Question about Maytag Neptune FAV6800AW Top Load Washer
OP when press start
Why does it say "OP" when i press the start button?
  • 335 Answers
I have to do a quick response take a look at this link http://www.fixya.com/support/t4615995-op_code_lid_closed and see if it will get you started.........Rich
Posted on May 09, 2010
How do I op my dvd player
Connect to power
Connect HDMI cable to television
Switch it on
Press eject button to insert DVD into drawer
Press button a second time to close drawer
Press PLAY
Scroll through inputs on the television until you see the content
Jan 09, 2016 | Televison & Video
Como habilitar mute
queria tmb
You may also use the following shortcut:
Dial ''1'' to exit programming mode and store the option as Enabled
(Mute Button, Record Out, Record Warning Tones), or
1-Line (Display) or the Per Plug setting (Headset Volume).
Dial ''2'' to exit programming mode and store the option as either
Disabled (Mute Button, Record Out, Record Warning Tones, or
Headset Volume) or 2-Line (Display).
Dial ''3'' to set the Headset Volume to the Per Call setting. (This
option is ONLY available for the Headset Volume setting.)
1-While on-hook (the headset must be unplugged), press 'SELECT'
+ The Light next To 'SELECT' Goes on.
2-PRESS 'MUTE'
+ THE CALLMASTER is in option Programming mode.
3Dial The 2-Digit Code, "68" ("MU").
+ The current Setting (Enabled or Disabled) is Shown on The display.
4-Dial * To chande the Setting.
5 when the setting you prefer is shown on the display, press # to save it an exit Programming mode.
DISPLAYING THE OPTIONS -------
To display the option settings:
1 While on-hook (the headset must be unplugged), press 'SELECT'
Select .
d The light next to
'Select' goes on.
2 Press
''Mute'' .
d The CALLMASTER is in option programming mode.
3 Dial the 2-digit code, ''00.''
d The display shows the option settings (three options are available
on the CALLMASTER III; four options are available on the
CALLMASTER II).
d The display will return to normal after approximately five seconds.
NOTE: Use the same procedure for international settings. However, you
must dial ''11'' instead of ''00.'' The top line of the display shows the
international settings, and the bottom line will either be blank or report a
problem with the (EEPROM) memory used to store the options an
Voc? tamb?m pode usar o atalho seguinte:
Dial '' 1 '' para sair do modo de programa??o e armazenar a op??o como Ativado
(Bot?o de mudo, Record Out, Record Aviso Tones), ou
1-Line (Display) ou a defini??o Per Plug (Headset Volume).
Dial '' 2 '' para sair do modo de programa??o e armazenar a op??o como quer
Disabled (Bot?o Mute, Record Out, Tons de aviso Record, ou
Volume fone de ouvido) ou 2-Line (Display).
Dial '' 3 '' para definir o volume do auricular para a defini??o por chamada. (Este
op??o s? est? dispon?vel para a configura??o de volume do auricular.)
1-o monofone no gancho (o fone de ouvido deve ser desligado), prima ' SELECIONE '
+ A luz ao lado ' SELECIONE ' continua.
2-PRESS ' MUTE '
+ O CALLMASTER est? no modo de programa??o op??o.
3-discar o c?digo de dois d?gitos, "68" ("MU").
+ A configura??o atual (ativado ou desativado) ? mostrado no display.
4-Dial * Para Chande o Ambiente.
5 quando a configura??o de sua prefer?ncia ? exibido no visor, pressione # para salv?-lo de um modo de sair da programa??o.
Apresentar as op??es -------
Para exibir as configura??es de op??o:
1 Enquanto estiver no gancho (o fone de ouvido deve ser desligado), prima ' SELECIONE '
Selecione.
d A luz ao lado
' Select ' continua.
2 Pressione
'' '' Mute.
d O CALLMASTER est? no modo de programa??o op??o.
3 Disque o c?digo de dois d?gitos, ''00.' '
d O visor mostra as defini??es de op??es (tr?s op??es est?o dispon?veis
na CALLMASTER III; quatro op??es est?o dispon?veis na
CALLMASTER II).
d O display voltar? ao normal ap?s cerca de cinco segundos.
