Question about Braun 9595CC Electric Shaver
AFTER RAZOR IS FULLY CHARGED IN CLEANING STATION IT CUTS OUT SHOTLY INTO THE SHAVE
  • 1,511 Answers
Hello and Welcome to FixYa!
Actually it happens due to battery cells weakness. With the passage of time or due to poor battery quality, the battery becomes weaker day by day. Please do make sure that your batteries are up to the mark and in good working condition. If not you need to replace the battery. If your device is a bit old and it working on the default batteries then you must go for the battery replacement.
For the replacement of battery, you need to locate the battery compartment, sometimes accessible without opening the complete unit and sometimes you need to unscrew the unit in order to change them... Replace the battery and then check. This problem will definitely be over after the replacement.
Best Of luck,
Please Do RATE my solution, If found HELPFUL,
Concerned.
Posted on May 08, 2010
Tip
How to use an electric shaver
If you are a using an electric shaver for the first time, I hope that this article will get you going. Proper techniques will ensure the best, closest shave possible. Maintaining the razor by properly cleaning and recharging it will also ensure that the razor works correctly and does not malfunction during use. Proper care and maintenance of the electric razor will also ensure that the razor will last for years to come. Consider this article as a shaving-best-practices template for your first electric shaver.<br /> <br /> Firstly, clean your face and dry it. Electric shavers do a better job when your face is clean. Turn the electric razor on and begin shaving against the direction of hair growth, moving the shaving head linearly and in circles. Circular motion Stretch the skin with your other hand to make the hair stand up straighter so the razor blades shave closer.<br /> <br /> After shaving, turn it off and rinse the cutting heads under warm water. You can also use jet clean system once a week to clean your shaver. Make sure that you charge it for the time specified in user manual. Overcharging may cause damage to the battery.
on Mar 03, 2011 | Health & Beauty
Does shaving your legs and underarms cut you? I want to shave my legs but I wear short skirts and dont want to walk around with shaving cuts.
Shaving your legs shouldn't leave cuts on your leg unless you use a blunt blade or don't use a shaving cream or body wash - in these situations the razor doesn't glide along the skin and can cause cuts.
Feb 14, 2013 | Health & Beauty
What is an electric shaver?
Not like shaving razors, electric shavers work by shearing the whiskers, the hair enters the perforated metal heads of the shaver and is cut by the moving blade inside.
Feb 06, 2013 | Health & Beauty
Whats a straight razor?
A straight razor is a shaving razor constructed of a long steel blade attached to a handle by means of a pivot. A straight razor is a classic shaving method and nowadays it is less commonly used since the invention of the safety razors.
I was given a norelco 3605 shaver in excellent condition (used) without instructions and would like to know the charging procedure and duration (the amount of time it takes to fully charge the razor). Is...
The manual says to charge for 16 hours if it has not been used in awhile. They say nothing about it over charging, but the batteries need to be used and let discharge through shaving. A fresh/new battery is supposed to last about 2 weeks before needing a recharge. I think keeping them charged all the time cuts down on battery life.
Jun 07, 2011 | Norelco 3605 X Electric Shaver
I just purchased a Panasonic Arc IV nanotech wet/dry shaver. I've been using it in the shower, and it's very effective. However, I'm wondering if I'm using it correctly. The shaver's manual says it should...
You did not include the specific model number written on your shaver but I will try to address your questions the best I can without it.
Most likely, your shaver came with a cleaning station and charging station. The cleaning light would tell you it is time to use the cleaning station. After each shave, you should dump out the shavings and rinse under the tap. You should let the shaver dry without the cap on.
ShaverOutlet com ShaverOutlet com Shaver Replacement Parts Manufacturer...
Mar 27, 2017 | Panasonic Es8243a Arc Iv Nano Electric...
I no longer have the owners manual. What does it
According to the manual, the red light comes on while charging when the battery does not yet have enough charge to sustain a 3-5 minute shave. The green light stays on steady while the razor is charging, and blinks when it is fully charged. If your battery life is short, they might need to be changed.
Jul 14, 2009 | Norelco Rechargeable Cordless Men's Razor...
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Braun 9595CC Electric Shaver Logo
76 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
