Question about GE Kitchen Ranges
Model GRML3640ZWW-3 How do you set the clock?
How to set clock on Lacrosse technology model 302-604
try holding the set and min/max buttons at the same time
Feb 10, 2015 | Audio Players & Recorders
Need to know how to set time on ISTA SET 40009
Instructions
    • 1 Press and hold the "Alarm Set" button for five to seven seconds if you have an Insta-Set 40001, 44100 or 44200 model; the year will begin to blink when the clock is ready for adjustment. If you have an Insta-Set 40009 or 40018, hold the "DST" button for five to seven seconds (until the hour begins to blink).
    • 2 Set the year by pressing the right-arrow, "Up" or "+" button, depending on your model of clock.
    • 3 Set the month, day, hour and minute. Press the "Alarm Set" or "DST" button to cycle through each field, and use the "Up," "+" or right-arrow button to adjust the values within each field.
    • 4 Press the "Alarm Set" or "DST" button after setting the date and time to store the information into your clock's memory.
Read more: How to Change the Time on an Equity Insta-Set Clock ' eHow.com http://www.ehow.com/how_5657092_change-time-equity-insta_set-clock.html#ixzz1d1qIibS4
Nov 07, 2011 | Equity Time USA Insta-Set 40009 clock
How to set the digital clock pls
Without your model number this is a GENERIC answer that is applicable to MOST microwave ovens.
1. Press Stop//Pause
2. Press Clock
3. Set Time
4. Press Clock
Time is now set and the Microwave is ready for use.
If this does not work.. I need you to respond with your model number to look up your exact steps.
Thanks for choosing FixYa,
Kelly
Sep 13, 2011 | Microwave Ovens
Need to set clock on oven
Instructions
    • 1
      Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
    • 2
      Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
    • 3
      Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
    • 4
      Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
Mar 19, 2011 | Ovens
I have a clock that will not get correct time. I have no way yo set it . Model #44100 Equity.
All Equity Insta-Set clocks automatically set the correct time and date when you turn on the power. Occasionally, the automatic time-setting feature malfunctions and you must reset the time yourself. Manually changing the time to the correct time on an Equity Insta-Set clock requires the push of only a few buttons to get the clock back on track:
1. Press and hold the "Alarm Set" button for five to seven seconds, the year will begin to blink when the clock is ready for adjustment.
2. Set the year by pressing the right-arrow, "Up" or "+" button, depending on your model of clock
3. Set the month, day, hour and minute. Press the "Alarm Set" button to cycle through each field, and use the "Up," "+" or right-arrow button to adjust the values within each field.
4. Press the "Alarm Set" button after setting the date and time to store the information into your clock's memory.
Best regards,
gylacz
Mar 18, 2011 | Audio Players & Recorders
Setting clock
It depends on the brand and model.
Normally it's a sequence like:
CLOCK > 1 > 2 > 3 > CLOCK
CLOCK > 1 > 2 > 3 > START
CLOCK > CLEAR > 1 > 2 > 3 > CLOCK
CLOCK > CLEAR > 1 > 2 > 3 > START
If not, please post a new inquiry with your correct brand and model.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
May 23, 2010 | Magic Chef MCD1311ST Microwave Oven
Can't set the Clock on microwave
One of these combinations may work:
Otherwise, I would contact the dealer you bought it form to see if they have a number for Cascade.
Dec 05, 2008 | Microwave Ovens
GPX clock radio clock question
I emailed the company and they sent a pdf of the manual back the same day.
partsinfo@dpi-global.com
Jun 06, 2008 | GPX CRCD6306DT Clock Radio
Virgin Pulse model VP-07 CD clock radio
1. To set the clock to leave the unit in standby mode. (Plug in the AC cord to a wall outlet without switching unit on). 2. Press SET button for about five seconds until AM--12:00-- stops flashing. 3. Press down TUNING button to adjust hour, and up TUNING button to adjust minute. 4. Press SET button to confirm time set.
Sep 11, 2007 | Virgin Pulse VP-07 Clock Radio
Kitchen Ranges Logo
83 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
