Question about E-Machines T1100 PC Desktop
Inputs not working on emachines desktop - E-Machines T1100 PC Desktop
  • jmmayes1 May 10, 2010
    the keyboard, mouse,sound and monitor all quit working after a power surge the other night....everything is connected to the power surge i have disconnected everything and reattached one by one still nothing, even changed power surger the tower turns on and fan runs but no led lights on anything
  • Grand Canyon Tech
    Grand Canyon Tech May 11, 2010
    witch inputs, sound usb,keyboard,mouse please be descriptive of your issue.
  • 4,234 Answers
The fans running confirm the presence of the 12V supply, and the tower turning on suggests that the 3.3V suply is also working. I would suspect that the 5V line has failed or that the filter capacitors on the motherboard have been damaged. Without seeing the actual machine, I cannot know for sure. You can do a visual check of the capacitors. Quite often if there was a voltage surge, the caps will bulge on the tops. These parts are small cylinders on the motherboard.
If you can post a photo of the motherboard, we may be able to make that determination for you.
Dan
Posted on May 10, 2010
  • 3,866 Answers
I would check the power supply, up including the motherboard. you might have a motherboard that has taken a hit.
Thanks
Relocatated an emachine now it says no input signal
Check both ends of your monitor cable to make sure it is plugged in firmly. Also, do you see a power light on the pc?
Apr 17, 2014 | E-Machines eMachines Desktop PC
Emachine 1401 how to connect to samsung hdmi tv
Where you able to complete the following:
1) Aquire HDMI cable
2) Connect HDMI cable to TV and Computer
3) Turn on TV and Computer
4) Set TV input source to HDMI
Nov 09, 2013 | E-Machines eMachines Desktop PC
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
I was wondering if i can use any monitor with an Emachine computer? my friends monitor went out and i want to replace it for her.
I use a regular 17 inch monitor from 10 years ago with my eMachine that came with a 22" flat screen. It's just a matter of connecting to the correct input and output. You do have to install the correct drivers for the monitor you are using unless it uses the Windows Generic drivers but it will work.
Feb 15, 2011 | E-Machines eMachines Desktop PC
Trying restore emachine need full back up discs model 590/790
You can order a set of recovery disks here:
https://secure.tx.acer.com/RCDB/Main.aspx?brand=emachines
They are about $20 plus shipping, and you need to input your machine's serial number to insure you obtain the correct disks.
Hope this helps.
Mar 07, 2010 | E-Machines eMachines Desktop PC
When I turn on my emachine, it reads:
It means your video card is not out putting to your monitor. If it clears up, it is normal. If it continues, check your video card and/or settings.
Oct 13, 2009 | E-Machines eMachines Desktop PC
Gateaway
Please uninstall the sound driver and install the correct driver of your machine to fix all the reccent problems of your system.
You can download the drivers here: http://www.emachines.com/support/product_support.html?cat=Desktops
Please input the necessary data of your system.
It is very important to install all the driver regarding your system for its optimum performance.
Jan 16, 2008 | E-Machines eMachines Refurbished EMA...
E-Machines T1100 PC Desktop Logo
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
