My computer takes about seven minutes to start up. What can I do?
  • 149 Answers
If you look in the start up menu and find that it is loading programs that you dont realy need on start up. you should remove these from the menu. it will then start up faster. failing this get more ram installed.
Posted on May 08, 2010
How to change light bulb in 2009 malibu
https://www.youtube.com/watch?v=ywlOIbxsMxU
you have to take off the entire bumper. just for the bulb. he doesnt speak and there is more to taking it off and replacing the bulb. So I am going to add the seven year old who takes off the entire thing a video seven minutes long. **** just a friendly reminder*** with care remove the plastic push pins they can break pretty easily and youll need to replace them if broken.
https://www.youtube.com/watch?v=9RiqSjaaquA
the seven minute video by a seven year old, it is well lit and simply explained.
ENJOY!! have fun
Aug 12, 2014 | 2009 Chevrolet Malibu
I have vitz 2007. 1.3 litre patrol, when i cleaning throttle body i noticed that there is a gap between the throttle plates (blades) and the Bore, me mechanic told me that there is no adjustment in it and...
CAUTION;
Do not attempt to disassemble the electronic throttle body, or the adjustment screw which is sealed with appoxy other wise you take the consequences.
The gap between throttle plate and the bore is always there which is preset at the factory and does not always mean to replace it. When the throttle body is installed, connector is attached and the car is started, and relearned the ECM brings it back to its home position automatically.
The unstable engine speed can be brought back to its default setting through the re-learning process. It can be done manually or with the help of diagnostic computer.
1. MANUAL PROCEDURE OF RELEARNING THE IDLE SPEED:
1.lower the driver's side window,take the key/ remote out the car, remove the battery negative terminal for 10 seconds or more. Connect the terminal back.
2. Check the coolant level, engine oil level before starting the engine.
3. Start the engine and hold the throttle pedal at 3000 rpm till the radiator fan becomes on.
4. Leave the engine at idle for seven minutes after the radiator fan becomes on.
5. Switch off the engine after seven minutes. Wait 3 seconds. The learning process is complete.
6. Start the engine and it is supposed to work fine.
If the problem persists, perform the Zero Point Calibration with the help of a Diagnostic Computer.
2. RELEARNING IDLE SPEED WITH DIAGNOSTIC COMPUTER:
Before performing Zero Point Calibration be sure that the car be parked on a level floor and not be shacked during the whole process.
You can do the calibration by clicking Engine and ECT > > special function > > and then click "deceleration 0 point calibration" while you do that make sure that your car IGN switch is "ON", engine OFF and your gear shift is on "P and the engine coolant temperature above 80 degrees Celsius.
Have a good day. Thank you for visiting Fixya.
Aug 29, 2013 | 2007 Toyota Yaris
1997 buick 3.8 no spark has injector pulse no start
get a cup of warm water let it settle for about fifteen minutes then go to the fuse panel take a hammer and hit the ignition fuse seven times then get the water and dump it on the fuses if this does not work repeat the process over refer to owners manual
Oct 13, 2012 | 1995 Buick Riviera
The dish washer starts to fill then stops and starts again then stops and the red light blinks on and off
Does it blink seven times, pause, then seven times, pause, seven times, etc. ?? If so you may have a bad heater element. Or the water temp into the D/W is not hot enough. Most machines require at least 120 degree water to work properly. Take a close look at the heater if it looks ok you'll have to check it and the heater circuit with a meter. Turning the breaker off for 7 to 10 minutes will reset the control board but wont fix the heater of course. Good Luck
Mar 12, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Gardenline - garden tap timer.I can't work out the instructions- the timer won't work . Please help and give me an easy guide line to the instructions.
1. Press PROG
2. Press up/down arrows to select the programme you wish to set (16 spaces are available)
3. Press SET
4. Press up/down arrows to set the hour at which watering is to start
5. Press SET to store the hour
6. Press up/down arrows to set the minutes at which watering is to start
7. Press SET to store the minutes
8. Press up/down arrows to set the number of hours over which watering is to take place (0-9)
9. Press SET to store the hours
10. Press up/down arrows to set the number of minutes over which watering is to take place (0-59)
11. Press SET to store the minutes
12. Press up/down arrows to select which days of the week watering is to take place (2nd means every second day, 3rd means every third day). When the required day of week is displayed press SET to store that day. The next day of the week will then be displayed and Set can again be used to store that day. Carry on throughout the seven days of the week as required.
13. Press the clock symbol to store the programme.
Mar 07, 2011 | Hardware & Accessories
Take at least seven time before my car start?
if its cranking over its not the battery or starter. Its going to be a fuel pump issue or ignition issue. You wil need some test equipment. Best bet is to take it in if you dont have the equipment before you end up stranded and have to get towed in.
Mar 20, 2010 | 1999 BMW M3
My HP s7720 desktop will not boot up. On the startup screen I can see white lines like pinstripes they are also in the restore box that comes up but the computer will not boot up is it a graphics card...
Do you have hard drive light activity? Do you have more than 1 hard drive?
I would take the video card out, once you have everything unplugged, and give it ten minutes out of the computer, then reinstall making sure everything was secured, then tried to boot.
Another problem that comes to mind is that your power supply could almost be gone, causing the striped screen and poor hardware reaction.
Aug 12, 2009 | Computers & Internet
Help me solve
1. Four Hundred Seventy-Eight Ten Thousandths
2. One Thousand Four Hundred Thirty Five Ten Thousandths.
3. Three Thousand Two Hundred Five Ten Thousandths.
4. Four thousand Seven Hundred Eighty Four Ten Thousandths.
5. Four Hundred Ninety Seven Ten Thousandths.
OR
1. Zero point zero four seven eight.
2. Zero point one four three five
3. Zero point three two zero five
4. Zero point four seven eight four
5. Zero point zero four nine seven
Thanks and please take a moment to rate as fixya.
Jul 06, 2008 | Audio Players & Recorders
Sudden PC slow down
Learn how to speed it up easily with some of the free PC speed up software.
best regards!
Dec 01, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
