Question about Car Audio & Video
Cd player i just bought a used 1995 saturan i need to know what the key code is
WE HAD TO GO TO A SATURN DEALER (LUJACK,GM) THEY HAD TO RESET THE KEY CODE....BUT EVEN THOUGH IT WAS $15 TOO LATE! I HAPPENED TO FIND MY OWNER'S MANUAL ON EITHER 152 OR 174 (IN THAT AREA) READ INSTRUCTIONS FOR THEFT DETERRANT IT WILL SHOW YOU HOW TO RESET THE KEY CODE (FREE OF CHARGE) WHEN YOU DO USE A NUMBER EASY TO REMEMBER, IF YOU LOST POWER TO THE BATTERY THE CODE WILL HAVE TO BE SET AGAIN SO KEEP YOUR INSTRUCTIONS!!!
Posted on Mar 29, 2008
SOURCE:
I have an Error code 20 on my cd player in my 1995 Cutlass Supreme, i just bought the car and it has no book. help!
CD Errors
· E20 or CHECK CD : Cause(s): The CD player cannot focus on the disc or there is an internal focus problem. Correction(s): Try cleaning the disc or using a new disc. Make sure the disc is loaded correctly. The road could be too rough or there is too much humidity.
If your player is an AC Delco giving you the e20 error and only on your burnt discs the lens is probably not shot. It's just very dirty and can only read professional grade CDs. The remedy is to open the CD player and clean the disc with 70% Isopropyl Alcohol.
You will need a small adjustable wrench or ratchet set as well as a T-7 torx bit. You only need to remove the bottom of the player and the front piece in order to get to the CD player inside. Unscrewing other screws will just lead to having to more to reassemble. Once you get to the heart of the CD player you will need to release it by unscrewing the torx screws and then turning the player over and you will see the lens. Put some alcohol on a q tip and gently rub the lens a few times. then reverse all disassembly and put the player back together.
When you reinstall the CD player it should play all of your CDs
ALSO be sure to disconnect the negative in the battery before removing any electric devices to prevent short circuiting. And only reconnect it after you have reinstalled the CD player.
Jan 22, 2010 | 1995 Oldsmobile Cutlass Supreme
Want to replace factory radio
go to walmart find your cd player, dash kit ,wiring kit and then this is what you do .. remove the old radio attach the wiring harnes you bought to the factory wiring harnes this will allow you to match the color code up for your new radio with out cuting wires then install the new dash kit witch will allow you to install your cd player with a factory look this should be everything ou need to know
Dec 04, 2008 | 1995 Oldsmobile Eighty Eight
Need multi-region capability
Press "Setup"
Scroll to "Preference" using the Left/Right arrow key
Press "138931" and a popup screen will appear
Use the Up arrow key and select 0 for a region free DVD player
Done.
Sep 09, 2008 | Philips Televison & Video
1995 grand prix
do you have a test light?your speaker wires should be four sets of matching color,dark/light blue,dark/light green,dark/light purple and one other matching set of colors. then there should be one black wire which should be ground.with a test light you can find your power and accesory wires. your power wire will always have power with key on or off,the acc wire will only have power when key on. i hope this will help.
Aug 04, 2008 | 1995 Pontiac Grand Prix
Ford key codes for ford 6000 cd player
hi, i am ok now thanks, i got the code from another website.
Jun 25, 2008 | Car Audio & Video
I bought a Kenwood CD player along with my car and I have got it installed and it turns on, I just need to know how to enter the code to where I can start using my CD player. The remote does not seem to be...
no cd player i have ever seen requires a code, but you could try looking on the manufacturers website and looking under the model of your cd player.
May 22, 2008 | Kenwood Car Audio & Video
CODE ???
Unfortunatly you do need a remote to enter codes
If you can borrow one from a friend then this will work for you
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Jan 11, 2008 | Kenwood KDC-MP232 CD Player
Reset security code
i bought a audiobahna3551 cd player at the pawn shop and i need the code for it
Jul 30, 2007 | AudioBahn A3351 CD Player
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
