Question about Garden
I have a 46 inch Murray riding, it runs fine but won't move in either direction. The blades will turn. The belt that goes to the pulley on top of the *differential* is in place and is turning the pulley. The direction foot pedal is moving the lever on the side of the *differential*. When I parked it in the fall, everything was working fine. Any help out there? Rick
  • 10,319 Answers
Raise the drive wheels off the ground and place the transmission in to 1st gear. Turn the wheels by hand and listen for the trans to make a churning noise inside of it. If a scraping noise is made the shafte is broken inside of it
Posted on May 08, 2010
I have a vintage Murray Riding Mower, model number is missing has three blades each blade is 15.5 inches Need belt diagram to install both belts to deck
If you have info numbers off the engine, usually found stamped on the top front area, it should at least give you an approx. year.
Sometimes there is a belt diagram under the foot rest area.
Worst case : The belts always fit/sit with the flat part to the flat pulleys and the v part of the belt to the v pulleys.
Oct 24, 2015 | Murray Garden
Spring mount location for belt tensioner for murray 45256x92a
Try this site to get your manual and see if the exploded parts diagrams help
Mar 30, 2015 | Murray Garden
Flow of belt between two small pulleys on a murry 425303x92
a4e1b0f6-5618-4d4f-bf75-6554491a4723.gifmaybe this can help.. NOTE: unsure if it is the exact same model as yours.
Jun 17, 2014 | Murray 46 Primary Lawn Mower Blade Belt...
Need diagram for belt instalation for murray 46" cut
Select Index Numbers here:
2 Asm, Jshaft Housing Head W
3 Q2 Pulley , 46"
4 Shaft, Splined Jacks
6 Nut, Pulley
7 Hub, Blade Adaptor
8 Q4 Blade 46" Mulcher
9 Washer, Bellevile(ard
10 Washer Hardened (ard
11 Nut Hex (ards)
12 Screw, 3/8, 16X1.25
24 Rod Belt Guide
25 Belt Cross Drive Ja
26 Belt Primary 46" J
34 Bracket Cover
35 Bracket, Pulley Cover
36 Qx Lburg# 094605E700 -INACTIVE-
37 Use Lburg# 093349 Zi -INACTIVE-
38 5/16, 18 Hexwdfllk Wh
39 Screw, 5/16, 18X.75HH
40 Cover, Pulley Right
41 Screw, 10, 16 .190X.62
72 711327
72-1 Wheel, Gauge
72-2 Bolt, .500X3.275HHSH3
72-3 Spacer, Slev .515X1.
72-4 Nut, 3/8, 16 Hxctrlkj
72-5 Qxcolor Code Require -INACTIVE-
79 Pin Detent Ring (DP5
80 Asm, Mulcher Plug 46
81 Bolt Carriage (ards
82 Nut, Wing (ards)
89 Zerk, Grease Fitting
Apr 21, 2014 | Murray 46 Primary Lawn Mower Blade Belt...
Belt diagram for a murray 46 model 46573X92A
This has a couple of diagrams with belts. Hopefully it has what you need. If not let me know and I'll keep looking for you.
http://www.outdoordistributors.com/pdf/Murray/MURRAY-MODEL-46573X92A-LAWN-TRACTOR-(1998)-PARTS-LIST.pdf
Jul 28, 2012 | Murray 46 Primary Lawn Mower Blade Belt...
Primary belt motion belt diagram for a murry 46 inch cut 2006 model
just did another murry today there is a sticker of the belt routing on the bottom of the foot rest
May 28, 2012 | Murray 46 Primary Lawn Mower Blade Belt...
Murray Riding Mower will not move forward or back
my murray Riding Mower will not move forward or backward
Jun 22, 2009 | Garden
Engine Pulley 660 MTD Yard Machines
make sure the narrow side of the belt goes in the pulley; you may have the wrong belt; make sure all the pulleys for that belt are the same height , if one is higher than the others that may be the problem
Jun 12, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Mower drive belt comes off murray 17hp
if you look somwhere next to drive belt then there is a spring. you may have to tighten it. or bend the guiders on the pulleys that the drive belt goes through.
Apr 13, 2009 | Oregon Scientific Oregon Gator Mulcher...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
