Question about GE 26921GE1 900 MHz Cordless Phone w/Headset Belt Clip
The IN USE light is not on do i have to charge a long time before this comes on and i get a dialtone?
  • pookie100 May 08, 2010
    yes it was, but i have no dialtone but the phone rings and i hit talk button and nothing
  • 8,197 Answers
You need to charge the phone for 24 hrs befor you can use the phone.
Posted on May 08, 2010
  • Jyackle5
    Jyackle5 May 08, 2010
    Did you register the phone to the base unit. If not you need to do that. To do that you need to put on the base for 10 mins to register.
How do I fix my cordless phone?
buy a different phone would be my choice
Feb 06, 2016 | Lands Phones
Why no dial tone. Only static?
Check the phone line were it comes into the house there is usually a point where the phone connection from the the TELCO outside wires connects to the inside wiring.
Remove the inside wiring and test the wiring that is on the TELCO side. If you get dialtone the trouble is in the inside wire. If you don't get dialtone call TELCO
Aug 26, 2014 | Lands Phones
My phone came without a manual and I don't know how long it has to charge before we have a dialtone.
What make and model phone? If it's a cordless phone then in addition to being charged, the handset may need to be registered to the base before it can be used.
Aug 01, 2013 | Lands Phones
Phone shows a voice mail but no message on phone
The phone's voice mail indicator works with the voice mail function from your phone service provider. When your line is busy or goes unanswered (depending on how it's set up), the message is recorded by your service provider at their end, and you need to retrieve it. Most systems give a "stutter dialtone" when you pick up the phone to make a call (a few short bursts of dialtone before it becomes steady) to tell you when there's a waiting message. The message waiting light on the phone lets you know in case you don't pick the phone often.
Once you pick up your voice mail the light will go out and the dialtone will go back to normal. Check with your service provider for how to do it.
May 25, 2011 | Lands Phones
The entry of the phone number dials, but it stops at the last number, it does not connect.
Is the phone actually connecting to the phone line? You can enter a number and tell it to dial, and the phone will, but if you never got a dialtone the call won't go anywhere. If you press the TALK button, do you hear a dialtone? If not, you'll need to check the base unit connection to the phone line. The cord may have come loose at one of the ends, or some problem has occurred on the phone line. Maybe another phone in the house isn't properly hung up.
If you do get dialtone, make sure you're dialing a complete number. Maybe one of the numbers isn't being entered, and the phone line is waiting for the rest of the numbers. This is actually unlikely, since if you are connected but don't place a call after some time, an error message comes from your service provider.
You can also try re-registering the handset. If it's not communicating properly with the base, this will usually get it going.
Then, if other handsets are working and this one doesn't, it's just an electronic failure of some kind in the handset. If it's still covered by a warranty, let Vtech fix or replace it. Otherwise you'll need to purchase a replacement or see what service options are available.
Jan 02, 2011 | Vtech mi6896 Trio Cordless Phone
I have a GE 25942EJ3-C three phone set. I move
place the additional phones on to main base the charge/in use light will blink and reset phone.
Nov 19, 2009 | GE 25942GE2 Cordless Phone System
No dial tone but the word "talk" appears and it lights up so I don't think the battery is dead.
I agree that the battery sounds good.
So, do you have another phone to confirm that you have dialtone coming into your home?
If so, then the two ends of your wireless phone are not communicating...
They will try to resync if you power both ends off for a few minutes (unplug the base and remove the battery from the handset).
After a few minutes off, reconnect everything and place the handset in the base.....
After 5 or so minutes, test again. If it is NOT broken inside, it should provide dialtone (if it is coming into your home).
Oct 25, 2009 | Lands Phones
Fax has stopped working on Gestenter DSC525
The modem card is faulty. It needs to be replaced.
Aug 11, 2009 | Gestetner DSc525 All-In-One Laser Printer
MITEL 5303 Conf Ph
These are analog only phones using a POTs line if you've connected everything properly and all the cables are in fine condition no broken conductors or anything it should work. If the keypad lights up you only need to hit the very buttom button and you should get a dialtone. To make a call you may need to dial a 9 or 909 (depending on the phone system programming) to get an outside line if this connected on an anolog line through a PBX. Probably first test it using a working faxline. If you do not get a dialtone and all cabling looks good it maybe that keypad got dropped. I have one that has been knocked off of a table - someone tripped over the cord - noone will admit it but through testing I've discovered it's in the keypad end, symptons being no dialtone.
Jan 28, 2009 | Mitel 5303 Conference (50001905)
All lights are on. Nothing works... please tell me if u can help me irfan
With a different phone that you know works, make sure you have dialtone at the jack the base is plugged into. check to see if the battery is connected properly is it charging? you may want to clean the contacts with a regular pencil eraser.
Jan 26, 2008 | Panasonic KX-TG6700 Cordless Phone
Lands Phones Logo
24 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
