
8) Trim off the excess wires.
9) If you installed the two screws in Step 4, remove them.
10) Carefully re-attach the rear faceplate cover to the front faceplate cover, making sure that all six locking tabs snap in place.
11) Put the four Phillips screws in the rear faceplate and carefully tighten them.
That's it! Now, put the faceplate back on the radio, turn it on, and enjoy your lighted display!
Hope this helps.
Ron
Dec 13, 2008 | Aiwa CDC-X204 CD Player
Faceplate
You can't take the faceplate off you have to buy a snap on cover. This makes the phone thicker but if you want a different look that is what you have to do. You can also buy phone stickers and decorate the front and back.
Nov 22, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Need to replace faceplate for nokia 5300
Start by removing battery. Then remove the camera plastic panel. After that you will need to loosen the screws holding the faceplate in on the top. You will require a special tool for this but it can be purchased from most places that sell DIY faceplate kits.After careful prying the faceplate should come loose. Keep in mind that the screen over the LCD screen is taped on and will need to be removed separately.
Oct 24, 2008 | Cell Phones
Motorola RAZR V3 faceplate lens cracked
This is very simple to fix. I have replaced 2 of them already. You can buy the new glass for I believe $6.99 or around that delivered from someone selling them on eBay. Then just pull out the old glass etc. Then the new piece has a little trim of double sided tape on it to fit into the exact same spot.
Jul 30, 2008 | Motorola Mobility RAZR V3
W580i faceplate/housing installation
i don't know but sony ericssons pretty much **** because mine is 3 months old and the faceplate broke off and i haven't even dropped it. take some advice, don't buy sony ericsson phones anymore
Apr 21, 2008 | AT&T Sony Ericsson W580i Cell Phone -...
KYOCERA SLIDER REMIX FACEPLATE INSTALLATION
I had the same problem and I was lookin on a forum/blog on how to do this,but not many helped.I'm about to attempt to change my faceplate and I noticed when you take the battery cover off,there are 4 screws under the cover,and one near the antenna.You probably have to take apart the back part of the phone to get to the screws that are attatched to the sliding part of the phone.Its probably a little risky and tricky,but Im guessing thats how you get to the 2 hidden screws.
Nov 20, 2007 | Cell Phones
Removing the faceplate
Hi, I can help you with this. Are you trying to remove the cd-rom drive bay plate or the front panel of the tower?
Sep 16, 2007 | Compaq Presario 5000 PC Desktop
Nokia N76 Smartphone Logo
1,389 people viewed this question
Top Nokia Computers & Internet Experts
Anthony Ward
Anthony Ward
k24674
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
