Question about Lexmark X6650 4-In-One Wireless InkJet Printer
MY PRINTER CARRIER IS JAMMED
I NEED ASSISTANCE BECAUSE MY PRINTER CARRIER IS JAMMED.. I HAVE NO CLUE WHAT TO DO. CAN SOME ONE HELP ME .. THANKS
  • 4,041 Answers
Hello there
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 08, 2010
  • Clive
    Clive May 08, 2010
    Hello there
    Make sure first that all you can see is out .
Carrier problem
It could be due to the cartridges or the encoder strip (transparent strip found behind the cartridge carrier) has gotten loose from its position. Please follow steps below to identify and fix the problem:
1. Open the printer cover and remove both the cartridges. Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
2. Check the encoder strip and make sure it is secured in its place.
3. Close the printer cover.
4. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
5. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
6. If no error appears, reinsert the other cartridge. Close the printer cover.
7. Replace whichever cartridge is causing the error to appear with a new cartridge.
8. If no error appears, try to print a document again to verify that the problem is fixed.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 21, 2011 | Lexmark X5470 All-In-One InkJet Printer
202 printer jammed error message appears, but could not locate
Here's an article in the Lexmark website on Error: "201 Paper Jam" or "202 Paper Jam". This will guide you on where to locate the cause of the problem. Follow the instructions. But if you're having a really hard time locating it or you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
Jun 28, 2010 | Lexmark C762dn Laser Printer
How do i get my ink carchrage out
Perhaps the Lexmark Z2300 User's Guide will be able to help you on that. Just click on this link: http://www.lexmark.com/publications/pdfs/2007/z2300/english/lxdpuser.pdf. Scroll to Maintaining the Printer, Page 28-29, for the instructions on how to remove or replace the cartridges. In some cases, the ink cartridge carrier won't position itself in the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the white tape in the middle inside the printer. The other end of it is connected to the carrier. Gently slide the carrier to the center. Load the cartridges. Close the cover. Plug the printer back to power source. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 20, 2010 | Lexmark Z2300 InkJet Printer
The power buttom is bllinking and the printer does not print. I cannot reach the cartridge. What can I do?
Most probably, you're having a problem with the cartridge not being recognized the printer. Maybe it's not seated well in the carrier or just needs cleaning. Maybe the carrier itself has stalled. Unplug the power supply(black box behind the printer where the power cord is attached) from the printer. Open the cover of the printer where the ink carrier is. Hold the solid white tape you see in the middle. Slowly drag the ink cartridge carrier to the center for easy access. Clean the nozzles of the cartridges. Reload the cartridges. Plug the power supply back in the printer. If power light is still blinking, check ink levels. Cartridges may need replacement. If you need more assistance, leave a comment and I'll get back to it. Thanks.
Apr 26, 2010 | Lexmark Z2320 InkJet Printer
Carrier is jammed dell printer all in one 944
check and clean the paper carrier and if it continues change the cartridge.
Nov 13, 2009 | Dell 944 All-In-One InkJet Printer
My epson r2400, On power up the printer goes through it start up sequence then after about 2 mins the carridge stops on the left hand side of its track and all the lights go out. the printer haed seem to...
Check that your printer head is not jammed or move freely.
For that put oil in head carrier .
Also clean dust from head contact with carrier .
Let me know if you need more assistance.
Thanks.
Oct 09, 2009 | Epson Stylus Photo R2400 InkJet Printer
6A00 error code is coming up on my PIXMA MP 500 Printer!
A 6A00 is a purge unit error. Either jammed or stuck or has gone bad. Check your purge unit. It"s the "wiper" which stop the printer
When the ink carrier is centered (automatic when the lid is open) look down to the right of it (far right) about a 2 o'clock position and see the squeegee thing.
It is supposed to be all the way back. Look for any paper residue or foreign objects.
Then take a small screwdriver and pushed on the hard plastic part (not the top where the rubber squeegee fins are) toward the back.
It may help to clean around it with cotton swabs and alcohol (very gently).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 26, 2008 | Computers & Internet
Clear carrier jam
hi,
Follow the wizard on the following website , to help you to pinpoint the problem
http://tinyurl.com/3nh59x
Thanks
Proton
Oct 02, 2008 | Dell 924 All-in-One InkJet Printer
Dell 942 carrier jam
This morning I replaced the cartridges in the Dell 942 printer, they jammed to the left which made a loud grinding noise and the cartridge jam error came on.
I solved the problem by turning the printer on with the top up which moved the cartridges to the right a little so I could reach back, push one down a little manually which freed them to move over to the middle.
Feb 28, 2008 | Dell 942 All-In-One InkJet Printer
Carrier jam
i had the same problem and i'm almost positive it's because i do not have a color ink cartridge in my printer. i called the technical support and they said that both ink cartridges have to be in the carrier for the printer to work. even if one of them does not have ink in it. hope this helps. (for me too)
Dec 18, 2007 | Dell 924 All-in-One InkJet Printer
Lexmark X6650 4-In-One Wireless InkJet Printer Logo
349 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
