Question about Whirlpool Washing Machines
Whirlpool awm 820 wont spin, fills with water & then empties, motor not turning
SolutionGuy
  • 331 Answers
SOURCE: Whirlpool LHW0050PQ - Water wont empty or fill
This sounds like a plumbing problem. Lets see if we can isolate it. Turn the valves off behind the washer and remove them from the washer. Remove the washer drain hose from the stand pipe. Stuff one of the hoses into the now vacant drain line and turn the water on. Then do the other hose. Any noise? Now reconnect the fill hoses to the washer and reinstall the drain hose to its' place. Turn on the water valves at the wall, set the washer to a cold/cold cycle and start it up. Listen for noise. Now shut the machine off and set it for a hot/cold cycle and turn it on. Listen for noise. If you get no noise now, it's all good. If you're getting noise from just your hot water, your water heater is set too high and you have steam propagating in your plumbing. Your washer water valves (where the hoses connect to your machine) will only do this if you have low water pressure coming from the wall. Still, it'll be a plumbing problem.
Posted on Jul 29, 2007
murdozzz2
  • 75 Answers
SOURCE: washing machine wont empty
hi there this is a common fault empty the water into a bucket and remove the water pump to check for blockages, the pump is located at the rerar lefthand side of the w/m.
also check your drain hose where it connects under your sink.
hope this helps
Posted on Dec 11, 2007
  • 1314 Answers
SOURCE: will fill water but agitator wont run.
you have a broken motor coupling if you want to tackle this your self then reply to this message and i will tell you how if you have to rate me to reply then give me 4boxes im not sure how this site works you can do it if you like to tinker
Posted on Jan 01, 2008
yalmer
  • 552 Answers
SOURCE: whirlpool awm 049 washing machine
If the washer leaks only during the fill cycle, check the following:
Air-gap device: The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube:There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout:Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During spin cycle only:
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Look at the entire hose and correct any problem you find. Also, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make.
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it.
Pump: If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Main tub seal: The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Outer tub:The steel or plastic outer tubs can rust, split, develope a hole in some way. If this happens, you may have to replace the outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Feb 07, 2008
mikedurland
  • 481 Answers
SOURCE: Whirlpool LSQ9549lW0
sounds like something is stuck in the water pump. look under the machine and you will see the water pump front and center of machine.
Posted on Jul 14, 2008
My front loading machine does not appear to be pumping water in a light flashes H20 and beeps
? im confused are you saying its not filling with water or its not emptying of water , if its not emptying of water , yes its true the pump in it is driven by a motor and yes they d go bad and yes if the pump wont turn then yes it wont empty out , this makes sense to the blinking light of water detection you see ? ohh and most times the pump and motor are all one assembly , if it wont fill with water then you need to ck the inlet valves they get clogged or go bad too ) there is no motor that is assoc with these valves that I know of
May 25, 2016 | Washing Machines
My Amana Washer wont lock
Here's a video darrell r waggoner suggested as a solution to your problem from YouTube:
Drain Hose (Pump to Back Panel) Replacement (part #W10358149) - Whirlpool/Kenmore Washer Repair
Feb 24, 2013 | Amana 3.2 cu. ft. Top-Load Washer
It wont spin out
if it doesnt go into spin brushes in main motor could b stuck or worn check also outlet tube and waste pipe not blocked if it goes into spin but doesnt empty check spin pump not jammed but most common fault brushes in main motorworn
Mar 18, 2012 | Whirlpool Washing Machines
My awm wont go on spin cycle
check water is pumping out. If so then it sounds like your motor brushes may need replacing, on main motor
Feb 19, 2010 | Whirlpool AWM5125/1 Front Load Washer
My whirlpool awm 5125 wont fill up at start of washing
if it has just been installed check that the water tap has been turned on and the hoses have not been bent or twisted if these are ok you may have to replace the solinde valve in you machine
Sep 22, 2009 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool washer AWM 5145/5 water wont drain/stops on B
I had same problem twice, the first time there was a sock in the filter at the front adjoining the pump, the second time a sock had got in the pipe under the drum which is more awkward to get to but is possible if you have the tools to remove the back plate and are ok at diy, there is a spring tension clip on the pipe which comes off quite easily with a pair of pliers.
Jan 14, 2009 | Whirlpool AWM5145/2 Front Load Washer
Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Jul 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
77 people viewed this question
Dan Webster
Dan Webster
Sal De
