Question about HP Officejet 4215v All-in-One Printer
How can I fix a paper jam? (and keep it from happening again!)
I'm trying to print on 4x6 photo paper, and the paper fed in and got stuck. I cannot reach it. How do I get it out? And how can I make it feed properly in the future?
My printer shows I have a paper jam, but I have checked everything and there is no jam. What could be wrong????
Posted on Jun 04, 2011
  • 152 Answers
Remove back cover and remove itHow can I fix a paper jam? (and keep it from happe - 6030ce0.jpg
Posted on Mar 29, 2008
Repeat paper jam
there likely a jam in there your not seeing or feeling
Jan 26, 2013 | HiTi P510L Digital Photo Printer w/Breeze...
C5180 sounds like printing then jams
try aligning the heads, and cleaning ink cartridges
Nov 18, 2012 | HP Photosmart C5180 All-In-One InkJet...
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
When I use my Brother MFC-465 CN printer to print 4X6 photos with the photo paper bypass tray in proper position, it jams sending the photo paper through. Printer is set to 4x6; software set to photo as...
Hi there!
The compatibility of the paper may affect the issue that you are having. I have a brother printer also and prints on 4x6 size what i can suggest is to try turn the photo paper upside down, so facing the tray, 2 sheets at the bottom should have the glossy side up. and the sheet where you need to print the photo should be facing down. So when the paper roller grabbed the photo paper at the top it will smoothly pass thru,
Hope this helps! Vikroks
Mar 06, 2011 | Brother MFC-465CN InkJet Printer
Rollers won't pick up photo paper.
Hi I would suggest you to try once again by putting the shiny side up and print it again, some time even if the pages get stick with each other than also the printer wont take paper in. so try one more time and do reply if you still have the same problem or nay other.
Naiven.
May 31, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Paper jam/no paper fed
make sure the photo paper is in glossy side face down,
set the paper type to photo.
If it keeps jamming it's because the paper feed is probably dirty and not taking the paper properly
Mar 24, 2010 | Brother DCP 130C All-In-One InkJet Printer
I can not get the 4x6 paper to feed into the printer during the printing process. the paper shoots through and the printer. screen says the paper is incorrect size. i am using kodak ultra premium photo...
Kindly place the paper in the photo paper tray and then place a photo on the scanner glass of the paper and press copy.Correspondingly,if you are printing from computer make sure that you select 4X6 in the printing properties or preferences while printing the pictures. Your issue will be solved.Keep me posted if you are facing any problems.
Dec 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printing 4x6 photos on photo paper
Sorry but your question seems to be unclear.
Here are the solutions that I see:
- try fixing the orientation of your paper on the printer:
-- go to printer "properties" then select "paper" then set it to
landscape or portrait. You might just have to cut the extra
papers
- try changing the paper size on the printer "properties" if it has
no 4x6 then choose "custom size"
Jan 19, 2009 | Samsung CLP 300 Laser Printer
Hp photosmart d7160
hp photosmart d7160
how can i print 4x6 photo paper ? it says load paper in the main tray its only printing with large plain paper , even if its set to photo tray , and if i put the 4x6 in the main tray it says wrong paper zize ...
Nov 10, 2007 | HP Photosmart D7160 InkJet Printer
HP Officejet 4215v All-in-One Printer Logo
113 people viewed this question
Ben Johnson