NOTA: Use o mesmo procedimento para as configura??es internacionais. No entanto, voc?
deve discar '' 11 '' em vez de ''00.' 'A linha superior do display mostra a
configura??es internacionais e a linha de fundo ou ser? em branco ou relatar um
problema com a mem?ria (EEPROM) utilizado para armazenar uma das op??es
Oct 29, 2013 | Avaya 6408D+ 8 Button Display Telephone
Why does it say "op" when i press the start button?
The Service Manual for reference. Sears Parts Direct for reference.
I feel you have lost signaling from the Left Hand Lid Lock for Lid is Open/ Lid is Closed.
First check is to place a magnet over the Left Hand grey bumper and while watching the LED display see if the OP error code clears. If it does you have a lid magnet out of position. See the Service Manual for access to the Lid Magnet.
See Pic;
If an external magnet over the Left Hand grey bumper doesn’t clear the OP error code with the lid open then See this Link for troubleshooting Left Hand Lid Lock Troubleshooting. I discuss the OD error code but the OP error code troubleshooting is very similar. If the lid Magnet is not out of position then I feel you have a broken lead at the Magnetic Reed relay or severe corrosion issues with the Left Hand Lid Lock preventing Lid Open/Lid Closed status signaling to the Control Board in the Console.
FAV6800A/FAV9800A replacement Left Hand Washing Machine Lid Lock - 25001048
Let me know if you have any questions or concerns…….Rich
May 20, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a Oki b6500. Replaced the fuser. How to reset the message exchange, "Maintenance." Please help!
The following procedure was provided by Oki Tech support when a web search did not provide an answer. Resetting the Fuser After Replacement - When Counter is NOT Reset First print out a MenuMap and note the fuser count, to later verify that the maintenance reset has taken affect. To reset the fuser counter, enter the diagnostics mode and go to Maintenance Mode Step-1 How to enter the maintenance mode. Hold the Menu & Right arrow button while powering on the printer. Hold the buttons down until the op panel displays “Initializing”. The op panel will display “Output Test” Step-2 Press the down arrow three times. The op panel will display “Maintenance Info” Step-3 Press the right arrow. The op panel will display “Reset Maint Reqd Execute” Step-4 Press the select button. A quick flash will come up on the op panel “Resetting Maintenance Reqd”. The op panel will then display “Reset Maint. Reqd. Execute” Step-5 Press the Cancel button to exit the Maintenance Mode and go back to “Online”. This completes the process, please print out the Menu and inspect the Fuser Count it should read ‘0.’
May 19, 2010 | OKI B6500 Led Printer
Change date and time
This can only be done if you have the Fax option fitted. Assuming you have then :
Press the SPECIAL FUNCTION key
Scroll down to KEY OP PRG and press OK
Enter the Key Op code - default is 00000
Scroll to FAX and press OK
scroll to INITIAL SETTING and press OK
Scroll to DATE & TIME SET and press OK
Enter the Year, Date and Month if required and Press OK
Enter the time (in 12 hour format) , press OK then select AM or PM and press OK
press the CA button to exit.
Mar 15, 2010 | Sharp AR-M208N Copier
There is no sound in my color tv 21pt2216.
enter service mode by pressing following sequence 062596 menu make option 4. 0
Jul 13, 2009 | Philips 27PT8420 27" TV
I press one button and two buttons work at the same time
Thats usualy signs of water damage. If you know what you are doing, Open the phone and remove the front plate. Inspect the phone and clean with 100% alcohol. Also you need to remove the white plastic keyboard membarane and clean the keyborad citcuits under the letters that you are having problem with
Mar 30, 2009 | RIM BlackBerry Pearl 8100
I c600 in km machine how to reset
Press the following op panel buttons
10871087
start
163
start
execute
Jan 04, 2009 | Kyocera Mita KM-2050 Printer
Need to reset calculator
When you press the reset button it resets EVERYTHING. You are now back at square one. Start all over again.
hamar nnelg
Apr 01, 2008 | Computers & Internet
Maytag Neptune FAV6800AW Top Load Washer Logo
73 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
