Question about Hunter 20537 / 20538 The Vista Iron Ceiling Fan
Have 4 wires coming out of the ceiling 2 black and 2 white
Only have three wires from the ceiling fan 1 black,1white and 1 black/white. How I do I hook it up.
    Guru:
  • 351 Answers
I have to assume a bit here. If you have 2 black and 2 white in the ceiling, then the proper way to connect would be . the white that is the run from the panel, the powedr white connects to the fan white ... the power black connects to the other white wire (put some black tape on that white wire) and the other black connects to the fan black .. if you hacve a meter you can test the wires and see which pair has the 120 volt power.
Please vote !!
Posted on May 12, 2010
Hunter ceiling fan/light unit install with 3 pole switches. there are 2 white, 2 black and one orange wires coming out of the electrical box. How do i handle the installation?
Not understanding, three pole switch is a wrong switch, wires in the ceiling or wall electric box.
Needed: What switch is existing and what wires are in the switch box and runs or groups in each run coming in as wire groups. Same for ceiling box, colors and wires in each run coming in.
Basically, remove the existing ceiling fixture and connect the ceiling fan replacing the fixture to the same wires the fixture was connected to. White to white, green or bare to green or bare, colored wire to fan's blue and black. Wired like this one switch controls both fan and light, on and off at same time. Use fan pull chain switch for individual fan or light control.
Oct 22, 2017 | Hunter Dryers
Just installed a new Hampton Bay 36" ceiling fan.
I suggtes recheck your wires, could use this wiring guide (click image for zoom)... support/t9590572-hunter_fan
Jun 29, 2011 | Hampton Bay 24002 Ceiling Fan
I have a used ceiling fan that I want to install. I see only three wires coming out of the top; a black, a white, and a blue. The fixture has the fan and 4 lights attached. Can you tell me how to...
Black is the hot wire, white is the neutral, and blue is the hot wire for the lights. If you only have a black, white and green(ground) coming from the electric box in the ceiling, you will have to wire the blue and black together coming from the fan and connect them both to the black coming from the box. The white will connect to the white coming from the box in the ceiling. You should have a ground wire off of the fan. If not look for a ground screw on the fan down rod. The ground is for safety.
Apr 08, 2011 | Heating & Cooling
Need diagram for hunter fan with light kit. Three
Black to black. from fan
Blue to Black and white. from fan
White to white. from fan
The input is from ceiling supply
the black wire from fan is for motor.
the black and white is for the light.
Jan 02, 2010 | Hunter 52" Ceiling Fan With Light And...
Wiring a ceiling fan w/light
To add to red54's comments:
This is what I believe you have:
- one source in the ceiling box (black & white)
- one donwline circuit in ceiling box going to another wall/ceiling box (black&white)
- on switch wire in ceiling box coming from your wall switch (black & white) -- this is the white wire which will be hot when the switch is truned on
Here's how it should be connected:
- all 3 blacks in ceiling box connected together -- no other wires in this bundle
- white wire (which is hot when switched) coming from switch connects to the black/blackwhite fan wires
- connect all reamining white wires together in bundle
- connect all ground wires together
It's that simple. Trick is figuring out, of the three cables in the ceiling box, which is source, which is downline, which is switch.
Maybe red54's procedure can help you figure that out.
May 09, 2009 | Hunter 22890 52'' Low Profile Plus Antique...
Ceiling fan and light wiring, 2 switches, 1 romexHunt
If you have only one black and one white in the ceiling to connect the fan / light to , then you have only one switch for this ceiling box. The fan / light will connect the white wires together and then the two colored wires on the fan to the black ceiling wire. In order to use separate switches for the fan and the lighht a 4 wire cable must go from the switches to the light so you have a red and black wire to switch the two separately .
Oct 30, 2008 | Hunter Vaulted Ceiling Mount - Antique...
Installing a universal remote on a ceiling fan.
your remote modual should have two or three wires coming from the unit on one side to go to the fixture and three on the other to hook it to power , the three should be to connect to the black (power), the white (Neutral) and green (ground), now the unit has power. The two or three coming from the other side should be a white and two other colors or two the same , black, red, or blue, The white connects to the fan white and the other two go to, one the fan and two the light. Any questions E-mail me...hwyhmmr hotmail
Oct 22, 2008 | Hunter 52" Ceiling Fan With Light And...
Ceiling Fan Electric
hi,
you may have two dedicated ceiling fan circuits coming out of that box, check to make sure theres not a black wire bunched up in the ceiling or cut off, or try this
1.white to white wires, and black wire and black with a white stripe to red wire out of ceiling for fan and light together operation
2. If you can find the black and the red and the white coming out of the ceiling then you may have two switches on the wall for that fan, red for black fan wire, black with white stripe for the to black out of the ceiling , white all together. try that combination
for separate light and fan control from the wall
good luck, and be careful
J
Aug 06, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Aug 17, 2007 | Hampton Bay 04383 Calibre Ceiling Fan
Hunter 20537 / 20538 The Vista Iron Ceiling Fan Logo
241 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
