Question about HP Compaq 6720s Notebook
Keep getting this message
Keep getting this message system32hal.dll. re-install this file. on hp mini compaq 700.the laptop has no cd or dvd drive and no windows backup
    President:
  • 524 Answers
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
Posted on May 09, 2010
  • 808 Answers
It looks like the error in ur registry because of invalid registry errors so make ur registry error fix by using reg in out registry cleaner
Posted on Sep 06, 2010
SOURCE:
Driver wireless compaq mini
Can you provide more information about problem?
Mar 05, 2011 | Computers & Internet
The file <windows root>\system32\hal.dll.
Restart the PC. The hal.dll error could be a fluke.
Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
Recover data from any bad sectors on your hard drive. If the physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Feb 15, 2010 | Dell Latitude E5500 Laptop
Installing Windows 7 - CD/DVD driver missing message.
windows 7 will still be released next month. are you using the beta version?
Sep 12, 2009 | HP Compaq Presario V2000 Notebook
The InterVideo WinDVD 5 program on my laptop not working!
Maybe your CD/DVD drive is a old drive :O( , for the new cd´s/DVD´s on the marked today actually many times you need a new drive for read them. Try first if you can install with the dll found on the link below.
You can find "wnaspi32.dll'' here : http://www.dll-files.com/dllindex/dll-files.shtml?wnaspi32
Ohter solutions:
1: get a external drive(not to old) and try install it with that
2: copy the cd to a usb storage on a computer thats have a new cd/dvd drive, use the usb storage to install it on your computer, use the dll file from the link.
Hope this can resolve the problem.
Aug 23, 2009 | Intervideo Computers & Internet
How to Reset HP Mini 1000 Laptop BIOS?
http://laptoppassword.blogspot.com/2011/06/hp-mini-password-service-compaq-mini.html
Clear Bios Password for HP Mini - Compaq Mini:
HP Mini 1000, HP Mini 110, Compaq Mini 110C, Compaq Mini 110, HP 2230S, HP Mini 1120LA, HP Mini 1151NR, Compaq 700....If you see this screen on boot:Enter CURRENT Password: [_______________]
We can help you Remove Password, right now !!!
You just enter 3 random passwords one by one and see if you get a similar [System Halted] message with 10 chars Error Code. (e.g CNUXXXXXXX, 2MCXXXXXXX....)
Jul 16, 2009 | HP Mini 1000 Netbook
then there is no option go get it back.... u have to boot into the Windows XP Setup then only u can solve this error...better get a CD Drive from any of ur neighbours or better buy one...
Jul 08, 2009 | Microsoft Windows XP Media Centre 2005 for...
Without cd rom how shld i install system32hal.dll file..
Install the file using USB drive such as pendrive.
Visit the below link for more information on hal.dll missing or corrupt:
http://support.microsoft.com/kb/314477
Try the steps in method 1.
For method 2, we need to use Windows XP CD, try to use external DVD drive and after connecting the external drive, you can reinstall the file or follow the other steps to resolve the issue.
Jun 25, 2009 | Acer Aspire One PC Notebook
if you have a windows cd you can do a system restore from it or at the boot screen some computers have a system recovery so you can use system restore without a disk, if you can use system restore, restore your computer to a earlier time and that should solve your problem
Jun 04, 2009 | Compaq Presario 5000 PC Desktop
My computer(Compaq 5301RSH 5000 SERIES) won't start because "Windows could not start because the following file is missing or corrupt: system32hal.dll. Please re-install a copy of the above file." What can...
Alright..Not a big problem..Generally happens due to some files corrupting. Put your Windows CD in the drive, boot form the Disc and choose to repair the operating system. The problem will be solved.
Thank you!
Sabharish
Jun 04, 2009 | HP Compaq Presario S5100NX (DM172A#ABA) PC...
I can't afford a brand new Windows XP boot disk Where
You should be able to download that file from microsoft, or try googleing "ntoskrnl.exe"
I done it for a missing dll file and found many places to download for free.
May 17, 2009 | Compaq Presario 700 470024-192 Notebook
HP Compaq 6720s Notebook Logo
652 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
