Question about Siemens 24 in. SL84A305UC Built-in Dishwasher
We have a Siemens SL84A305UC Dishwasher and it just keeps running and running. Someone suggested that it may be the control panel. Does anyone have any other suggestions or experience? Thanks!
  • Siemens Master
  • 2,605 Answers
Hello and welcome to Fixya. The assesment of the control is likely accurate. Siemen is made by B/S/H/ ( bosch/ thermador/ siemen/ gaggenau) and there is plenty of president for this issue. Likely if you select just a rinse cycle it will complete fine since the rinse cycle doesn't call for heat from the element/control. sooo... Based on your description I'd say the issue IS indeed with the control. As I said B/S/H/ has had a history of this exact problem I'm about to lay out for you and this is the first thing I'd be looking for if called out to service the unit with the symptoms you've described. ( unless you requested a resolder option...see below re: my opinion on this ) I digress, As I've alluded to the issue is within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). My first suggestion would be calling in an authorized bosch/siemen servicer if that is an option for you and your budget however, If you cannot afford that option or simply feel you want to attempt and are capable of checking this on your own, there`s a way to visually inspect the control yourself. It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s and takes forever to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed. **My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...half assed will not last, although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)** **Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Siemen/Gaggenau, to service your machine.** Hope this answer`s your question, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness. Good luck. macmarkus :)
Posted on May 08, 2010
  • wynnef Dec 21, 2010
    I have the same problem but I have a SL84A315VC/30
Siemens dishwasher- start button is flashing but will not start. some water in bottom of dishwasher.
Did you try turning off the circuit breaker to it, waiting about 15 minutes and turning it back on?
If that doesn't do it, I would start by checking your drain pump.
Oct 24, 2014 | Siemens 24 in. SL84A305UC Built-in...
The water doesn't pass thought the first solenoid to get into the dishwasher? How can I fix it?
Far as I know, the solenoid is 110 volts.
If you will find a tester and check the leads, you should read 110 volts as soon as the machine control knob is turned to "run".
If not, advance it a click or two, and test it again.
If you have no volts, you likely have a bad control, not sending the signal.
If you have 110 volts, you'll likely need a new solenoid.
Be blessed.
Feb 22, 2013 | Siemens 24 in. SL84A305UC Built-in...
Wont drain after it runs. Has standing water in it
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
May 18, 2011 | Siemens 24 in. SL84A305UC Built-in...
Siemens lady dishwasher is getting stuck on
I removed the dishwasher and put fill hose on mains pressure. (30 to 45psi or 2 to 3 bar). Working ok now. May be issue with water pressure switch ?
Mar 23, 2010 | Siemens 24 in. SL84A305UC Built-in...
I need a solenoid for a Siemens dishwasher.
Here is a link to the parts listing from Siemams. Is did not see Solenoid on it, but they might call it by a different naem, it is a foreign company... Good luck
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Jan 12, 2009 | Siemens 24 in. SL84A305UC Built-in...
Siemens Model SL84-A - Water will not pump into dishwasher
heres a screen on the inlet to the water solinoid that plugs up with calcium alot of the time. shut off the water and take the bottom panel off the unit and you will see where the solinoid is. take off the water and then take the solinoid out and apart to clean. reassemble and you will be good to go.
Jan 11, 2009 | Siemens 24 in. SL84A305UC Built-in...
Control Panel
See:
http://www.siemens-home.com/pdf/sl84a30xuc_manual.pdf
There is a pic with the buttons in there.
Aug 13, 2008 | Siemens 24 in. SL84A305UC Built-in...
Siemens 24 in. SL84A305UC Built-in Dishwasher Logo
981 people viewed this question
Top Siemens Dishwashers Experts
Paul Bade
shaun taylor
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
