Question about HP Computers & Internet
I have a laptop which is hp widows vista,compaq 6720s. my little boy went on it and the screen side is has crack and doesn't work. what should i do HOW MUCH DOES IT COST TO FIX IT
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 103 Answers
The replacement panels for the Compaq 6720s range between $85.00 USD and $110.00 USD depending on where you order them from. The replacement is a relatively easy procedure, but I don't recommend it for a first-time novice do-it-yourselfer.
Here are links to some places where you can order the display panel:
http://www.blisscomputers.net/hp-compaq-6720s-laptop-lcd-screen-15-4-wxga-glossy-ccfl.aspx
http://www.screencountry.com/index.php?section=products&model=HP%20COMPAQ%206720S&brand=HP-Compaq
http://www.r3electronics.com/index.php?option=com_virtuemart&Itemid=1&page=shop.product_details&flypage=flypage.tpl&product_id=1147&category_id=38
Now the good news is you can still use your laptop if you have an external monitor. You can use the appropriate "Fn" key combination to switch your display output to the external device. I believe for the Compaq 6720 is the "Fn" key & the "F4" key. Connect the external monitor then power on your machine, Press the Fn and F4 key simultaneously until you get the display showing on the external device.
One more thing, you will need to go set the laptop to not do anything when the lid is closed. You can do this via Start -> Control Panel -> Power Settings. Change the custom power settings for both "A/C" Power and "Battery Power" to "do nothing" when the lid is closed. By doing so, you can close the laptop lid without shutting off the computer. Of course you will need to add an external mouse and keyboard to continue using the computer, but by following these instructions, you can basically use the laptop, even with a damaged screen, pretty much the same way you would use a desktop. The portability is lost, but the function is retained until you can have a new display panel installed.
Hope this helps FixYa! Please take some time to leave some feedback and a testimonial if you found this information helpful.
Posted on May 08, 2010
My bluetooth driver is not working on Compaq 6720s, i have installed driver file sp34842.exe file but it ask only turn on bluetooth , but even i turned on bluetooth it does not install. Please help me
The Vista Business Bluetooth drivers for your notebook should work fine with W7.
Here they are:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=3442832&prodNameId=344283
3&swEnvOID=2096&swLang=13&mode=2&taskId=135&swItem=ob-56755-1
Jun 15, 2011 | HP Compaq 6720s Notebook
My Compaq 6720s sound was initially workin but stopped suddenly, I have restored to it's factory state but no result. OS is windows Vista
So, it worked well-enough for you to re-install Microsoft Vista?
What do you mean by "no result" ?
What happens?
What does not happen?
What do you think should happen?
What error-messages do you get?
Nov 29, 2010 | HP Compaq 6720s Notebook
Hi its HP Compaq 6720s originally vista basic and i upgraded it to vista premium, now after installing i can see width size on screen has been reduced by 1-inch on both side , i do not have any manual keys...
First, right-click on the desktop where there are no icons and choose Display settings, may be in advanced settings, but look for supported screen resolutions.
If you pick one that is not supported, doing nothing when the screen goes wonky will automatically cause it to revert to what it was before you changed it.
One of the settings there should work for your screen.
If none work, go to your device manager and update the drivers for the display.
Nov 06, 2017 | HP Compaq 6720s Notebook
The drivers for this device are not installed(Code 28) for hp compaq 6720s
Hi:
Your problem doesn't state what driver or device isn't working on your HP compaq 6720s, but all drivers for your laptop can be downloaded from www.hp.com for free. click on the support tab, type in your model number and you can download all of them.!
Aug 20, 2010 | HP Compaq 6720s Notebook
Sound is not working on my laptop compaq 6720s
Try downloading the latest audio driver from the Compaq WEB site.
You need to download the audio drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Use this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Dec 31, 2009 | HP Compaq 6720s Notebook
Hp compaq 6720s
Check the display on External monitor, if the external monitor works fine, it could be an issue with the LCD and controller for the system board, better to replace the LCD.
but before that just be in a safer side.
Update graphics driver and new version of BIOS from Hp.com
Jul 06, 2009 | HP Compaq 6720s Notebook
Compaq 6720s - No DVD drive and will not open
Have you replaced this DVDdrive with a working one and does this work if this works you will no that this si a hardware issue. are you using windows vista or windows xp
May 03, 2009 | HP Compaq 6720s Notebook
HP Compaq 6720s Sound problems!!!!
pls. check the internal speaker audio cable is ok or not. and also check the audio cable is connected on the audio section of motherboard.
Feb 16, 2009 | HP Compaq 6720s Notebook
Widows XP
(1) go to Hp.com - load load the necessary Xp drivers for your unit - burn them to cd - then aquire a replacement hdd - install Xp on that - install the required drivers and walla you have one hdd with vista and another with XP
Jan 21, 2009 | HP Compaq 6720s PC Notebook
Computers & Internet Logo
168 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
