Question about Ryobi Snap In Primer Bulb Pump 683974 Blower Trimmer
Ryobi Leaf Blower
I"ve got a Ryobi leaf blower i push the primer bulb to get ready to crank it and then i choke it and it cranks and start running and then i turn the choke off and it runs for about ten seconds and then goes dead i can push the bulb again and it will crank and run again for ten seconds and then dies again do u have any idea whats wrong
    President:
  • 2,702 Answers
Yes,,,,its a dirty carb jet or a blocked carb jet strip the carb and blow out all the running jets,dont go poking wire into any of the jets to clean them this could bistroy the jet/s
Posted on May 08, 2010
Testimonial: "thanks going to go and clean the carb.thanks for the fast responds"
    Problem Solver:
  • 5 Answers
Hi it could also be a perished or split fuel line ,check especially behind the primer bulb were the pipes connect as this was the problem on mine
Posted on May 12, 2011
The little pump for gas does not wok
The primer does not necessarily need to work for the unit to run. It does have a choke to aid cold starts. However it is a good indication of something wrong in the fuel system. A primer bulb that does not return to shape or does so slowly indicates a clogged screen in the carb. Check the fuel filter and fuel lines. Replace the fuel lines if they are stiff or discolored, rebuild the carb and replace primer bulb.
Aug 29, 2014 | Ryobi Garden
Ryobi instruction manuals
Aug 29, 2014 | Ryobi Blower Vac 205mph Leaf Blower Or...
4 lawn mowers same problem wont start until I prime the by hand. Briggs Stratton 917.387500/ 12AV566n01124987/20043/SDSP2245D Will the same primer bulb fit the above mowers.
If its identical it should work ,if not take the old one to a mower shop,to get correct one and make sure the choke is going right on when the cable is in choke position.
Aug 05, 2014 | Ryobi Snap In Primer Bulb Pump 683974 ...
My Ryobi 4 cyl 30cc leaf blower just quit starting. Has always started perfectly, but now it just wont start.
replace spark plug.if spark plug okay problem could be carburetor or air leak at fuel lines or check primer bulb for crack which cause air leak.any breaks in fuel line or primer bulb cause air leaks fuel system cause carb not get fuel run engine.
Sep 20, 2013 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Leaf blower wont stay started, ran out of gas earlier is it flooded
you have pluggered the primer bulb untill it got full of gas set choke then tried starting it
Nov 08, 2009 | Husqvarna 155bt Gas Backpack Leaf Blower
Leaf blower will crank only when spark plug is dipped in gas and re-inserted
fuel system needs to be cleaned, carburetor diaphragms and gaskets replaced, check fuel lines, filters, primer bulbs
Nov 07, 2009 | Homelite 'Yard Broom' Leaf Blower
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Echo pb 200 leaf blower want start
Turn on ignition switch, Choke, prime bulb 5 times (or until fuel flows), hold throttle down and pull starter cord sharply until it tries to start, then place choke in mid position pull cord sharply again until it runs then move choke to off when it will allow it.
Also you can go to toro.com then customer care, then manuals and parts then type in model no. and download an owners manual.
Apr 06, 2009 | Echo Garden
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Ryobi Snap In Primer Bulb Pump 683974  Blower Trimmer Logo
799 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
