Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
I have a poulan lawn tractor model number 31a707 16.5 horse briggs and stratton, when i used it last it sounded a little funny, when i turned it off it would only turn over never crank. when i choke it it will start but die as soon as it starts. i will then move the choke to run high idle and it wont start. acts like its not getting fuel.
  • 8 Answers
SOURCE: briggs a stratton 35 lawn mower
Turn the mixture screw on the carburator slowly counter clock wise till the idel stabalizes.
Posted on Jul 01, 2009
lester482529
  • 226 Answers
SOURCE: MTD lawn tractor. 16 hp twin briggs straton
THIS SOUNDS LIKE A THROTTLE CABLE LINKAGE PROBLEM.WITH THE HOOD OPEN AND MOTOR RUNNING RUN YOUR THOTTLE UP AND DOWN WHILE LOOKING @ THE LEFT SIDE OF THE MOTOR TO SEE IF THE CABLE IS FROZEN IN PLACE OR BROKE OR DISCONNECTED .HOPE THIS HELPS
Posted on Jul 16, 2009
  • 3 Answers
SOURCE: Huskee 25 hp lawn tractor with briggs & stratton motor wont start
Most all manufacturers have the Users Manuel available on line you will need the Make and Model to pick the correct one. Have you replaced the battery. It can show the correct voltage but have no cranking amps. I believe if the solenoid is trying to engage the Dead Man switches are closed. With the starter disconnected from all power sources do the teeth on the starter turn or are they locked up? If they refuse to move do you have an Auto Zone around or another parts store or electrical engine repair store that can test the starter. Make sure the mowing deck is not engaged while you are trying to start the engine. I hope these rudimentary suggestions help.
Posted on Jul 18, 2009
panilling9
  • 284 Answers
SOURCE: how to adjust valves on briggs and stratton 17.5
Remove spark plug
Remove cover from engine that covers the flywheel
Remove rockerarm cover or valve cover
Find TDC (top dead center) by rotating the flywheel by hand and your finger over the spark plug hole as you rotate the flywheel you will feel pressure against you finger at some point then stop.
This is the compression stroke it is called now find a long slim round piece of plastic or plastic ink pen to stick in the spark plug hole (If you are careful a slim screwdriver can be used ) and find the piston top, then slowly rotate flywheel again (cw) as the piston is moving up pushing the plastic up as you rotate the flywheel slowly.
a max. piston up or tdc as you turn you will feel and then the piston starts to go the other way,at that transition this is tdc (piston is on top of stroke) leave it there,,both valves should be closed at that point.
Have a feeler gauge and set the exhaust valve at a loose .002 and the intake a loose .004 be sure engine is cold when valves are adjusted
Feeler gauge goes in between the rocker arm tip and valve stem top for each valve setting.
Note the rocker adjustment at the push rod side of each valve by tightening and loosening to make adjustments,lock your adjustments in place and rotate flywheel a few times and recheck settings
Posted on Sep 20, 2009
SOURCE: Poulan Lawn Tractor 42" 14.5 hp Model 733-864 How ...
I need the diagram for a drive belt for a 42'' lawn tractor - 14.5 hp Can ANY ONE help me?
Posted on Jul 14, 2011
I have a Poulan PRO Model PB20H42YT. It was working great when slowly I lost forwar/reverse motion; freewheel control is engaged properly.
sounds like the drive belt is off or broken, on the lawn tractors if you remove the plate, where you shift gears, you will see the belt.
Oct 29, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Starter
Take the part with the info you have to a Briggs authorized parts place ... they can help you .
Jun 01, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Remove starter motor briggs and stratton lawn tractor
My briggs 16.5 moptor wont turn over. It comes up on compression and stops. I have tried to jump it but the cables get really hot. Is my problem in the starter motor?
May 30, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan Lawn Tractor 42" 14.5 hp Model 733-864 How do you remove the rear wheel to fix flat tire?
May 21, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Need to locate lawn mower ID No on a Briggs and Stratton lawn mower
The Model number for the Lawn Mower should be located under the seat or on the underside of the hood. The Model number for the engine should be on the top shroud usually in the front or above the carb.
May 03, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Won't start
If you don't hear a clicking sound when you turn the key, it sounds like the starter solenoid needs to be replaced.
Find your model number under the seat and go to www.precisionope.com. Look up your model there.
It may say Poulan on it but it was more like an AYP product.
Apr 17, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Poulan Pro Lawn Tractor (PB195H42LT)
sounds like you have a little rust on the very top of the piston. try this take the plug out and spray a little wd-40 in the hole(just a little) and pull the starter rope until the piston frees up(turn key to engage the starter if no rope) then trplace the plug and try to start it up...good luck
Apr 03, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Same problem: tapping carbureator with golf putter gets me more..
The model number should be 31C707-0005-G1. This should help you get a carb. Probley just as cheap as a kit.
Jun 03, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
179 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
