Question about GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
I have GE Profile PSC25SGSC SS refrigerator. Over
I have GE Profile PSC25SGSC SS refrigerator. Over the last couple months, I've started seeing water of the bottom of the fridge. It appears to be coming from behind the bottom drawer where some tubes pass through the back. Also I am seeing the ice in the icemaker melting and along with food on the top shelf. Temperature indications are at setpoint, but the Freezer is definitely warm. I've cleaned all the coils, but to no improvemnt.
Bogie Boy
  • 46 Answers
SOURCE: I have a GE profile
Might should check the condenser fan in the rear of freezer section. sounds as if it isn't running at its peak performance. May just need replacing. BB
Posted on Dec 16, 2009
  • 4793 Answers
SOURCE: top of refrigerator is warm and bottom freezes
poss answer is drain hole/vent blocked,as unit auto defrosts water/vapour collects at bottom and when unit swiches back on it freezes,poke out drain with thin wire with a small piece of cloth dipped in clorine bleach or blow out with air hose.do not use hot water to manually defrost/ clean drain holes every 6 months
Posted on Feb 09, 2010
  • 2526 Answers
SOURCE: GE Profile PSS26PSTB refrigerator ice melts inside icemaker
when you open the freezer door do you hear the fan blowing,you could have a bad evap fan motor,also if there's ice on the back wall you have a defrost problem,take off the inside back wall of the freezer where the ice is,you need to shut the control off and melt out all the ice,g.e. has had alot of problems with their computer boards which is a very expensive part number WR49X10152 around 200 bucks,look behind the kick plate on the bottom of the fridge and hopefully the tech sheet will be there,it will tell you how to put the machine into defrost,do this first before you melt anything out or before you touch the control,i think you click the lite switches together 5 times to make it go into defrost,it should tell you on the tech sheet,if ithe heater doesn't come on you need to read out the heater with a meter to see if it's good also read out the defrost thermostat,you have to check the thermostat while it's cold if the t-stat warms up you won't be able to check it, you should change out the t-stat anyway so you can cut the wires going to the t-stat,bypass it by connecting the wire directly to the heater and click the lite switches 5 times and the heater should come on,if it does leave the heater on to help you melt it out.so if the fan is running on the freezer side,click the lite switches 5 times and the fan should shut off and then you'll know it's in defrost,the heater should come on ,if the heater and t-stat read good and it won't go into defrost then it 's the board,also you can take out the board in the back of fridge ,unplug it first and look at the board for burn marks on the back or on the soldered spots,the board tells it when to go into defrost and melt the ice off the coil and like i said g.e.has had a lot of problems with the board,if you need any more help let me know,good luck
Posted on Mar 24, 2010
jmgldsmth
  • 1906 Answers
SOURCE: TOP FREEZER REFRIGERATOR WITHOUT ICEMAKER LEAKS
the condensate drain hose is blocked.
remove the plastic rear cover in the freezer; locate the drain opening;
it's about 1/2 inch in diameter; it drains into a pan at the bottom of the refrigerator. using a funnel and, a small pan, pour hot water through the blocked hose until water flows into the drain pan again.
remove the condensate pan pour the water out and, reinstall the pan.
Posted on Jul 02, 2010
heatman101
  • 43501 Answers
SOURCE: gss25xsrd ss GE fridge gets
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 26, 2010
Why is mt GE Profile PSC25sgsc ss not cooling
Most likely the=> Defrost Heater Assembly WR51X10055 and High Limit Thermostat WR50X10069 need to be replaced. Heater is burned out. High Limit Thermostat WR50X10069
Appliance 911 Sea Breeze
Aug 01, 2015 | GE Profile 26.6 cu. ft. Side-by-Side...
My GE side by side refrigerator model PSC25SGSC has a problem. It makes ice fine. But sometime, all the ice cubes melted, along with the food on the top shelf. After I turned the ice maker on and off, it...
Ok this sounds like your mainboard is about to go out, its causing intermittment cooling issues, board runs about $150-200.As long as you dont have any frost buidup in the back of the freezer, if not definitely the board. If you need any further assistance let me know.
Sean
Mar 30, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I have a GE Profile side-by-side Refrig (model PSW26PSSB SS). The freezer does not stay cold. Often my food thaws. I?ve placed a cup of water in the freezer over night and it does not freeze. My ice maker...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 12, 2010 | GE Profile PSW26P Stainless Steel Side by...
Home from vacation--no ice.
Check the fill area of the ice maker for an ice blockage.
- make sure the tube on the back of the Ref. is connected to the white rectangled block of the fill tube.
- check to make sure the water filter in the bottom of the unit was not kicked and has popped out or is not seated / locked in place.
- Check to see if water is actually getting to the unit.. from the 1/4 inch supply line.
If your icemaker is the common one there here is a way to test it:
(I noted GE Profile but not an exact model number)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
Last question... does water in door work?
Thanks for using FixYa.
Kelly
Apr 03, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
I have french door with freezer on the bottom refrigerator in the GE profile line. I have the internal ice cube maker. My ice cubes melt into one big block of ice. I lowered the thermostat to -5 but that...
check ur temperaTure in the freezer make sure it is 5 degrees fahrenheit or lower if it is u might need to see if ur ice maker tray has a crack i it to where when the water goes in to be frozen it runs out a crack and if all this is good check to see when the ice maker fills up its just not running over
Mar 01, 2010 | GE Profile PSW26P Stainless Steel Side by...
Not getting any water out of the dispenser, but its making ice
The water dispenser on my GE profile fridge stopped working for a couple days. The refrigerator and freezer temperatures have fluctuated over the past several months causing fridge items to periodically freeze and freezer items to periodically thaw. GE tech came today identified a bad circuit board, which he replaced for a cool $300. Ouch. Fridge is only three years old. Oh yeah, the icemaker also has a broken tab which causes it to jam every couple weeks. We have GE Profile appliances throughout our kitchen and they all work great except for the fridge :-( I hope GE engineers read this post. If so, get to work! LOL
Feb 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Profile side by side refrigerator,model #GSC23LSRC SS
Have you tried a new GE filter? Use only GE brand. You can purchase a bypass plug from GE parts 800-626-2002
Jun 23, 2008 | GE DBSR453EBWW Electric Dryer
GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
270 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
