Question about Maytag MGDC500V Dryer
Dyer is making loud noise like as if it had shoes inside. It is not drying, it takes like three hours to dry cloths.
  • Maytag Master
  • 8,220 Answers
Probably a broken blower wheelDyer is making loud noise like as if it had shoes - c3967f7.jpg
Posted on May 08, 2010
  • Dan Webster
    Dan Webster May 08, 2010
    If that is fine something must be in there with it
Tumble dryer not drying properly
Make sure your dryer vent is clean. This can get clogged with lint over a period of time. Make sure to check both inside and outside vents
Dec 23, 2013 | Indesit Dryers
My new gas dryer takes an extremely long time to dry clothes. It can take up to three hours to dry one load.
check your vent on the inside and outside of your home,, also check and make sure the vent hose is not kinked up,( sometimes when you push the dryer back it will kink it)
Jan 20, 2011 | Kenmore 8753 Dryer
My stackable dryer (417.94702300) makes a clunking noise. We just got it (craigslist) and it happened the 1st time we turned it on. Sounds like we're trying to dry a shoe in there - it clunks in rhythm...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 16, 2011 | Kenmore Washing Machines
DYER IS TAKING SEVERAL HOURS TO DRY CLOTHES
You need to clean out the lint fron the inpeller inside the machine and the hose that exits the driyer
Feb 13, 2010 | Maytag Neptune MAH6500A Front Load Washer
Frigidaire combo washer/dryer screws inside come off
The drum shaft came loose from drum. You can YouTube it for procedure of disassembly of dryer. Remount shaft, if screws are bad may need new shaft with screws, make sure it is tight to drum. While you have it apart you can clean out lint.
Sep 27, 2017 | Frigidaire GLER331A Electric Dryer
Dyer malfunctions
Clean off the two metal bar inside the drum, near the lint filter. (these are the moisture sensors, which can become coated with fabric softener sheet residue, preventing the dryer from "seeing" that the clothes are still wet)
Jan 13, 2009 | LG WM-2277HW Front Load Washer
LGE59777S Not drying
There is a little sensor that tells the dryer when to heat and when not to heat. that sensor is bad. If you take the back of the dryer off you will see it. It is about the size of a half dollar and has 2 wires that plug into it. While you have it apart make sure that the dryer vent on the back of the dryer is not plugged with lint. Major cause for fires in dryers.
Jan 04, 2009 | LG DLE5977 Electric Dryer
Kenmore elite smartheat quitpak electric dyer
try drying load with vent tube disconnected may get warm and dusty but if works ok recheck vent completely also be sure vent is not being flattened when dryer is pushed back to wall also remove lower panel(clips along top edge each corner about 3-4 inches in)remove blower housing 2-3 screws and clean housing
Dec 12, 2008 | Dryers
Maytag dryer model LDE8410acw
Hi james,
How old is the dryer?
Sounds like a bad element!
Age determines if it's worth the investment !
Sep 18, 2008 | Maytag MDG9606 Dryer
Dryer
Today my whirlpool dryer started making a loud noise. it is drying the clothes but the noise is loud.
Jul 06, 2008 | Kenmore Dryers
Maytag MGDC500V Dryer Logo
61 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
