Question about NorStar M7310 Corded Phone
How can I change the number of rings?
I can't seem to get the ringer off of 2 rings to my extension at my phone. Does anyone know the feature I need to change this? I have not been able to find it in the manual, though it seems like it should be a simple answer.
  • SSSSPRO May 20, 2008
    Yes, the phone only rings 2 times before going to voicemail.
    The other solution above does not help my specific problem.
  • 326 Answers
To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 – 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
let me know if thast helps
Posted on May 19, 2008
  • mark hudson May 21, 2008
    found this -
    1. Press the
    Feature button, then 981
    2. Enter your password
    3. From here you can listen to messages, change your greeting, change your
    password, etc.
    you might find something in there
    passwords:
    a. If your company extensions are 2 digits long
    enter "120000"
    b. If your company extensions are 3 digits long enter "1020000"
    c. If your company extensions are 4 digits long enter "10020000"
    Problem Solver:
  • 6 Answers
Not sure what you are asking. Are you saying your phone only rings twice before going to voicemail?
Posted on May 13, 2008
Incoming calls on Line 4 are ringing in personal office and mail line. I want it only to ring on Mail line . Our phone is a Norstar M7310. Thanks Sherrie
Enter Feature **2663444
Search through General Options until you find Ringing options.
Type in the extension number of your personal office.
scroll to line 4 choose turn ringer to off, and rls! Let me know if you need clarification on how to find Ringers in General Options.
May 20, 2011 | NorStar M7310 Corded Phone
I do not know how to turn the ringer on
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Jun 15, 2010 | Lucent PARTNER18 Corded Phone
Want to turn the ringer off unless receiving a transfer.
This feature determines how each outside line or pool assigned to an extension rings. You can specify Immediate Ring, Delayed Ring (telephone rings after a 20-second delay), or No Ring. Delayed Ring is useful for backup coverage on shared lines or pools, such as for secretaries who cover each other’s lines. No Ring is useful for all extensions except 10 when an operator answers all calls, or for telephones with no regular users, such as those in conference rooms. To change the way outside lines or pools ring at an extension:
To change the way outside lines or pools ring at an extension: 1 Press "Feature" , "00", "System Program ", "Central Tel Program" at extension 10 or 11.
2 Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons show the current Line Ringing settings for all lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green light next to that button is off.) The following ringing options can be shown by the green light next to the line or pool button: • Immediate Ring — on steady • Delayed Ring — flashes slowly • No Ring — flutters quickly • Immediate Ring is the factory setting for lines; No Ring is the factory setting for pools.
3 Press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
4 Continue programming, or exit programming mode.
Aug 06, 2009 | AT&T Lucent MLS-12D Phone
How do i turn the ringer off of a phone
Ok, gotca.... no ringing at your set, as the title states.
First you need to know the extension of the phone that you want to change. Feature 0 at the phone and hit the intercom key to ensure that we are programming the right phone.
To get into programming press:
-> FEATURE 2 6 6 3 4 4
-> Password: 2 6 6 3 4 4
Now you will have to look at your LCD for 3 arrows
<- Heading..Enter->
<- Back .......Next->
-> you will now see TERMINALS&SETS and press Enter (the top right arrow key) now put in the extn that you want to change.
-> you should now see the extension number of the set and the name that is associated with it, press Enter (the top right arrow key) again
-> now you will see LINE ACCESS and press Enter (the top right arrow) again then LINE ASSIGNMENT and hit Enter again
-> then you will see Show line:____ and hit Scan the scan button
-> it will show something like L002: Appr&Ring now press CHANGE till it says Unassigned
-> keep hitting Scan till all the lines are found, DO NOT REMOVE ANY NUMBERS ABOVE 145, as these are your target lines for your Direct phone numbers (these numbers above 145 may not be there, but just incase)
-> after you find all the Lines, you now hit RLS to back out of programming.
Voila, your phone will not ring anymore except when you receive a direct call to your set -or- via your direct number if you have one.
Apr 16, 2009 | NorStar Meridian M7310 Phone
3rd line - no ring tone on one of a 3 set phone system
Yes, as you noticed FEATURE *6 only changes the ring tone on the set...
You have to go into system programming to make this change...
-> First you need to know the extension on the set, you can find this by doing FEATURE *0 and press the Intercom button.
-> Get into programming and you'll see TERMINALS&SETS and enter
-> type in extension that is giving you problems
-> hit next till you see LINE ACCESS and enter
-> the you'll see LINE ASSIGNMENT and enter
-> type in the line 003
-> and press change to APPR&RING
-> hit next and RLS to back out of programming
Mar 04, 2009 | NorStar Meridian M7310 Phone
Prostar 816 need to turn ringer on
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
hope that helps
Jan 30, 2009 | Samsung Prostar 816 Phone
Ringer
press #when finished. hope that helps
Jan 27, 2009 | Samsung Prostar 816 Phone
I need to silence an extension on the lucent 18d telephone
From ext. 10 or 11, press Feature 00, left intercom (twice), right intercom (once), Dial ext. number of boss' phone. Lights on the line button will indicate ringing state for that line:
Green light - Immediate ring
Fast Flutter Green light - No ring
Slow Flashing Green light - Delayed ring
Press each line key until Fast Flutter Green light appears.
Press Feature 00 to exit programming.
Jan 05, 2009 | Lucent PARTNER18 Corded Phone
Ringer
You may need to change your Ring Volume. Here are some instructions on how to do so.
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
Let me know if this works for you.
Sep 03, 2008 | Nortel T7316E 2-Line Corded Phone
CHANGE THE TIME/DATE AND TURN THE RINGER ON
You have to use the feature 9 # from the administrators phone (usually extension 100)
Go to extension 100, press "feature,9,#" and you'll see the numbers on your display blinking like a digital alarm clock. Enter the time and then press feature to complete.
Oct 11, 2007 | NEC DTU 8D-2 Corded Phone
NorStar M7310 Corded Phone Logo
317 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
