Question about Dell Latitude D800 Notebook
Have a dell latitude d800. Battery died so replaced with new one, ran fine for a few months, now it won't run from battery. Battery shows full charge from itself and from bios, so it is charging and the system is reading voltage form it. But when trying to run from battery only the power light comes on for just a second then goes out, seems like it is going to start but is maybe stuck getting power from jack and not switching to battery? If I start it from the power supply then disconnect the cable it dies right away. All BIOS settings, date/time etc are not lost.
  • 52 Answers
Update bios-if same issue occurs-check for another known good battery (maybe a friend may have one) try this battery and if same issue is occuring then its your motherboard....now if a kown good battery is fine on the system or one is not available then we have to beleive there is a issue with the battery...alot of dell system's in which the battery gets replaced whith in the first year..chances are you will always have this issue with the system....the board is running at a high speed which is eventually killing the battery
Posted on May 08, 2010
4 Suggested Answers
  • 3940 Answers
SOURCE: cpu upgrade latitude d800
what do the Lock Lights indicate (Flashing , ON, ON perchance) it appears that the CPU is either not compatible or bad. Have you tried the original porcessor?
Posted on Jan 29, 2009
  • 2692 Answers
SOURCE: bios password dell d800
Remove BIOS battery. Short BIOS jumper or leave the battery out for a long time(Over night,maybe) This should default the BIOS to having no pass word present.  If that doesn't work then evidently Dell has one within the BIOS . Just ask them.
Posted on Feb 17, 2009
sim4182
  • 393 Answers
SOURCE: Unable to remember my BIOS
4havwvxd try this password .. thanks
Posted on Sep 18, 2010
I need to unlock a bois pass word for dell latitude D800
The best way to unloc a BIOS password is to reset by removing the CMOS battery and while the mains is removed press the power button a few times and leave for about 30 seconds. Refit the battery and power up. Password should be removed.
Apr 12, 2013 | Dell Latitude D800 Notebook
Hi my Latitutude D800 has a Pentium M 1.7 GHz processor but it slows down and runs at 600 MHz. Please Help PS. Am using windows 7
whenever it use on battery power it shows it minimum speed, also it will shows full speed when the processor is processing something.
May 12, 2012 | Dell Latitude D800, PP02X Series Laptop...
Hi! my dell d800 wont turn on. I have take then battery out and such and then put it back in but it still wont work. I have put the charger into the computer and the computer says its not charging the...
the battery is damaged..replace the battery with a new one or you will have to run your laptop straight from a eletric power source with the battery removed.
May 02, 2010 | Dell Latitude D800 Notebook
Dell Latitude D800 Wont Power Up
Check the status of the battery directly from the battery. Turn the laptop over and on the batter is an battery indicator button and lights to tell you if it's charged. If it is charged then you have an problem internally. Wiggle the tip of the power cord at the laptop connection to see if it is loose, if it is then you have an loose connection on the motherboard which can be fixed by an experienced tech that can solder or the motherboard will need to be replaced.
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Nov 12, 2009 | Dell Latitude D800 Notebook
Dell laptop battery has 3 lights flashing when hit battery tester
You can't get the modern batteries to come back to life. Time to get a new one.
A suggestion: When using a laptop battery, run it on battery and discharge it until it shows about 2 to 3% charge left at least once a month. Do not keep charging it without letting it run down periodically. Most important--do not run always plugged in to line current.
Sep 09, 2009 | Dell Latitude D810 PC Notebook
Cant run on battery it dies after 5 mins but battery power says i have 99 percent battery and the ac adapter only charges for 5 mins
The Cell on you battery might be dead. if its brand new you need to replace it, might still have warranty.
if not you have to buy a new one in order to run it in battery mode, how ever you can still use it without battery and plug directly at an outlet.
Apr 03, 2009 | Dell Latitude D800 Notebook
My Dell Latitude D610 Battery Stopped Working
The battery light flashing RED/AMber is an indication of a failed battery.
Portable batteries have a life expectancy of 300 to 500 recharge/discharge cycles. (roughly 18 months under normal use) After that, the charge life starts to drop off and eventually it will not hold a charge. Because of this, the battery is considered a consumable item and is only warranted for one year from the manufacturer.
Since all the systems listed in the post are D610's (4 to 5 years old) it is not surprising that the batteries are failing.
Dropped Puck, if you replace the battery and a new battery doesn't charge/run the system, then the charging circuit on the MB is failed.
Feb 22, 2009 | Dell Latitude D610 Notebook
I have a dell D800 it won't power on at all the battery show full
Try removing the battery and plugging it into the wall. then turn it on, if it turns on your battery is bad or connected improperly.
Dec 11, 2008 | Dell Latitude D800 Notebook
Dell Latitude D800
This may be SpeedStep slowing the processor to save battery life. It speeds up when it is needed.
Dec 13, 2007 | Dell Latitude D800 Notebook
Dell Latitude D800 Notebook Logo
188 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
