Question about Samsung SGH-t819 Cellular Phone
My screen light won't turn on. the buttons light up except the screen. anyone know how to fix it? or what's wrong with it? its a tmobile samsung sgh-t819
  • 343 Answers
If its not dead is dying so its time to change the screen sorry
Posted on May 08, 2010
Samsung 13 tv can't get it to run what can I do?
As you and I don't know what the problem is, certain basics have to be first covered. Here is a link describing basics for any TV.
TV Power Light Comes On But No Picture Or Sound
As I don't know if you have an active led power light, here are a couple of videos:
EASY HOW TO FIX SAMSUNG TV NO POWER
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
Samsung TV Won Turn On Has No Power No Standby Light Samsung LCD TV...
If the set is powered up, you can try resetting it to factory defaults. Yes, any of these suggestions may not work but one of them might fix your problem. You might try searching for tips by including the model number in the search. Bear in mind you are dealing with a high voltage device and your next repair may be at the hospital if you are not exceptionally careful.
Feb 28, 2018 | Samsung Televison & Video
How to fix Samsung HL72A650C1FXZA DLP TV with no sound, no picture, bright screen with lamp light flashing?
Check the bulb ballast board. It's the board that the wires from the bulb connect to. That is most likely causing the Sounds like the main board is the culprit for most of the problem. The picture problem can be the color wheel not turning. The lenses in front of the bulb should be taken out and cleaned too.
Oct 12, 2016 | Samsung Televison & Video
SAmsung behold turns on and restarts on its own will. Cannot open text messages either
Not sure why it happens, but my behold would start up and then turn off, start up and then turn off, cycling over and over. I checked internet and no one had an answer. Finally tried this and it seemed to work. When the behold finally gets to the first screen (with widgets, phone, ph.book, web, and menu on the bottom of screen) I pushed on the touchscreen menu button. I only had a few seconds before it shuts down and restarts. The menu screen popped up and I went to the "settings" and then "reset settings". It asks for a password (I used 12345), and then confirm password. This will reset your phone, but you will also lose info. or pics on your phone. Phone then did an automatic restart and my phone was back working. I was then able to restore my phonebook #'s because tmobile has an automatic phonebook backup. I hope this helps anyone with the same problem I had. Makes me angry that when I called tmobile they said no one has called with this issue yet I have found many people with the same problem. Obviously some type of glitch that seems to have an easy fix.
Oct 23, 2009 | Samsung Behold Cell Phone
Samsung sgh a737
FOR PEOPLE WITH PHONE FREEZE ON SAMSUNG- the #7465625*638*code# is not needed when you have the phone freeze just follow below.
I know how frustrating this was and i got it done by myself by experimenting since everything cant be googled that easily. i figured i can help anyone out. this has worked for 5 phones that i have done my self so 5 for 5 YESS!!! This is as satisfiying to me as watching micheal jordans final shot!
any ? contact me at 2xplizit4u@gmail.com
ok i figured it out. for all those people that have gotten the dreaded phone freeze om samsung propel a767 or any other samsung phone so far not sure about touch screen.
first look for a local unlocker in ur area or somewher that can provide the codes and get the unlock code and phone freeze code. mine was only 20 for both and took less than 24 to retrieve. email me for his info.
insert sim that you want to use (tmobile). you get the screen which says phone freeze. type in the freeze unlock code which was given and the press the att logo/menu button.
**YOU WILL NOT BE ABLE TO SEE THE NUMBERS YOU ARE TYPING SO KEEP TRACK OF WHAT YOU INPUT**
after you have entered number and pressed button then you will get a network lock screen. this is where you type in ur unlock code. type that in press confirm and BAMM!!!! you are now able to use tmobile sim
Apr 11, 2009 | Samsung SGH-a737 Cellular Phone
I forgot my password for my samsung behold-tmobile
Dont worry. If you forgot your password for your samsung behold tmobile it is eassy to reset. just follow these steps :
Step 1: Turn your phone off Step 2: press and hold down volume and hold call button and End button if done right you will see a Reset mode pop on your display screen step 3: This picture with icon over a phone pops just Press "MENU" and wait for your phone to boot and then enjoy.
Dec 20, 2008 | Samsung SGH-U600
Picture will not display on my samsung sgh-u600
Probably the ribbon that connects screen to keypad
common fault on this phone
Aug 12, 2008 | Samsung SGH-U600
When I try to turn on, or see pictures stored, it beeps three times and shuts off
called samsung s800 have know power problems return for replacement before warranty expires or they will charge you 58 to fix
Oct 28, 2007 | Samsung Digimax S800 Digital Camera
Samsung SGH-t819 Cellular Phone Logo
243 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
