Question about Iomega (33215) 250 GB Hard Drive
The drive won't load it's making a clicking sound but doing nothing
  • sandy_shull May 10, 2010
    Is there any way to retrieve the data off this drive? It is bad. I took it to Best Buy and they checked it and said it's dead. But surely there is a way to retrieve data......isn't there?
  • 977 Answers
Hi Sandy!
How are you?
To be honest, I must say that the clicking (or ticking) sound is not a good sign... :/
It usually means that the drive is practically dying - or dead already .
With that said, make sure the power adapter is connected properly to the drive as well as the USB cable.
Also, try using a different USB port on your computer, preferably a rear port (rather than the port at the front - on a desktop computer); Try using another USB cable as well.
If still unsuccessful, your last resort, with no great chances, is to disassemble the hard drive itself from the enclosure case and connect it directly to your computer...
If none had worked for you, I'm afraid you'll have to bid your drive farewell.
GOOD LUCK,
Pelu.
Posted on May 10, 2010
  • Ran Kedar
    Ran Kedar May 10, 2010
    I've just read your last comment...
    As I've said, you can try disassemble the device, take off the HD and connect it to your computer, using a SATA data cable and power.
    If you manage to do so, but fail to get the HD working (at all), your only chance is to take it to a special store/lab which specialize in data recovery. I don't know how much it costs abroad, but I live in Israel and this procedure is quite expensive here (starting with about $150US for a recovery job, may get up to $500US - depends on the HD's condition)!
    Good luck again... Crossing my fingers for you!
    Pelu.
    President:
  • 1,561 Answers
Put your hard drive back into your system, listen to the sound after you have put it back.
If its spinning sound you heard, after you have put it back, it means the hard drive is still good, all you need do is to change the case.
But if after you put it back, the sound you get is a cracking sound or the kind of clicking sound your hard drive is making, it means the hard drive is bad and will need to be replaced.
Take care.
Posted on May 08, 2010
  • Sulaimon Jimoh Olayemi May 11, 2010
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    I told you initially that the hard
    drive is bad already,
    Their is no way you can retrieve data off the hard drive because one, the hard
    drive is not booting and recognize in your system , so you cannot
    access it.
    Secondly, since the hard drive is bad, all the data stored on it are corrupt
    and gone and can not be retrieved.
    This is the excess of backing up files from hard drive when they are still in
    use, because of unpredicted incident like this.
    Am so sorry to say this,Sorry, you cannot retrieve the data off the bad hard drive anymore.
    Take care.
    I told you initially that the hard drive is already bad.
    Their is no way you can retrieve data off the hard drive because one, the hard drive is not booting and recognize by your system, so you cannot access the hard drive since it is not booting or recognize.
    Secondly, since the hard drive is bad, all the data stored on it are corrupt and wiped off, and cannot be retrieve anymore.
    This is the excess of backing up data from hard drive when they are still in use because of unpredicted incident like this.
    Am so sorry to tell you this, you cannot retrieve the data from the bad hard drive anymore, they are gone.
    Take care.
Won't drain and won't spin ,makes a clicking sound
sound as though the drain pump has something hitting the impeller making the clicking noise,and the filter basket next to the pump is blocked by debris and not letting it drain
Sep 01, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
Just finished driving car, tried to start it back up and nothing happens. Radio works fine, lights come up but car won't start.
if starter is not engaging or clicks then have battery load tested. if battery checks good then test the voltage draw on the starter,may be dragging when it gets hot.
Jun 03, 2012 | 2002 Kia Spectra
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have a gateway 400 VTX that powers on to the Bios screen then goes to another screen that says operating system not found. I have tried to load the os cd and it looks like its loadind and says windows is...
Sounds like u need to go into CMOS (System Setup) upon boot & make sure that the HARD DRIVE is the FIRST item in the BOOT ORDER and NOT your CD DRIVE. Also, make sure your Hard Drive shows up in the CMOS. If it does, then note what it says about the hard drive as it boots... If it is a bad hard drive, then nothing will install to it unless it is fixed or replaced.
Sep 22, 2010 | Gateway 400VTX-3501335 Notebook
Unit comes on and it takes the disk ok but then thats it
Make sure the drive to the Wii is upside down so its facing the ground and shake the Wii cause there may be loose debris in the drive.
If nothing comes out then the drive is bad. If debris comes out then try to load a game and if it doesn't load then the drive is still bad.
Nov 28, 2009 | Nintendo Wii Console
Hard drive makes a clicking sound and does not connect to my Macbook Pro. When i unplug the USB or firewire cord from the computer and turn on the drive, it doesn't make the clicking sound
if the harddisk is making clicking sound,, then there may be an failure of motor inside it,,, ,, nothing but giving your HD for replacement by manufacturer
Sep 28, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Iomega (33215) 250 GB Hard Drive Logo
149 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
