Question about Black & Decker String Trimmer Cordless 12" 18V
String getting cut right past the ferrel on the spinning head.
This is model 82332 Black& Decker Yard Trimmer. When in use, the string will break right at the spinning head requiring much more feed reps. There is a metal ferrel that is supposed to prevent this. however, the ferrel is set back from the plastic housing (spinning head). Do to wear in the spinning head, the plastic has formed a v wedge which I believe is cutting the string prematurely. I would say this is a poor design. Is there a remedy for this problem?
SOURCE: Black & Decker 8209 Weed Trimmer
I fixed mine, but this thing won't let me post. If I have to be a member just to make a suggestion, my suggestion would be 'let me post my suggestion'. Do you think everyone passing through here is a member? Some of us would rather not sign up, but still have something to contribute. anyone out there to hear this?
Posted on Jul 20, 2008
SOURCE: the grasshopper stirng trimmer keeps letting to much trimmer line
i have the same problem. it sounds like your clutch is broken. i went to the hardware store and it seems like a hard piece to find. its unfortunate becuase its the little white plastic piece that should cause on $.99 to replace.
Posted on Jul 12, 2009
  • 133 Answers
SOURCE: string won't advance automatically. Thank you so
There is a rachet mechanism at the bottom of the spool. make sure the spool is seated fully. Also make sure the string isn't wound too tight or it will stick and not advance.
Posted on Apr 20, 2010
  • 133 Answers
SOURCE: B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Posted on Apr 21, 2010
SOURCE: How to wind string around the bobbin
The manual is available on line if you do not have your hard copy OR you could purchase a spool already loaded and ready to go.
Posted on Jul 04, 2010
Black & Decker GH3000. String is stuck on reel.
We live in a townhouse so our yard is't very large. We had actually skipped a few weeks of cutting the grass since our reel mower blades were too dull to cut the thick weeds and grass. This thing got the job done and did't break a cord. Really love Black & Decker tools. More details about the tips and tricks about the Black & Decker Click the link String is stuck on reel
Jun 02, 2018 | Black & Decker Garden
It looks like its working fine, but it doesn't cut the grass. Looks like the string is spinning with the turn instead of against it, if that makes any sense.
If the string is spinning it should cut no mater which way it is turning. maybe you aren't getting the trimmer close enough to the grass.
Apr 17, 2010 | Black & Decker String Trimmer Cordless 12"...
Describe your Black & Decker Grasshog
The push lock on the string feeder Is sticking. Pull it off, clean it out and put it back on.
good luck
Aug 07, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
I need directions to replace string on black and decker cordless 18v grasshog
Go to home depot. look at the floor model and the replacement spools they sell there. Reverse engineer the stringing process or but a pre-loaded spool.
Otherwise,
1. Squeeze the tabs on the side of the head of the unit to remove the spool cover.
2. remove spool.
3. place end of string in small hole in center ring of spool.
4. wide spool with string in the direction of the arrows printed on the spool. DO NOT OVERLOAD!.
5. snap string into notch on spool and cut string leaving 6" exposed.
6. thread 6" of string through hole in side of unit head, replace spool, and replace cover.
7. go cut grass.
Jul 07, 2009 | Black & Decker String Trimmer Cordless 12"...
The motor runs but the base doesn't spin.
The nylon Gear in the head has theeth missing. I need a parts break down and a source for part.
this is for a Grasshog. NST 2018 Trimmer
May 25, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Black and Decker Grass Hog Model #GH1000
the drive cable probley kinked or bent and does not drive the head the cable goes from the motor to the head take the clamp bolt out and lift the head off the cutter check the cable
Jul 30, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
37 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
