I NEED A WIRING DIAGRAM FOR A 120/240/24V ACME CONTROL TRANSFORMER.IT HAS H1,H3,H2 AND H4 ON ONE SIDE(PRIMARY). SIDE 2 HAS X2,F1,F2 AND X2 (SECONDARY). IT CAME WITH NO INSTRUCTIONS AND I NEED TO HOOK IT UP ON A SWIMMING POOL HEAT PUMP.
  • Brian Niten May 11, 2010
    Is there a label on the side of the transformer that shows the different input & output combinations. And also does it have fuse holders on the transformer.
    Guru:
  • 587 Answers
If you're wiring up 120 volts to the primary then you need to connect H1 and H3 together, then connect H2 and H4 together. Then connect one side of line (120 volts) to H1 and H3 and connect the other side of line (120 volts) to H2 and H4. Then for the 24 volts secondary X1 is one side of your 24 volts and X2 is the other side of your 24 volts.
For 240 volt primary connect H2 and H3 together, Then connect one side of your Primary (240 volts) to H1 and connect the other side of your primary (240 volts to H4. Then your Secondary 24 volts is still X1 and X2.
Posted on May 11, 2010
ASKO TL751 error messages ?
Asko dryers as model T760 or T780 indicate failure by error message (like "Overflow", "Sensor", "Thermistor", ...) while the model TL751 indicate failure by error code ("H1", "H2", ...)
Below you can see a list of error codes:
H1 error - Humidity sensor error
H2 error - Drying temperature sensor open/short error
H5 error - Heater overheated (ELECTRIC TYPE)
Heater disconnection check and H4/H6 error (ELECTRIC TYPE)
H3 Error - Flame Detector Open Defect (Gas Type)
H7 Error - Gas Valve Defect or Gas Blocked-off (Gas Type)
H8 Error - Igniter Defect or Flame Detector Short (Gas Type)
Dado
Mar 31, 2015 | Asko TL751 Electric Dryer
E-000013-0000
At power-on, the rise in the temperature of the fixing assembly is not high enough. The main thermistor (THM1, THM2, THM3), thermal switch (TP1, TP2, TP3), or heater (H1, H2, H3, H4) has an open circuit or poor contact. The AC drive PCB or the DC controller PCB is faulty.
The temperature reaches 110 deg C, but does not reach 140 deg C within 300 sec. Remedy Check for an open circuit and poor contact in the main thermistor, thermal switch, and heater; then, reset in service mode: COPIER>FUNCTION>CLEAR>ERR.
Dec 09, 2014 | Canon ImageRunner 5050N Digital Copier
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
I am unable to set handset to work with the base. Its panasonic KX-TG5933Al
Registering a handset
Important:
If you accidentally assign another
handset's extension number to the base
unit, the originally assigned handset
stops functioning. Confirm the extension
number of the handset by placing it on
the base unit or charger. Lift the handset
from the charger before registering.
1 Handset:
{MENU} i {0}{0}
2 Base unit:
Press {SELECT} until the desired
extension number (H1, H2, H3, or
H4) is displayed on the base unit, then
press and hold {CALL} until the
CHARGE indicator flashes.
LH4 can be used if you have 4
handsets.
LAfter the CHARGE indicator starts
flashing, the rest of the procedure
must be completed within 1 minute.
3 Handset:
Press {OK}, then wait until the handset
beeps.
For futher information, see the phone manual at: http://dl.owneriq.net/3/3cd5d5a0-865d-4a28-8a1f-91f144108d9d.pdf
Mar 22, 2011 | Panasonic Computers & Internet
The codes on my Armana furnance is saying I have a open primary. How can I fix this?
If you have an open primary wire, this means the transformer, or one of the Hot wires coming into the unit may be tripped. Check your breakers to see. If it is the transformer at the furnace, the primary side is the 120 volt side of the transformer. The 24 volt side will be dead due to this, as it is the secondary side. If you find you have power going to the indoor unit, but nothing is working, you will need to replace the control transformer. It is 120 Volts primary side X 24 volts on the secondary side. They only cost about $20.00 and are easy to change out. Primary side you will have a blk and wht wire. You may have several wires on the other side, but it will tell you in the directions which 2 wires to use to get 24 volts, very east to do. Look on the diagram and it will show you where the transformer is at the start of the run on the furnace. Again, it may be a blown fuse if you have a fuse box, or a tripped breaker. It will be the incoming side, that is the primary. Please rate me on my help to you.
Shastalaker7
A/C, & Heating Contractor.
PS, If you need my help contact me.
Feb 17, 2011 | Amana Heating & Cooling
One of the knobs will not turn at all in either direction. How can I get it to turn?
The picture shows a drop in glass cook top (electric) You have to pull the top, disassemble it from the bottom and replace the switch. Most switches have five wires on them L1 L2 which are your hot 240v, h1 h2 which go to the burner(dual burner switch has h3 h4), and p is the pilot. Terminals are marked, just change one wire as you go or mark the wires as you change the part. Make sure your house breaker is off, no power to unit when working on it . Be careful of the glass top when working on it
Feb 24, 2010 | Jenn-Air JED8430 Electric Cooktop
Trying to wire up a single phase transfomer, 480 step down to 208
TAKE ONE OF YOUR 480VOLT WIRES AND TIE IT WITH (H1) TAKE THE OTHER 480VOLT WIRE AND TIE IT TO (H4) NEXT TAKE TRANSFORMER WIRES (H2) &(H3) AND TIE THEM TOGETHER THAT WILL TAKE CARE OF THE HIGH VOLTAGE SIDE, NEXT WITH YOUR 208V- TAKE ONE OF THEM AND TIE IT TO (X1) TAKE THE LAST ONE AND TIE IT TO (X4). LAST TIE (X2) AND (X3) TOGETHER THEN YOU WILL HAVE IT. -LANCE
Oct 16, 2009 | Acme 1000-Watt Transformer with Dual...
H4-01
Dear sir h4 signal is fuser unite please you call a technician and solve your problem
Aug 12, 2009 | Sharp AR-507 Copier
Heating & Cooling Logo
312 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
