I have a toshiba tp-55g90 projection tv i plug it in and it sounds like it is going to turn on but then it just quiets and the light in the front blinks. i saw a couple of different things about the regulator ic and some capacitors but i need to locete so i can see if there bad could you let me know numbers of what to check. or what you might think is the problem thank you for your time
  • duwop56 May 09, 2010
    by chance do you know what kind of reading i am suppose to get when i check
    yeah it did help. thank you for your time.
  • 5,081 Answers
The most possible cause of the problem you are expecting is that because of a bad capacitor. If you noticied the capacitors are burned or bulged they might be faulty.Just check the continuity across them and confirm whether it is faulty and try replacing them.
Posted on May 09, 2010
  • INDIRA KUMAR
    INDIRA KUMAR May 09, 2010
    Just check the continuity of the supply
56 in toshiba rear projection tv. When u turn it on the green light comes on and a yellow light flashes 15times followed by a click sound. No picture. What does this mean?
Try going to www.toshiba.com to research your problem and what the 15 flashes of the yellow light means. Try unplugging your TV from the wall for about 30 seconds and then plug it back in. This will re-boot your TV (like re-booting your computer). If still no picture, if could be your bulb, motherboard or color wheel.
Mar 01, 2015 | Toshiba Televison & Video
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Toshiba TN50V71
Shorted horz. output transistor
Feb 09, 2009 | Toshiba TN50V71 50" Rear Projection...
Toshiba 52in
MY TV IS ON A REC TIMMER IT WILL TURN ON BUT IT WILL TURN OFF AGAIN AND THE GREEN LIGHT WILL COME ON .
Dec 28, 2008 | Toshiba 52HM95 52" HDTV Projection...
Have a Toshiba 42H82 rear projection TV
Sounds like a power supply problem. You will need your tech again.
Nov 13, 2008 | Toshiba 42H82 42" Rear Projection...
No power
Replace Convergence IC's STK392-110 and any burnt resistors
& check fuses F851,852,853,etc.........................T
Aug 11, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba 55" 55H70 model. Turns OFF, but won't turn ON until I unplug it from the wall first.
sounds like loose connections on the convergance amps ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Aug 22, 2007 | Toshiba 55H70 55" Rear Projection...
 Grubhead
Grubhead
