Question about HP DeskJet 722c InkJet Printer
Connect printer Want to print from XP or 2000 (with 98SE partition). Am using USB parallel converter cable. Would a Y USB cable work instead of switch? Have only XP connected now. Printer works fine. Thanks.
I can't get my printer to work
Posted on Apr 25, 2008
XP and Win2000 are the same NT platform and are different from Win98SE and if you have the correct drivers installed for each then a single USB cable is sufficient as long as the printer is pointed to that port/device.
Posted on Apr 07, 2008
I have an old serial printer that works fine, I can not connect it to my new computer via a parallel to usb cable convertor on windows 7!
Hi craig931, First try downloading the latest driver of your printer and your usb converter compatible for windows 7. Second Checked your device manager if your printer and usb to parallel driver properly installed, it should be there. If not yet installed try using different usb port one at a time until the cable have been detected. Third if you see already the printer port force to change it to USB001 or Com1, then try to print. regards,
Sep 26, 2011 | Office Equipment & Supplies
My new computer does not have a parallel printer port. My old 840C printer has both parallel and USB ports, though I only ever used it with a parallel cable, so I tried connecting with a USB cable. The...
Hello and welcome draepeacock !
The only solution is a workaround :
If you have the W XP install disc , you can install a virtual version of W XP on your machine from http://www.vmware.com/products/player/
If you still have the install disc , you can also partition your primary and install W XP on the new partition from http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html.Back up your data first.
Both are easy and safe , no specific knowledge required .
Regards .
Feb 14, 2011 | HP DeskJet 840c InkJet Printer
I have an HP LaserJet printer 4050N with RJ45 and Parallel Port. The Printer is kind of far from the WireLess router and I can't connect it. Unfortunately, my PC doesn't have a parallel port. The best...
Another option is to find an old laptop, with "wireless" capabilities and a Parallel Port.
Connect the printer to the laptop.
Connect the laptop to your wireless network.
Tell the laptop to "share" the printer.
Then, any computer on your network can "find" the networked printer, and can print to it.
Jun 12, 2010 | HP LaserJet 4050 Printer
12 year old notebook - need to connect a printer
Yes you can use any Printer
use it through Parallel port....
you get the converter cable for USB to Parallel port
printers don't need high config....
regards
Apr 30, 2010 | Computers & Internet
It is possible to convert the cable of lq-2180 from parallel to sb cable?
No!
Are you trying to connect your printer to a PC using the USB port?
If so, it would be far better to purchase a USB to Parallel port cable.
The data passing over the USB cable will have to converted from a serial format to a parallel format before the printed can store the data,
Next, the converted has to add the required control signals in order for the printer to read and latch the data.
Don
Apr 18, 2010 | Epson LQ-2180 Matrix Printer
Printer doesn't work when use usb parallel converter.
Forget about using parallel converter. Just use the USB cable it works best anyway.
Easiest way is this.
1: Turn printer on. (Green light. ready to print)
2: DISCONNECT the usb cable from the PC.
3 DELETE the Zebra LP2844 & Zdesigner drivers from the printers & Faxes folder. Just highlight them and hit the delet key. Don't worry Iknow what I'm doing.
4: Plug in your USB cable back into PC.
Just sit back and wait, your PC will automatically detect your printer and re-load your driver software.
Send me the cheque now!!
May 12, 2009 | Zebra LP 2844 Thermal Printer
Connect Kyocera Mita FS-1010 to Macbook (OS X 10.5)
in FS1010 printer usb port avilable u can connect the printer through usb port .
please delet ur printer driver and reconfigure it . use a usb cable to connect the printer it will work.one more u can put ur printer in network
Dec 23, 2008 | Kyocera Mita FS 1010 Laser Printer
Compatibility of parallel and usb
I have Canon LBP-800 laser printer with parallel prot and have computer with USB port.
I connect my LBP-800 printer with Parallel and USB Converter but printer is not functioning. I am using Windows XP.
Please solve the problem in details.
Thanks
ishaq
Dec 23, 2008 | Canon LBP 800 Laser Printer
Connecting Epson TM U220D printer with Laptop (having Windows XP)
Please verify if you properly install the port converter, its drivers.
Aug 31, 2008 | Epson TM-U220 Matrix Printer
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
HP DeskJet 722c InkJet Printer Logo
106 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
