Question about Samsung SyncMaster 913N 19" LCD Monitor
Samsung SyncMaster 931B
Out of the blue, when I turn on my system I now get the message box "Not Optimum Mode. Recommended Mode 1280x1024 60Hz". I cannot get beyond this...nothing else will display. Until now it's been working fine.
I'm running Win2k. Is my driver corrupted? I can't make any adjustments because I don't get a screen with which to do this.
  • Anonymous Jun 11, 2008
    I have exactly the same problem with my 713N
    SyncMaster only i can't get the pc to boot in safe mode no matter how many times i press F8 (yes i have checked the function key is on).
    Is there any other way?
  • Anonymous May 26, 2009
    i have the same problem. I tried everything i set on my resolution to 1280x1024 60 hz but it not turning on, its going so bad... i must of the system for 1 2 hour to on my monitor in ... bad resolution 16 bit 600 x 800 60 hz :(
Hi, here in Youtube is have you can repair resistance is 47 Ohm or 50 Ohm. Work fine.
http://www.youtube.com/watch?v=kwU3wOV2pO0&feature=response_watch
B.r.
Robert.
Posted on Mar 15, 2010
    New Friend:
  • 4 Answers
I tried both suggestions above and neither worked. 1) Hitting the monitor buttons as stated only got me a "digital" message and then the monitor went black as usual. Never got to any menu options. 2) Going into Safe Mode and changing the monitor settings or downloading/installing the correct driver didn't stick once you went back to the normal startup.
I didn't have another monitor handy to swap out so I had to be a little more creative. The only solution that worked for me is re-booting (F8 during startup) into the mode "Enable VGA Mode". This allowed me to go into the normal desktop with a screen resolution of 800x600. I went online, found the driver, downloaded it to the desktop. Deleted the video driver (Device Manager), installed the downloaded version, rebooted and....no problems.
I have Windows XP. Hope I've helped someone today. :)
Posted on Jan 29, 2010
Press the 'Source' button on the bottom edge of the monitor. Then press the 'Menu' button to make the "Not Optimum Mode" message go away temporarily. Then configure the monitor refresh rate to 60 Hz, and apply. (If the message comes back on before you get the refresh rate set to 60 Hz, just repeat the Source/Menu again.) Once set to 60 Hz, the messge should not come back, even if you don't use the 'recommended' screen resolution.
Posted on Jun 15, 2008
    Scholar:
  • 42 Answers
Sounds like you need to temporarily use another monitor to reconfigure your display settings to 1280x1024 at 60hz. What's happened is somehow your computer was set to an incorrect screen resolution or refresh rate and the monitor is telling you that it's not going to display anything until you correct it. The problem is that you can't see your computer to fix the display settings.
You should be able to boot into safe mode in windows XP, that will allow you to use your computer (keep hitting F8 on startup), but you'll need to change your display settings on the normal boot to get your monitor working again, which the best way to do that is to temporarily use another monitor.
Posted on Mar 27, 2008
SOURCE:
SAMSUNG SYNCMASTER 226BW WHEN TURNING ON MONITOR, IT SHOWS BLACK AND WHITE LINES THEN IT SHOWES A BOX THAT SAYS "NOT OPTIMUM MODE, RECOMMENDED MODE 1680 x1050 60HZ " AND IT IS STUCK ON THIS...
hi dear
start your computer on safe mode and go to the display property change to as per mentioned rresolution on your screen.
best of luck
regards
raj
Sep 06, 2011 | Samsung Computers & Internet
Not optimum mode recommended mode 1280x1024 60hz syncmaster 712 n pop up occasionly I have to shut down computer
Your video card and computer memory may not be sufficient to run in the recommended "optimum performance mode" that Samsung and Windows both suggest. Please try setting your display setting at a lower resolution such as 1080 x 760 which is still quite excellent. Otherwise you may need to buy a better video card or increase system memory to run the higher mode graphics.
Good Luck!
Jan 11, 2011 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Samsung syncmaster713bm not optimum mode
try to adjust resolution you monitor may not support higher resolution change it in the display properties
Mar 13, 2010 | Computers & Internet
Geen beeld opmerking :not optimum mode
comes on and screen says optimized mode 1280x1024 60hz i put it on and get no video
Jan 23, 2010 | Samsung SyncMaster 910T 19" LCD Monitor
How do I change the setting on my Syncmaster monitor if I can't see anything but the message box..."Not Optimum Mode recommended mode 1280x1024 60 hz?
You could try pressing the auto adjust button (simply says 'Auto'), and see if that changes anything...don't know if this will work, but it is a start.
Sep 29, 2009 | Samsung SyncMaster 913N 19" LCD Monitor
Floating box non optimum mode recommended mode
You need to adjust the Display screen resolution.
  1. Control Pannel
  2. Display
  3. Settings
  4. Screen Resolution
Sep 22, 2009 | Samsung Computers & Internet
When i try to play maple story my screen says not optimum mode recommended mode: 1920 x 1080 and the message keeps reappearing
Your source may not be compatple with the tv.
Some gaming systems are not made for use on older gaming systems.
Jul 08, 2009 | Samsung SyncMaster 32 in. HD-Ready LCD...
SYNCMASTER BM SREEN WILL NOT ACTIVATE JUST A FLOATING SQUARE BOX SAYING NOT OPTIMUM MODE RECOMMENDED MODE+ 1280x1024 60hz analog
I tried the following options and neither worked. 1) Hitting the monitor buttons as stated only got me a "digital" message and then the monitor went black as usual. Never got to any menu options. 2) Going into Safe Mode and changing the monitor settings or downloading/installing the correct driver didn't stick once you went back to the normal startup.
I have Windows XP. Hope that helps. :)
Jun 06, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Samsung Syncmaster 710n monitor - screen goes black for no reason. All cords connected properly. Computer works with other monitors. Switch on front of computer is on - green light on. Get floating...
in safe mode adjust the resolution lower than 1280x1024
then restart and then install the driver again the driver is crrupted than install the right driver problem could be solved
May 16, 2008 | Computers & Internet
Samsung syncmaster 711p power issue
Its a general fault however all these units are under a 3 year warrantee the dates printed on the back, just call 08706010309 speak to a service engineer and they will arrange a swap out within 5 working days, no need to a receipt as they can tell the units age from the serial. the replacement will be under the same 3 years cover in my case it was for another 6 months
Nov 24, 2007 | Samsung SyncMaster 931B 19" LCD Monitor
Samsung SyncMaster 913N 19" LCD Monitor Logo
2,063 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
