Question about Frigidaire FRS23KF7AW Side by Side Refrigerator
I have water leaking constantly around the water filter. I have changed filters and still have the leak.
    Problem Solver:
  • 19 Answers
When you change out the filters are you keeping the same fittings? It might be those..or some faulty tubing perhaps?
Posted on Aug 28, 2010
What else can cause this leak
there is a plunger inside them takes o rings too
May 02, 2015 | Refrigerators
What could be cause of oil leaks around filter, all of the expected things to check have been done. New filter, checked to make sure no double gasket etc. and still leaking. Could it be comign from an
If at filter it could be only what comes out (oil drip) when changing oil filter. If filter is good then use oil filter tighter tool to tighten the filter snugger. Make sure its not the oil bolt that is leaking, which could leave that pesky oil spots. Tighten it or replace oil bolt with new one.
May 06, 2014 | 2012 Kia Optima LX Sedan 2.4L 4-cyl....
Water dispenser leaks when getting water . This is Frigidare refrigerator , is it the valve on back ?
Hello Marie Baxter: If you suspect the water dispenser is leaking, make sure it is the hoses coming from the filter and not the actual filter.
Sometimes the clamps on the hoses for fridge water filters can come loose or the hose itself could crack; in which case the hose would need replacing (or tightening the clamp), and not the filter.
If you clearly find the filter is leaking, the best thing to do is make sure it is installed properly.
If it is securely in place, then you may just have a defective filter and changing it will solve the leaking.
You will need to remove the filter, which is typically located in the back of the refrigerator and inspect it to see what condition it is in.
•For instance, if it is black or looks dirty, you probably will want to replace it.
•Moreover, when there is a leak or a clog, you will notice a dramatic decrease in the output of the water dispenser tab, which is another sign there may be a leak in the water filter. If you know the water filter in your refrigerator is leaking, then you can take the water filter out and see if it has anything loose on it, but typically if it is leaking, it probably is best to replace the water filters for refrigerators.
•This is especially true if you use the filtered water from the refrigerator as your main home water filter systems.
•Moreover, if it has been awhile since you changed the filter; it can become clogged over time, which can cause it to leak.
When you are faced with having a leaking filter refrigerator water unit, it helps to think through the pros and cons of fixing the leak vs. replacing the refrigerator water filter.
Apr 19, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Gxrlqr filter leaks
MAKE SURE THAT WHEN YOU REPLACE THE FILTER IT IS IN THE SAME ORDER AS THE ONE YOU REMOVED OR THAT IT IS THE SAME MODEL TYPE REPLACEMENT , I WOULD TRY TO TURN IT AROUND FIRST , A THIN WRAP OF "WHITE PLUMBERS TAPE" , AROUND THE SCREW TOP INNER SEAL MAY CORRECT THE LEAK , ABOUT THE FILTER , WELL , IT MAY JUST BE SIMPLY IN THE REVERSE ORDER , TRY TO FILP THAT OVER , AND WHEN YOU RESEAL THE CAP ON THE FILTER MAKE SURE THAT THE SEAL IS ON PROPERLY , APPLY PLUMBERS TAPE ONCE AROUND , AND *"BEFORE YOU TIGHTEN IT" , GENTLY , REVERSE THE CAP BACKWARDS , SLOWLY , UNTIL YOU FEEL IT "SEAT " PROPERLY , "THEN" YOU MAY TRY TO RE-TIGHTEN IT . THIS SHOULD REMEDY YOUR LEAK , IF IT CONTINUES MAKE SURE THEN THAT YOU HAVE THE CORRECT REPLACEMENT FILTER MODEL FOR YOUR PARTICULAR ITEM . HOPE THIS HELPS YOU . NOW GO FIX IT ! GOOD LUCK .
Aug 19, 2012 | General Electric GE SmartWater Household...
Leak at one of the fittings on my Culligan RO system
Too much pressure in holding tank will not cause leaks in the RO unit. All too much pressure in tank will do is cause low or no product water in RO tank. Older Culligan RO systems (H8, H83, H5) had fittings that used metal locking washers and these can cut the RO line after the RO has been moved around while changing filters. Newer styles (AC30, Water Tower) use quick connect fittings and the RO line may work loose after filter changes and system being moved around under sink.
Turn the incoming water off to RO, turn the water off on RO tank, open the RO faucet to relieve pressure and pull the line off feeding the RO tank, inspect (you may want to cut off a small portion of the line at the filter) check the o-ring and re-install.
RJ
Aug 01, 2010 | Culligan Under Sink Water Filter
Water leaking from around filter housing
There is a seal around the filter housing. If it is leaking around the filter housing than you need to replace the filter which will come with a new seal.
May 26, 2010 | Frigidaire Side by Side 26.0 Cubic Foot...
Leaking water
IF YOU CHANGED THE FILTER AND GOT WATER OUT THE DISPENSOR AND HAD A RUSH OF AIR COME OUT OF THE LINE. YOU MAY HAVE GOT WATER UNDER THE DRIP TRAY. WATER WILL THEN COME AROUND AND APPEAR THAT THE DISPENSOR IS LEAKING. OR YOU MAY HAVE NOT PURGED ALL OF THE AIR. LET ME KNOW.
Apr 25, 2010 | Frigidaire PHSC39EESS Stainless Steel Side...
Water Filter leaking after changing filter
There's probably some particles that got trapped in the filter purge valve ( the red button) preventing it from closing all the way.
You may be able to clean the valve while the filter top is still in place. Try using a small brush. A toothbrush may work if you cut off the handle. Hold the button down while you clean the inside of the valve. Then take a
spray bottle and put the sprayer tip on stream. Flush the valve from the inside.
If that did not do it, next step is to remove the top from the water lines, and flush the valve out.
Jul 19, 2009 | Culligan Under Sink Water Filter
Water filter compartment leaking
If you have already replaced the filter and you can see the housing is still leaking, You have to replace the housing and water tank as an assembly (12956202). Make sure you verify it's the filter housing leaking, and not a fitting at the water valve which is right behind the plastic cover around and below the filter housing.
Apr 28, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
A/c water leak
If the line and pan keep filling with water the line has to be pluged futher down the line
Nov 14, 2008 | Heating & Cooling
Frigidaire FRS23KF7AW Side by Side Refrigerator Logo
83 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
