Question about Palm Treo 750 Smartphone
Synching causses clock to change on my Palm Treo 750
When I synch my Treo 750 the time changes. e.g. the Outlook Calendar appointment time is 10:00 am but when I do my synch it puts the time in as 9:00 am.
  • BrendaGammon Apr 02, 2008
    My time keeps changing on appointments when I sync. Help!
  • Palm Master
  • 13,434 Answers
Check your timezone settings in your pc and in your palm.
other is wrong and causeing this error.
Posted on Apr 21, 2008
SOURCE:
Palm Treo synchronize calendar daylight savings time
You need to go to your phone carrier support page, or to Palm.com and download the daylight savings time update.  You SHOULD keep network time checked unless you don't want to pull the proper time from your carrier, such as when you are out of town.
Mar 24, 2009 | Palm Treo 700w Smartphone
Appointments synching in wrong time zone
Is the incorrect time on the computer you are syncing to then?
Dec 21, 2007 | Palm Treo 755p Smartphone
Calendar not synching properly
hi
often there are events with a regular cycle
the outlook just repeats its every week, month or year
if you dont define the 'end' period it just keep creating them
set the period to sync to 6-12 months and try again
D
Oct 14, 2007 | Palm Treo 750 Smartphone
Outlook not synching
This is how I got it working. Don't use wireless sync software, someting is definitely buggy with it. Here is what I did to resolve sync errors: 1. Perform a hard reset on the Palm 2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old. 3. Connect the Treo to your computer. 4. Right click the Hotsync icon in the taskbar and click Custom. Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld. 5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now
Sep 12, 2005 | Palm Tungsten E2 Handheld
Time difference
Try to reset your time in your phone and try synching
Sep 11, 2005 | Palm M100
Problem syncing with two computers
The HotSync Manager was not designed to work this way. While it may seem like a good idea to do what you are doing, I would never consider doing it. HotSync was designed to be a one-to-one relationship between a set of data on your PC and a set on your handheld. You are giving contrary messages to each PC by using it this way. If you synch to an exchange server (via your Outlook account) you can get away with doing this because PocketMirror or the palmOne Outlook conduits and other conduits have settings you can make to notify HotSync that you are 'two-timing' :-). However if you synch to Outlook in work and then to Palm Desktop at home (I suspect this is your scenario), I disrecommend this. I recommend setting the Home PC to be a slave. That is, I set the conduits at home to be handheld overwrites desktop for the four personal information conduits - Calendar, Contacts, To Dos and Memos. Then when I am at home if I want to change some data, I add it to the handheld not on the PC. That way you have a kosher set of data that is up to date on the handheld and on your work PC. When you synch to the home PC, this data is cloned to the home PC from the handheld. You can continue as you are but you will always have some uncertainty on your data integrity. Losing precious contacts or not showing up for a key appointment is a bad deal.
Sep 11, 2005 | Palm Treo 650 Handheld
When synching new Outlook calendar items, a "note" is added to the T5 calendar item
I have the same problem. T5 Win XP Home HP Pavilion Desktop Outlook 2003. It seems to only attach the blank notes to recurring appointments. Delete them all (which is annoying) and they come back after a HotSync
Sep 11, 2005 | Palm Tungsten T5 - Multilingual Handheld
Why doesn't my conduit save my synchronization preferences?
you should set these conduits to default. when you change these conduits to do nothing you notice a checkbox on the right potion of the window labeled 'Set as default' tick on that and click on ok.
Unresolved Items when synching
Try the following.... Open Active sync on your PC. Double Click on Calendar. Change the settings such that it syncs only 0 past and 0 future appointments. SYNC (this will clear all calendar items on the IPAQ) Now go back in to those Calendar settings, and set it back to the default which is 2 past weeks and All Future appointments. SYNC (this will now reload all appointments into your Ipaq)
Sep 08, 2005 | HP iPAQ H2215 Pocket PC
My Outlook Calendar is not synching with the Datebook on my Tungsten C, why?
Go into your desktop software and make sure your outlook is programmed to transfer back and forth.
Sep 07, 2005 | Mapopolis GPS for Palm Tungsten T, C &...
Palm Treo 750 Smartphone Logo
91 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
