Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
How do I remove the lid - Whirlpool Ultimate Care II LSQ9564J Top Load Washer
    President:
  • 1,430 Answers
Try the video at www.appliancehelponline.com/servicemanual.html it is the one on taking apart a direct drive washer.
Posted on May 08, 2010
Do I have to change my license plate assembly since my bulb is out on my 2004 Cadillac cts 3.6l v6
no just change the bulb .
Open the rear compartment.
Remove the rear compartment lid applique. Refer to Rear Compartment Lid Applique Replacement in Body Rear End
1.Remove the rear compartment lid trim. Refer to Rear Compartment Lid Inner Panel Trim Replacement .
Remove the fastener securing the rear compartment pull down strap to the rear compartment lid.
Remove the rear compartment pull down stap.
Remove the fastener securing the rear compartment release handle escutcheon.
Remove the rear compartment release handle escutcheon.
Remove the push-in retainers securing the rear compartment lid trim to the rear compartment lid.
Remove the rear compartment lid trim from the compartment lid.
Disconnect the rear compartment lid applique electrical connector (4).
Remove the fasteners that retain the rear compartment lid applique (1) to the rear compartment lid (2).
Remove the rear compartment lid applique (1) from the rear compartment lid (2).
Remove the rear compartment lid applique electrical harness pass through (3) from the rear compartment lid (2).
Remove the license lamp socket from the rear compartment lid applique by turning it counter clockwise.
Remove the license lamp bulb from the socket if replacing.
Remove the license lamp from the rear compartment lid applique by lifting the retaining tabs and sliding the lamp away from the applique.
Jan 20, 2017 | 2004 Cadillac CTS Sedan
How to remove washer lid to replace lid lock
Remove power to the unit.
Locate the console and remove two phillips head screws. Most
models have them in the front, bottom of the console. In some of the newer models they are located in the back, bottom of the console. Some washers require you to remove two end caps on the console to access the screws.
After you remove the two screws, slide the console slightly forward and then up. The console will then hinge to the back of the washer.
With the console now hinged back, locate the lid switch harness.
Disconnect the harness and check for resistance between the 2 grey wires (outside) on the lid switch connector connected to top of washer. With the lid down the circuit should read no resistance. If the circuit is open(infinite resistance) then the switch needs to be replaced. You can also use a insulated jumper on the lid switch harness to determine if its the switch.
To replace the lid switch you will now have to remove the cabinet. Use a flat head screwdriver to remove the two clips holding the back of the washer to the outer shell of the washer.
Disconnect the lid switch harness(If not still disconnected).
You can now pull the outer shell away from the washer. Do this by
grasping the outer shell (I open the lid and grab it there.) and tilt the shell forward (toward you) and out. The shell is now removed and you can see the tub. Be careful not to bend the outside walls of the shell when removing and setting aside. This will help greatly when reinstalling the shell. Remove the 2 screws attaching switch to cabinet. Remove the screw connecting the ground on the cabinet. Use a flat blade screwdriver to push tabs on lid switch connector block to remove. Finally remove the whole harness from the 2 remaining retainer clips under the cabinet. Install new lid switch harness assembly and reassemble washer.
Apr 09, 2014 | Washing Machines
Need to remove lid
If you have the kind of lid that has the slots on the back this video will help
Dec 10, 2013 | Zojirushi Kitchen Appliances - Others
HOW TO REPLACE HIGH MOUNT BRAKE LIGHT 2002 CADILLAC DEVILLE
The light will be fitted from inside the trunk. You might need to remove any trim or lining on the trunk lid. There will be 5 small nuts on the inside of the trunk lid. 2 each end and one centre. The light should drop out. It could be tight so GENTLY rock it up and down to free it.
** NOTE ** The light fitting is likely to be a sealed unit so you will have to replace the whole light as you cant get access to the bulbs.
