Question about Tascam CD Gt1mkii CD Guitar Trainer
Keeps switching off and showing tocread on display
  • Tascam Master
  • 5,603 Answers
That probably means it can't read the "Table Of Contents" which is essentially the directory of the disc.
MAKE SURE any disc you try to read has been "finalized".
Any disc that you have burned that can have stuff added is NOT finalized and may not work in certain CD players.
Posted on May 09, 2010
Senpera 2 when plugged into amp lights up but no display screen shows
Contact Peavey toll free at 877-732-8391 or by email at customerservice@peavey.com,
Dec 31, 2014 | Peavey Electronics Peavey Sanpera 2
I have a roland e96 that showed the message_INTERNAL BATTERY WEAK every time i switch on and the display of screen is empty
It's likely a coin battery, like the type in a computer, used to keep the bios or settings ram user settings (whatever)memory
Nov 30, 2014 | Roland Music
Load to default not working
Did you follow the instructions from the manual? If yes, at what point did this process fail?
Switch off the power of the XK-1.
2. Hold the [REC/JUMP] Button, and switch on the power.
3. Continue to hold down / Keep pressing the [REC/JUMP] Button until "Loading Default..."
appears on the Display.
4. After 5 seconds if everything is in order, PLAY Mode appears on the Display. (Completed)
Dec 20, 2013 | Hammond XK1 Pro Drawbar Organ
Numark ndx400
1 of yor tak switchs are faulty either cue or play button or maybe even the scratch button replace all 3 that should solve
Aug 03, 2013 | Music
Hello my Korg X5D on switching on shows 00:Initcombi0 on top display and "battery low" blinks on lower display, Keys from 33-40 are malfunctioning ( giving odd sound) other keys are working...
There's a watch type battery (flat disc) on one of the boards inside the X5D. This maintains the settings while the keyboard is switched off and could be the whole problem.
The keys are on two different circuit boards connected with a multi-pin cable. If the cable were dislodged I would expect it to simply cut off half the keys but it's probably worth checking.
Oct 30, 2011 | Korg X5d
It's been a long time since i've been using the unit but a strange problem appeared. when i step my foot on the foot pedal, the numbers used to show the patch just disappear... maybe it's something...
I would expect a problem with the power to the display. I believe these had LED displays and they use a reasonable amount of current. I would expect he power source for the display has a bad source of power. If poowered by an adapter, possibly the wrong adapter is being used with insufficient current capability or if powered from teh amp, then maybe the wire that brings the display power down is broken or a connector for that cable has a problem.
Apr 30, 2011 | VOX ToneLab ST Modeling Effects Processor
Como resetar o gfx8
zoom GFX-8:
The All Initialize/Factory Recall function is a special function
that lets you reset the GFX-8 to the condition in which it was originally shipped. When All Initialize is performed, all settings of the unit including all user group patches are returned to the default condition. Factory Recall can be used to reset only specific user group patches group to the default settings.
1. Turn power to the GFX-8 on while keeping the STORE key depressed.The display shows "ALL-INIT".
• To perform All Initialize, Continue with the next step.
• To perform Factory Recall, Use the BANK UP/DOWN foot switch and foot switches 1 - 4 to select the patch (from a user group) that you want to return to the factory default condition.
2. Press the STORE key once more.
All Initialize or Factory Recall is carried out.
If All Initialize was carried out,
the unit automatically returns to the play mode.
Note that when All Initialize is executed,
the contents of all patches stored by the user will be overwritten (erased).
When wishing to cancel All Initialize/Factory Recall,
press the EDIT/CANCEL key before step 2.
source: ZOOM GFX-8 User Manual.
Oct 13, 2010 | Zoom G1x Guitar Multi Effects Pedal with...
Hello. It's my first time on this forum. I just got a Fostex VF08 multitrack recorder from a friend of mine. But when I switch it on, the display is just orange, showing no text. All the commands seem to...
You will need to put th set on for really some time. I assume that the person who gave you must give more information if the recorder was working prior to this or was idling for along time.
If so leave the set on and allow the electronics to bring up voltage to all stages.
If there is no result look near the display unit the links, the cconnectors and the processor.
Now is your experienced friend can check out the prrocessor and display interface we can have some leads.
So check this out and respond
Sep 19, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
Tuner
In the navigator display in the upper right corner of the face, after holding the tap switch or the tap footswitch for over two seconds the display will indicate your tuning. Strike an open string and the left end of the display will show you the note. Then there will be left and right arrows on the screen until you adjust your tuning for that note. When in tune for that note, two asterisks will be displayed in the center of that display.
Read your manual on the page with the "Smart FX" at the start.
May 14, 2010 | Line 6 Spider Iii 30
Pedal Malfunction RP250
You will have to recalibrate your pedal. If you don't have your manual anymore try going to www.digitech.com. The procedure for the RP350 so that you don't lose your presets is : 1. Press and hold the UP/DOWN Footswitches until PDLCAL appears in the display (BYPASS,TUNER and EXIT will be displayed before PDLCAL is accessed after about 5 seconds). 2. When the display prompts you with TOEDN, rock the EXPESSION PEDAL forward (toe down) and press either FOOTSWITCH.
3. When the Display prompts you with TOE UP, rock the EXPRESSION PEDAL back (toe up ) and press either FOOTSWITCH.
4. The Display now prompts you to calibrate the V-Switch sensitivity (VSWxxx), where xxx is the current V-switch threshold. Rock the EXPRESSION PEDAL forward and press firmly on the toe once to turn the V-switch on (WAH ON) and again to turn the V-switch off (WAH OFF).
5. If the V-switch is too sensitive, press the right UP FOOTSWITCH to raise the threshold (range is 0-2000. Keep testing the V-switch sensitivity and adjust the threshold until it only engages when you want it to ( too sensitive a setting will lead to the V-switch falsely triggering on or off when using the Expression Pedal).
6.When the V-switch sensitivity is set to your satisfaction, press both UP/DOWN FOOTSWITCHES simultaneously to exit. NOTE: IF the DISPLAY shows ERROR, an error has occurred and steps 2 through 5 should be repeated. Sorry fo the caps but thats how the instructions appear in my sons manual. You can also dowload the manual and an editor librarian (for the 350 at least) at their site. They might even have an update for your pedal. Hope this helps. Keep playing.
Jul 09, 2009 | Music
Tascam CD Gt1mkii CD Guitar Trainer Logo
109 people viewed this question
Top Tascam Music Experts
Michial Gueffroy
Computer Links
drivealot
Are you a Tascam Music Expert? Answer questions, earn points and help others
