Question about M&S Systems FX-3000 Bagged Central System Vacuum
M&S FX 2000 vacum shuts off
After 3 to 5 minutes vacum shuts down have to hit reset button in order to get it to run again
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
Overheat light comes on vacume will not run
Let it sit for 30 minutes before trying to use again. Make sure the bag is not full and check to see if filter is clogged.
Oct 27, 2013 | Electrolux UltraLux 2000 Bagged Canister...
Oreck vaccum cleaner runs about 4 or 5 minutes then shuts down.
this means you have a blockage somewhere on the vac
Feb 17, 2013 | Oreck Vacuums
Dirt devil doesn[t hold charge
Try running the battery all the way down by letting the vacume run in a corner or another room and even when it stops leave it on for a hour to drain the battery. Then shut the switch off and try charging the battery. Make sure the charger is putting out enough volts by looking at the rated output of the charger and while it is plugged in check it with a volt meter. If it does not hold a charge and the charger is putting out the right voltage you need to purchase a new battery for the vacume
Mar 18, 2011 | Dirt Devil Easy Lite Quick Vacuum
I can not get alarm to work on Constant elite colour change LCD alarm clock
Underneath clock there is 4 buttons, 2 of which are marked (m) & (s) and the other 2 buttons marked with arrows for (up) & (down). depending if you have the clock, alarm or date showing press down on the (s) button for about 3 seconds and the hour digit will start flashing, use the (up) & (down) arrows to set your hour. Then press the (s) button again just briefly and the minute digit will flash and use arrow (up) & (down) buttons to set this also. Press the (s) button again and all will stop flashing and Alarm or Time or Date will be set. Hope this helps as i had same problem but figured it all out in about 2 minutes as i couldn't find my manual lol,.
Jan 27, 2011 | Vacuums
Where EXACTLY is the reset button on DC07? I am not an idiot, but I cannot find this button anywhere!
This model doesn't have a reset switch. When it shuts off due to overheating, the vacuum needs to be switched off and allowed to cool down for at least 30 minutes before using again.
Overheating is generally caused by blockages in the airflow system, and should be checked while it's shut down. A downloadable owner's manual can be found on the following site.
http://ubermanuals.com/product/dyson-dc07-1870
Jan 02, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a Simplicity model 6970 upright vacuum. It picks up great and there is no smell but it will over heat in about ten minutes and shut down. There are no clogs. Once cool, I hit the thermal reset on...
It could be electrical on the inside of the vaccum or your belt is the wrong size therefore making it over heat. Hope this helps?!
Please rate and comment - Thank You
Sep 23, 2010 | Vacuums
My Hoover runs for a few minutes and shuts off.
It's possible the thermal reset is defective. It shuts the motor off if it gets hot. Remove the bag door and take the bag off, remove both filters and then turn the vacuum on, just leave it sit there with the motor running. This eliminates the bag or filters causing any airflow resistance. If it still shuts off after a few minutes it's likely the thermal reset is bad. Some vacuums have an external thermal reset button which can be replaced if necessary but on your model it is built into the motor and you must replace the motor. If the motor runs fine put the bag and the filter under the bag back in - (make sure the filter is clean and not restricting airflow) put the bag cover on then turn it on again. If it overheats and shuts off then you may have a clog on there somewhere restricting the airflow. If so check the power nozzle area, the hose coming from the power nozzle, the extension hose and wands for clogs or restrictions.
Sep 22, 2017 | Hoover U6426-900 Bagged Upright Vacuum
I can't get the vacume to run for more than 15 minutes before it shuts down presumably do to overload. But I don't get the warning light and I clean it out regularly. I have to let it sit for hours until...
Sounds like you have a blockage. Check your attachment hose by dropping something through it, if it is all clear, then check your duct hose, this is the hose at the base of the cleaner. Many times this will clog and you might have suctionat your hose, but if there is a clog here, it will shut off due to no airflow to the motor which causes the cleaner to overheat and shut off with the thermostat. Hope this info was what fixesya! Thanks, Let me know, please! Rene(the VAcuum Doctor)
Nov 11, 2009 | Vacuums
Electrolux Oxygen 3 model 7020A contols not working
You need to replace the hose itself. The buttons in the handle a very cheap and go bad all the time.
Aug 17, 2009 | Vacuums
Vacume overheats and shuts down I replaced the motor.When it cools down it runs again.
The filters had to be cleaned out with air.
I replaced the motor for nothing.There are two filters and the cannister give them good cleanings with an air gun.
Jun 03, 2009 | Kenmore Vacuums
M&S Systems FX-3000 Bagged Central System Vacuum Logo
59 people viewed this question
Top M&S Systems Vacuums Experts
JoeVacs
Are you a M&S Systems Vacuum Expert? Answer questions, earn points and help others
