Question about Whirlpool LSB6200KQ Top Load Washer
Fills with water but will not agitate or spin the water out
    President:
  • 949 Answers
This sounds like a broken coupling, I have put together some instructions on how to repair this, follow the link and let me know if it helps.
http://www.fixya.com/support/r4670549-drive_coupling_replacment
Posted on May 08, 2010
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Fills with water..doesn't wash..drains and spins..does the transmission spin in direction and wash in the other? in other words does the motor run one direction to spin and rev. to agg/
    Yes it does reverse. If the motor is running in agitate pull off the agitator and check the agitator drive (bell) (white plastic bell shaped) on top of the agitate shaft is not stripped. You should not be able to turn. To remove the agitator fill first about 8 in of hot water, drain and pull up on agitator with fingers under the bottom or a belt.
    Nov 22, 2010 | Hotpoint -Ariston VVSR1030HWO Top Load...
    Kenmore series 70 washer will only fill with water.
    I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
    Jun 30, 2009 | Kenmore Washing Machines
    As washer was on final spin cycle it sounded like a belt came....
    • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
    Apr 01, 2009 | Kenmore Washing Machines
    Will fill water but agitator wont run.
    Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
    Hope this helped.Let me know by rating me
    For more help go to live chat.
    lenwest
    Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Washer will fill with water but the agitator won't spin.
    No agitation or spin in any cycle? If so and the machine will drain check the coupler.
    Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
    Old model rca washer machine...will not agitate/wash the clothes,does spin.
    If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
    Sep 29, 2008 | Washing Machines
    Water fill problem
    did you clean the screens in back of water valve? normally a fault code appears if it's a fill issue also the tub will spin at beginning of fill to soak clothes first before beginning to agitate
    Jul 17, 2008 | Whirlpool WTW6600SW Top Load
    Whirlpool LSB6200KQ Top Load Washer Logo
    129 people viewed this question
    Sal De
    Gerry Harvey
    Gerry Harvey
