Question about Whirlpool GH4155XPS Microwave Oven
Need a wire diagram to re connect the main control panel i.e. microcomputer. Old one was damaged by power surge. Ordered a new part but know I don't have a manual that shows me the wiring sequence.
    President:
  • 949 Answers
Here is a link to the wiring diagram.
wiring/Tech%20Sheet%20-%208205611.pdf
Posted on May 08, 2010
Model "KOT-152UW" The
well inside the unit check for any burn fuses on the power supply area, and into the control board. fuse basically the one will tripped if power surged occurred..
Jun 27, 2008 | Microwave Ovens
Tip
Troubleshooting Guide
  • Problem: Totally dead oven.
    Possible causes:
    1. No power to outlet (blown fuse or tripped breaker or GFCI).
    2. Blown main fuse - likely due to other problems.
    3. Open thermal protector or thermal fuse.
    4. Defective controller or its power supply.
    5. Clock needs to be set before other functions will operate (some models).
  • Problem: Totally dead oven after repair.
    Possible causes:
    1. Cabinet screws replaced in incorrect location (safety interlock not engaged).
    2. Any number of screwups. :)
  • Problem: No response to any buttons on touchpad.
    Possible causes:
    1. Door is not closed (some models).
    2. You waited to long (open and close door to wake it up).
    3. Controller is confused (pull plug for a minute or two to reset).
    4. Defective interlock switches.
    5. Faulty controller or its power supply.
    6. Touchpad or controller board contaminated by overenthusiastic cleaning.
    7. Defective/damaged touchpad.
  • Problem: Oven runs when door is still open.
    Possible causes:
    1. Damaged interlock assembly.
    2. Cooling fans (only) running due to bad sensor or still warm.
  • Problem: Oven starts on its own as soon as door is closed.
    Possible causes:
    1. Defective triac or relay.
    2. Controller is confused (pull plug for a minute or two to reset).
    3. Defective controller or its power supply.
    4. Touchpad or controller board contaminated by overenthusiastic cleaning.
    5. Defective/damaged touchpad.
  • Problem: Oven works but display is blank.
    Possible causes:
    1. Defective controller or its power supply.
    2. Broken display panel.
    3. Oven needs to be reset (pull plug for a minute or two to reset).
  • Problem: Whacked out controller or incorrect operation.
    Possible causes:
    1. Previous or multipart cook cycle not complete.
    6. Defective sensor (particulalry covection/mirowave combos).
  • Problem: Erratic behavior.
    Possible causes:
    2. Bad connections in controller or microwave generator.
    3. Faulty relay - primary (or HV side, much less commonly used).
    5. Bad contacts/connections on mechanical timers. Intermittent fuse.
    6. Power surge at start of cook cycle confusing controller.
    7. Microwave (RF) leakage into electronics bay.
  • Problem: Some keys on the touchpad do not function or perform the wrong action.
    Possible causes:
    1. Touchpad or controller board contaminated by overenthusiastic cleaning.
    2. Defective/damaged touchpad.
    4. Faulty controller.
  • Problem: Microwave oven does not respond to START button.
    Possible causes:
    1. Defective START button.
    2. Faulty interlock switches.
    3. Door is not securely closed.
    5. You waited too long - open and close door to wake it up!
  • Problem: No heat but otherwise normal operation.
    Possible causes:
    1. Blown fuse in HV transformer primary circuit or HV fuse (if used).
    2. Bad connections (particularly to magnetron filament).
    4. Open HV capacitor, HV diode, HV transformer, or magnetron filament.
    5. Shorted HV diode, HV capacitor (will blow a fuse), or magnetron.
    6. Defective HV relay (not commonly used).
  • Problem: Timer and light work but no heat, cooling fan, or turntable rotation.
    Possible causes:
    1. Defective (lower) door interlock switch or door not closing fully.
    2. Faulty relay or triac.
  • Problem: Fuse blows when closing or opening door:
    Possible causes:
    1. Defective door interlock switch(s).
    2. Interlock switch knocked out of position.
    3. Misaligned door.
  • Problem: Loud hum and/or burning smell when attempting to cook.
    Possible causes:
    1. Shorted HV diode, magnetron.
    2. Burnt carbonized food in or above oven chamber.
    3. Shorted winding in HV transformer.
    4. Frayed insulation on HV wiring.
  • Problem: Arcing in or above oven chamber.
    Possible causes:
    1. Burnt carbonized food deposits.
    2. Exposed sharp metal edges.
  • Problem: Fuse blows when initiating cook cycle.
    Possible causes:
    1. Defective interlock switches or misaligned door.
    2. Shorted HV capacitor.
    3. Shorted HV diode.
    4. Shorted magnetron (probably won't blow main fuse but HV fuse if used).
    5. Defective triac.
    6. Old age or power surges.
    7. Defective HV transformer.
    8. Short in wiring due to vibration or poor manufacturing.
  • Problem: Fuse blows when microwave shuts off (during or at end of cook cycle).
    Possible causes:
    1. Defective triac (doesn't turn off properly).
    2. Defective relay.
    3. Shorting wires.
  • Problem: Oven heats on high setting regardless of power setting.
    Possible causes:
    1. Faulty primary relay or triac or HV relay (not commonly used).
    2. Faulty controller.
  • Problem: Oven immediately starts to cook when door is closed.
    Possible causes:
    1. Shorted relay or triac.
  • Problem: Oven heats but power seems low or erratic.
