Question about HP Photosmart 2710 All-In-One InkJet Printer
Paper mismatch when recieving a fax - HP Photosmart 2710 All-In-One InkJet Printer
  • Anonymous Mar 18, 2009
    I have the same problem and have selected plain as the paper type and letter as the size, but the printer still says paper mismatch for incoming faxes. Any help?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
I understand that while receving faxes, you are experiencing with paper mismatch error message.
Please select the paper type as plain paper fromt the front panel of the All-in-One and try to recevie faxes.
Posted on Jul 27, 2008
We are not receiving faxes..we keep getting error code 407..Please help? Thank you.
The message means:
407 No confirmation from the receiving station for the
previous page sent.
Wait a few minutes and send again.
This can mean 2 things
1) you have not set your fax machine to recieve faxes
2) you need to have your fax machine serviced because the part that makes it pickup a fax has malfuctioned
Clean all paper paths with paper path cleaner.
Unplug and then after 10 seconds replug the fax machine and do a test recieve for it
If all else fails, you may need to call a service person to repair or replace the broken or defective part that recieves faxes.
Hope this helps :)
Mar 16, 2010 | Panasonic Panafax UF-890 Plain Paper Laser...
PAPER JAMS ALMOST EVERY TIME WE RECIEVE A FAX OR RUN A COPY
Load the paper with curled side facing away from you. Hold the paper from at the top with 2 fingers. the paper should be away from you. Important also is to remove all of the remaining paper. then add addtional paper before putting back into paper set.
Jan 07, 2010 | Brother IntelliFax-4100e Fax
All of a sudden, faxes stop coming out and the window says something to the effect...''Place US Paper in Upper Tray''. If I turn the machine on and off, the display clears and faxes that are in memory...
The fax machine is trying to print fax recieved copies on the bypass feeder.
Check up the setup menu on the control console.
Fine fax recieve.
You should find a selection for fax recieved in which paper tray.
Check this area, any that have the bypass feeder, de-select it.
Make selections for 8 1/2 x 11 paper in tray one.
May 01, 2009 | Xerox FaxCentre F116 Plain Paper Laser
When we recieve Fax, the paper is very dark
We had the same problem and we switched out the drum and now the faxes are very clear except for a solid black line going down the right side of the paper.
Mar 14, 2009 | Brother IntelliFAX 2800 Laser Fax
Machine refuses to print incoming fax. "Paper mismatch"
HP Printer 7210 or 7310 Gives Error receving faxes Load a new blank paper on paper tray.
Press * and # simultaneously, and then release both buttons.
Press 1 , 2 ,and then 3 . The Service menu appears.
Press the right arrow button (>) until the System Configuration menu appears then press OK.
Press > until Media Sense Calibration or Calibrate Spot Sensor appear and then press OK. The unit should pick the paper and eject it.
Press the Cancel button until date and hour appear on display
Mar 05, 2009 | HP Officejet 7210 All-In-One InkJet...
MFC -9420 CN Printer/Fax Scanner
I've seen this before...
The machine is calling for legal sized paper and it thinks it has it in the paper tray. Check the back stop that is inside the paper tray. It should be a green guide that is closest to you if you pull the tray out. You may have to lift up a flap on the end. Make sure that the paper stop is on the correct paper size for what is in the tray. Hope this helps. Let me know if you need any more assistance.
If this helps you please rate it as Fixya!
Nov 25, 2008 | Brother MFC-9420CN All-In-One Laser...
Paper Mismatch
Dig through the menus on the printer and make sure the paper type for the tray in question is set to plain. Sounds like someone set it to transperency and forgot to change it back.
Aug 29, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Check paper reload paper
Remove the paper tray completely and make sure paper is not binding and lifting up OK.
Jun 30, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Incoming fax problem
DON'T KNOW IF THIS WILL HELP-BUT MY PROBLEM WAS SIMILAR--MINE WAS SAYING PAPER TOO NARROW WHEN I WAS TRYING TO PRINT AND COPY. I JUST KEPT MOVING THE FRONT SLIDER AND THE LEFT HAND SIDE SLIDERS BACK AND FORTH AND TOOK THE PAPER IN AND OUT --TRIED AGAIN AFTER EACH TIME--IT EVENTUALLY FIGURED OUT I DID HAVE THE RIGHT SIZE PAPER--
ALSO TRY---MENU--THEN--COPY SET-UP--THEN PAPER SIZE--SEE IF PAPER SIZE IS SET RIGHT.
Mar 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Photosmart 2710 All-In-One InkJet Printer Logo
1,264 people viewed this question
Seeker5211
Seeker5211