Mar 01, 2018 | Cars & Trucks
Who do you get in to change the back up light
Welcome to FIxYa.com
BACKUP LAMP REPLACEMENT
REMOVAL PROCEDURE
1. Open the rear compartment lid.
2. Remove the rear compartment lid trim.
3. Pull back on rear compartment trim panel.
4. Disconnect the backup lamp connector (5) from the rear compartment lid wiring
harness.
5. Press the grommet (3) out of the rear compartment lid.
6. Remove the fasteners (4) securing the backup lamp (1) to the rear compartment lid
(2).
7. Remove the backup lamp (1) from the rear compartment lid (2).
INSTALLATION PROCEDURE
1magJ
1. Route the backup lamp connector (5) and the grommet (3) through the rear
compartment lid Q).
2. Install the backup lamp (1) to the rear compartment lid(2).
3. Install the fasteners (1) in order to secure the backup lamp (I) to the rear
compartment lid(2).
NOTE: Refer to Fastener Notice in Service Precautions.
Tighten
Tighten the fasteners to 4.5 N.m (40 lb in).
4. Verify that the grommet (3) is filly seated in the rear compartment lid (2).
5. Connect the back-up lamp connector (5) to the rear compartment lid wiring harness.
6. Install the rear compartment lid trim.
7. Close the rear compartment lid.
Thank you for using FixYa.com
Regards, Lee Davidian
Dec 23, 2010 | 2003 Cadillac Seville
Mine wont spin
Your problem is more likely a broken lid switch. To test for this, lift the washer cover and look for a small hole in the washer top where the cover was. Push a toothpick gently into the hole and press the piece of plastic you see in the hole downward and listen for a soft clicking sound. If you don't hear a click or the plastic tab is not in the hole replace the lid switch.
Unplug the washer. Check the actuator on the lid that operates the lid switch to see if broken. Open the console of the washer. After removing the screws, the console will lift up and hinge back. Disconnect the plug going to the lid switch. Picture. Check the lid switch [lid closed] with an ohm meter from the wire plug-in leading to the switch. If no continuity, replace the lid switch. You will need to remove the cabinet to replace the switch. There are only a couple screws holding the lid switch assembly and a ground wire connection to the cabinet. Reassemble the washer and test the operation.
Unplug washer, remove the two console screws and tilt console back, remove cabinet clips, unlock lid switch block and then remove the cabinet. Remove the lid switch mounting screws, disconnect ground wire and remove lid switch assembly. Compare old switch to the new one. If the plastic sleeve of the new switch is longer, break off at the score mark. Pull wire partially out of sleeve before shortening sleeve. If the sleeve had to be shortened, the wires must be looped to take up the excess wire. Use supplied wire tie from the new kit. Install new switch assembly. New lid switch
Pay VERY close attention to assembling case back onto base so that sides engage tabs in base.
Sep 21, 2009 | Whirlpool Washing Machines
Can remove breadman pro lid
You might have figured out how to do this by now, but here's the answer anyway.
There are two slots that the lid's hinge pins slide into.  To remove the lid for cleaning or otherwise, tilt the lid at a 45-degree angle and pull it towards the front of the machine.  To put the lid back, simply reverse these directions.  CAUTION: Make sure that the hinge pins are completely inserted into their respective slots before carefully lowering the lid.  Not doing so could bend them or break them off and would ruin the lid.
Feb 14, 2009 | Breadman TR875 Bread Maker
Remove lid of top loading washing machine Kenmore 110.92575110
Remove 2 screws that hold the console in place. Most are at the rear corners of the console. Pull console forward and up and tilt back.There are 2 brass clips holding the cabinet in place. then the cabinet can be removed by tilting forward and away from base. there is no reason to remove the lid.
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite washer lid removal?
how do i remove the washing machine the top
Oct 20, 2008 | Washing Machines
How do I remove lid for cleaning
With lid in open position just pull it straight up and off.
Feb 12, 2008 | Rival CF153-WM Deep Fryer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
60 people viewed this question
Dan Webster
Dan Webster
Sal De