    Possible causes:
    1. Low line voltage.
    2. Magnetron with low emission.
    3. Faulty controller or set for wrong mode.
    4. Stirrer (or turntable) not working.
    5. Intermittent connections to magnetron filament or elsewhere.
    6. Faulty primary relay or triac or HV relay (not commonly used).
  • Problem: Oven heats but shuts off randomly.
    Possible causes:
    1. Overheating due to blocked air vents or inoperative cooling fan.
    2. Overheating due to bad magnetron.
    3. Bad connections in controller or microwave generator.
    4. Faulty interlock switch or marginal door alignment.
    5. Faulty controller.
    6. Overheating due to extremely high line voltage.
    7. Stuck stirrer fan resulting hot spots detected by sensors.
  • Problem: Oven makes (possibly erratic) buzzing noise when heating.
    Possible causes:
    1. Fan blades hitting support or shroud.
    2. Vibrating sheet metal.
    3. Vibrating transformer laminations.
    4. Turntable or stirrer hitting some debris.
  • Problem: Oven light does not work.
    Possible causes:
    1. Burnt out bulb :-).
    2. Bad connections.
  • Problem: Fans or turntables that do not work.
    Possible causes:
    1. Gummed up lubrication or bad motor bearing(s).
    2. Loose or broken belt.
    3. Bad motor.
    4. Bad thermostat.
    5. Bad connections.
on Mar 30, 2008 | Kenmore 80412 Microwave Oven
GE JVM1850CH06 MICROWAVE
the panel display is fried. you'll need to remove and replace it...this the sort of thing you enjoy doing?
May 23, 2008 | GE XL1800 1100 Watts Microwave Oven
Dacor Microwave DMT2420S control panel screen white
It is the CPU/display assembly that has a problem.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
In my professional opinion, there are weaknesses in both the design and manufacturing.
Our proprietary modifications and repairs are designed to not only repair these, but prevent them failing again.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you with disassembly.
Please tell your builder about us.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 21, 2009 | Dacor DMT2420SS Microwave Oven
Control panel on a whirlpool microwave
SOME ELECTRONIC CONTROLS HAVE A LOCKOUT FEATURE THAT IS ENGAGED AND DISENGEGED BY HOLDING A CERTAIN BUTTON FOR 5 SECONDS. LOOK FOR A LOCK PAD AND HOLD IT FOR 5 SECONDS TILL IT BEEPS.
IF NOT AVAILABLE, THE TOUCH PAD MAY BE UNPLUGGED FROM THE MAIN P.C. BOARD OR MAY BE DEFECTIVE.
ALSO, TRY UNPLUGGING THE MICROWAVE FOR 5 MINUTES
TO RESET THE MICROCOMPUTER, THEN PLUG IT BACK IN AND SEE IF IT WORKS.
AN ELECTRICAL OUTLET NOT WIRED WITH PROPER POLARITY OR NOT GROUNDED CAN AFFECT ELECTRONIC APPLIANCES ALSO.
Mar 26, 2008 | Whirlpool MH7140XF Microwave Oven
Microwave/small appliances do not turn on when plugged on to the power outlets on one wall.
What does "control panel has all fuses working" mean?
Are you saying you have an old-fashioned fuse panel in your house, instead of a modern circuit breaker panel?
If so, then I would suspect a bad connection in the panel.
If you indeed have breakers, a breaker can snap into the on and positions and still be bad.
Either problem sounds like it should be handled by a qualified electrician.
The power company or your insurance company would likely reimburse you for all or part of the electrician's bill, but you shoudl call first to be sure.
It's possible to have a faulty neutral connection in your wiring. That can lead to damage of several appliances and bulbs, and even pose a real fire or smoke hazard.
Please do not hesitate to get things fixed when you have home electrical problems!
Nov 04, 2007 | Samsung MW5351G Microwave Oven
Keypad on microwave wont work
TOUCH PANEL & MICROCOMPUTER BOARD TEST FOR WHIRLPOOL....
The microwave oven may be provided with a self diagnostic routine that can be operated
through the touch pad keyboard. To enter the self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "—" is displayed...
POWER FAILURE &FAILURE CODES
Power Failure: After a power failure, the WELCOME screen will be displayed.
F2 —Keyboard Failure: Refer to the Tech Sheet and conduct a touch panel continuity test.
F3H —Humidity Sensor Failure: Refer to the Tech Sheet and test the sensor.
F6 —Microwave Relay Failure: Check the microwave relay.
F7 —Microcomputer Board Failure: Change the microcomputer board.
Oct 18, 2007 | Microwave Ovens
Wiring diagram Problem - Maytag MMV5207A 1100 Watts Microwave Oven
This doesn't have the diagram hidden away somewhere inside? Check at the bottom edge of the control panel, transformer brack, or rear of the oven. Otherwise, you can find wiring diagrams of earlier models that may be close enough. Just enter your model number here: http://tinyurl.com/gv383
Sep 04, 2007 | Maytag MMV5207A Microwave Oven
Possible power surge?
Sounds like you got a surge which damaged the control panel. This is the most likely thing. We regularly repair these control panels nationwide for $32.50. A fuse is designed protect against excessive current. But if you have excessive voltage (a surge or spike), it can be so fast that it gets past the fuse and damages the control panel without actually blowing it. While the panel does have surge protection to keep that surge from actually destroying the control panel, the panel is damaged and will have to be repaired. If any power line connections were broken or are suspect, I hope you have contacted the power company. Either way, I would test any affected outlets to be sure the neutral and ground are present so the voltage output is within the proper range.
Nov 16, 2006 | Samsung MW5351G Microwave Oven
Microwave Ovens Logo
177 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Gerry Harvey
Gerry Harvey
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
