Question about Husqvarna Garden
Riding mower stalls when blades are engaged
Mower runs great until you start the blades, then stalls - no matter how long it has been running.
    Problem Solver:
  • 10 Answers
If you bought this mower used and did not change the oil and air fillter or even looked too see what the oil and air filter looked like that could be part of your problem what ever you do when you buy a used mower always change the oil and air filter make sure you are lubed up good and the mower can breath then go from there to your spark plug if it is a used mower change it is better safe then sorry got to keep that sparky sparking. Then if the problem continues think could the lever for lowering and raising the blades sliping and causing the blades to get to close to the ground if not. After all of this it would be a good time to call you nearest pro for some advice not to fix it because if they are anything like the ones around where I live they will try to help you figure out what it is just by what you tell them over the phone before they will want to see it and charge you anything.Good luck.
Posted on May 08, 2010
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Mower cranks and runs smooth until i try to engage blades or put mower in gear. it then stalls out
The seat switch is not making. You can start the mower but if you try to move it or cut, the switch is acting as if there is no operator present. Find it under the seat.
Gary
Sep 16, 2011 | Craftsman 18.5 HP 42"
I have the Craftsman 20.5 Model 944.609800 42 in mower I can get it to run but when i put it in gear or take my foot off the brake it stalls it also stalls when i engage the mower blades can you help i...
I agree it is the seat switch. This switch will let you start the mower as long as it is in neutral, the brake is set and the mower blades are not engaged. I think it is just two wires, maybe you can jump them together and see if it runs.
Gary
Aug 06, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My 48 inch riding mower shuts off when I try to engage the blade. It runs until I try to engage
mine has a reverse cut out when blades are running....maybe the switch is bad and thinks mower is in reverse therefore shutting down the mower when the blades are engaged....
Aug 21, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
Model 111 - worked great in Spring. Sat out all
SOUNDS LIKE THE PT O SWICH IS BAD OR THE SEAT SWICH IS
Oct 18, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Tractor starts, stalls when blade is engaged, or brake released
you have a safety switch malfunctioning or a transistorized relay not working properly. Go to www.partsdirect.com, this is sears website. It should be able to find and illustrated parts list for your mower.
Sep 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a Sears 26 hp garden tractor that stalls when I let off of the clutch/brake or engage the mower blades. I have bypassed the under seat swith, and I have also bypassed the clutch/brake switch. The...
does it run off of a pto system or is it a lver type if its a lever type there is a switch under the lever also you might have something caught in the deck causeing it not to engage blades if i can further help e-mail me wade at wadembly@aol.com
Jun 24, 2009 | Craftsman 26 Hp 54" Deck Yard Tractor
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Garden Logo
258 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
