Question about Echo CS600P Gas Chainsaw 20 Inch
What is correct fuel mixture for Echo CS 6701 Chain saw?
    President:
  • 2,220 Answers
"Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more."
The above excerpt is from the Echo FAQs (6) here:
http://www.echo-usa.com/faqs/
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 08, 2010
Why does derate lose power?
OK things to check. Gas/Oil mixture make sure you mix it in right amount. Be sure chain is NOT too tight. Now be sure to let the saw do the work . if you put too much pressure on it or,the chain is dull , the saw will loose power. Let me know how it goes.
Dec 03, 2015 | Echo Cs-400 18" Gas Chainsaw 40.2cc Sealed
How to replace clutch spring on a echo 650 chain saw?
id replace the entire clutch as if spring came out then therese got to be a reason
Mar 01, 2015 | Echo Cs-650evl Cs 650evl Chain Saw...
My Echo CS 3400 chain saw has an air vent problem
Most handheld power tools have a tank vent that will hold some pressure, Don't quote me. But If I turn the saw sideways and the vent allowed fuel to drain out THIS WOULD CREATE A FIRE HAZARD. If the fuel is boiling when you open the fuel cap could this be a engine temperature problem? or low octane fuel.
Apr 07, 2014 | Garden
I purchased an Echo CS-400 a month ago, put the oil in the gas as required, and after using it for an hour, it stopped and would not start. I brought it for repairs to a shop, and they told me the pistons...
Hi, basically this is partially correct. It will have this damage with not enough oil added to the fuel, also by having the incorrect type of oil added to the fuel. Also all new saws must be tuned rich for the first 5 litres of fuel consumption to allow for run in. If the dealer tuned the saw prior to delivery you could try this argument. First I would take it to another dealer and get them to verify that the high speed mixture screw is at least 1 and1/8th turns from seated. If not it was tuned too lean. Hope this helps, regards Phil.
Sep 01, 2011 | Echo CS400 18" Chain Saw
Brand new Echo cs-400 chain saw: The chain spins fast on idle. Should'nt the chain be stationary on idle?
The manual is available here:
http://safemanuals.com/user-guide-instructions-owner-manual/ECHO/CS-400-_E
The idle speed of the negine may be too high.
Page 26 of the manual gives instructions for adjusting the speed with the "T" screw on the carburettor.
May 12, 2011 | Echo CS400 18" Chain Saw
Chainbrake spring broke need new one
Parts Catalogs Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04511001001 - C04511999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04612001001 - C04612999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04713001001 - C04713999999 Language: English
Jan 05, 2011 | Echo CS310 14" Bar Length Fully Assembled...
I would like some advice on how to tune a cs 3400 echo chain saw
Hi, you can't tune these, so if its not running smoothly, check air filter, clean and replace. Check spark plug, clean if necessary and replace. If problem persists it could be dirt in the carbretta, so flush this out with clean fuel, after this, drain fuel tank and replace with fresh fuel, ensure you have the correct mix of fuel.
Hope this helps
Aug 19, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Echo CS-302 chain saw with no instructions (Inherited)
the echo cs302 is equiped with an automatic oiler that lubricates when the engine is running the manual states the unit runs on a 20:1 mixture 89 octane fuel with 6.4 oz of tcw3 oil per gallon
Apr 10, 2009 | Echo Garden
Echo cs-341 stalls out when cutting sideways
Make sure the fuel filter is indeed attached to the fuel line in the tank and pushed down to the bottom of the tank.
Mar 14, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Echo CS600P Gas Chainsaw 20 Inch Logo
659 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
