Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Does not have any suction to pick up
My dyston vacum has no suction to pick anything up?
    President:
  • 1,185 Answers
Clean out the filter in the top of the cyclone chamber
Make sure there are no blockages in the tubes or hoses by checking for vacuum
Posted on May 08, 2010
Vacum has suction, but won't pull debris from the floor
The vacuum may not be set for use on carpet.
Jan 19, 2017 | Vacuums
My Bissell bagless vacuum does not seem to work anymore. It will start to with a suction and then instead of picking up the dirt, it appears to blow the dirt out almost in a cloud of dust and debris from...
this is caused by a dirty air filter and/or a blocked vacume hose ( most of the time the blockage is at the bend where the hose enters the floor sweeper area ) ---
remove and tap out and brush the filter ( or use a air compressor to blow out filter ).
then with the vacume on its side - remove the bottom plate ( like you were going to change the belt ) and use a coat hanger and clean out the hose between the floor sweeper and where the suction hoes attaches. this will restore your vacume to full operation.
c...
Jan 23, 2011 | Bissell 6595 Lift Off Bagless Upright...
My Hoover vacuum cleaner is not picking up from the carpet like it used to. Like it's having difficulty picking up strings, fuzz, etc. from the carpet. Suction power seems to be fine. The belt and the...
YOUR VACUME SHOULD HAVE A HOSE THAT PLUGS INTO THE LOWER PART OF THE VACUME OR MAY COME APART AT THE BOTTOM . IT SOUNDS LIKE THE TUBE IS STOPPED UP AT THE FAN MOTOR
Jan 16, 2011 | Hoover Vacuums
I have no suction for vacumming the floor. the wand is totally still working and sucking it heart out. clear hosing doesnt looked cracked. dont know where else to look.
Hi, if the wand is doing its job very well, you have to have a blockage some where, either in the hose where it attaches to the bottom of the unit near the roller section. It may be hard to see, but this is what is causing the bottom from not picking anything up. Flip it over and remove any screws at the corners you may have. The bottom should pull right off. It will fit in 2 notches. Try and remove the roller and belt. Check for anything that may have been sucked up in that end. I bet you will find the problem. With all of the parts out of the way, plug it in and turn it on to see what has changed. If still no suction, you have to keep looking for the blockage. Keep me posted on this.
Sincerely,
Shastalaker7
Apr 14, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Not picking up, not getting any suction.
try to clean the filter out. I have a similar vacuum and I clean mine out and wash the filter out. Leave the filter to dry overnight before you use it again.
If this fails try figure out if there is something blocking it so it is not able to **** in air. message back if this does not work.
Also take the bottom off and look for obstruction and anything that is not in place
Mar 16, 2010 | Fantom Vacums FM760 Twister 500DX Bagless...
The vacum is 7 months old andAll of a sudden is very hard to push and it has lost suction how do I fix this
sounds like you have picked up some thing in the inlet pipe have a good look in the pick up brushes there may be thred stuck in there on the rollers
Oct 26, 2009 | Dirt Devil Featherlite Bagless Vacuum...
It wont pick up dirt and motor is very loud it was clogged but cleared it still loud belt is fine
check impeller that is the part that creates the suction in a vacum if impeller is broke that will make the vacum loud and vibrate
Oct 17, 2009 | Bissell 3910 Bagless Upright Cyclonic...
Loss of suction bissell vacume
that is normal for the vacume to shut off if the motor overheats you must keep teh dirt cup clean and empty and all the filters clean, when you empty the dirt cup if you have a lot of pet hair take the hose off and make sure that it is clean as well, and do not try to pick up any of those cleaning wipes that will stop it up real quick
Sep 29, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Poor suction on carpet
Did you check to see if brush is spinning ,
is belt broken? It could be something stuck
in the mechanism in the impeller, shute,etc
Nov 16, 2007 | Vacuums
Willnt pick up good...
I had this problem once too. When the hose is inserted into the vacuum, the floor unit (where the spinning brushes are) becomes the head of the vacuum. In other words, the suction goes through the floor part and then up through the hose and into the vacuum. If the suction is good when the hose is out, the the problem is blockage at the bottom piece. Take the cover off of the rollers (it is one screw then it pops right off) and see if there is a bunch of lint/hair/gunk blocking the suction hole. You could also take the hose part out of the vacuum and look down the empty shaft with a flashlight and see if you see anything there. Hope this helps!
Apr 04, 2007 | Fantom Vacums FM760 Twister 500DX Bagless...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
363 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
