Question about Pentax K10D Body Only Digital Camera
My camera doesn't shoot anymore.
My Pentax K10 doesn't shoot anymore. It sounds like obstructed when i push the button. All the other parts are working as usual. There was any knock on the body. I took some pictures on the beach and it happened on the last shot.
Could anyone help me?
I don't know if this is gonna cost me more than buy a new one.
Thanks.
  • 4 Answers
Photo's on the beach, camera obstructed? Could it be you got sand in your camera? Didyou change your lens while on (or near to) the beach? Sand in your shutter can obstruct the shutter in that case the camera has to be cleanded i don't know what the costs are for a cleaning of the body.
Posted on May 08, 2010
I have a trouble with my digital camera. When I put a lens on the camera I cannot get the shutter to open. I am using some older lens that I had for my manual pentax. Could this be the problem. When I have...
Hi Noodle
One of Pentax's strengths is that that you can use lenses from the late 1960s on them (via an adaptor). However, I'm assuming that you have a bayonet fitting lens - but as you say 'my manual pentax' could it be that they are not autofocus lenses?
If autofocus is switched on and you have a manual focus lens, you have to have something in focus in order for the shutter to fire. (with no lens fitted it doesn't seem to matter). Switch the camera to manual focus (where you can shoot out-of-focus stuff) and see if the problem is still there.
If it is then it spounds as though there is something amiss with the camera to lens coupling.
Jul 07, 2011 | Pentax *ist DL Digital Camera
I snap a shot on my Pentax zx-7 and the flash will go off but the film doesn't advance, the number on the roll indicator stays that same, and there are no negative being transferred onto the film...
Hi I need more information. After pushing release button, you will hear motor running sound---like mirror goes up and down and takeup spool running sound. I want to try more. First remove lens and set M mode. Push release button. You will see mirror up/down and motor running sound. If you can see these thing, then you have defective camera. Let me know more detail. thanks and best regard!
May 25, 2011 | Cameras
My Pentax K10D shoots the mirror at pushing any control/knob/button. But there are no photos taken. Photos were fine until the cmera started to shoot several time I took a shot. Shortly it went worse and...
Honestly I have never heard of this one. Most likely you shorted the board inside the camera. Was it ever exposed to water? You may need to send in for repair. Check instruction manual and see if you can do a factory restore. If that doesnt work contact tech support.
Feb 01, 2018 | Pentax K10D Body Only Digital Camera
Pentax k10 black pictures
Your shutted syncronization is not set right. Set it for automatic and see if that fixes your problem.
Dec 30, 2008 | Pentax K100D Digital Camera
Flash doesn't fire
Should fire from test button. If not flash tube is blown.
Jul 08, 2017 | Digital Concepts 952AF for Pentax Flash
How to set timer on pentax k10
The manual for the K10 is available at
http://www.pentaximaging.com/files/product/K10D_Manual.pdf
pp.77-79 details operation of the self-timer.
Basically, use the "Fn" button to bring up the menu. Press up on the four-way controller to select Drive Mode. Then you have two self-timer options. The first sets up a 12-second delay. The second is a 2-second delay.
Unfortunately, the manual offers no other method for setting a self-timer time.
If you are talking about date and time, that starts on p.56 in the manual. Basically, enter the menu system in Playback mode, choose Set-up, choose Custom setting, then select the Date setup option. There are a series of options there for formatting and setting the day, month, year, hour, and minutes.
Sep 30, 2008 | Pentax Cameras
Can't take pictures.
Guest,
pentax codes are in repair manuals, not instruction manuals. H3 indicates shutter failure. this means anything from the flex circuit on the zoom barrel ( inside ) to the shutter itself. camera needs repaired.
Aug 18, 2008 | Pentax IQZoom 200 35mm Point and Shoot...
How can I rewind film in a Pentax Zoom 60-X camera
I used to use point and shoot film cameras. My guess is that there is a button underneath which when you depress will automatically rewind the film. Sometimes the button is very small that you may need a ballpen point to press it. Hope this helps cuz i have no idea what the Pentax Zoom looks like. I am guess it is a point an shoot type and not an SLR. If it is a point and shoot type, you must be sure the battery has power or else it won't rewind.
Jul 18, 2008 | Pentax Cameras
Firmware Update
save the firmware file on your sd card, then you have to find the menu in your camera, to load it in camera memory, make sure your battery is fully charged or it will not work.
Mar 23, 2008 | Pentax Optio S Digital Camera
Pentax K10D Body Only Digital Camera Logo
154 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
