Question about Danco Home
I just installed a new anti-syphon ballcock. The water-level adjustmaent knob does not stop the water from continuing to run, till it overflows, constant running water. How can I get the water to stop filling the tank?
  • airsantacruz May 09, 2010
    very poor answer, not, in fact to the point...which was that the control being turned was not limiting the flow of water at all.
    wrong again...the adjustment knob is a screw (itself), and tightening the screw is the method used to increase the water level. I'm beginning to think I've been "screwed"
    Genius:
  • 1,040 Answers
Dear Airsantacruz,
Check out your assembly is same as per this.....
I just installed a new anti-syphon ballcock.  The - backsiphonage2.gif To eliminate the risk of reverse flow in toilet tanks, anti-siphon ballcocks should be installed with a minimum 25mm (1 inch) air gap above the overflow tube. Figure 3 shows the correct installation of an anti-siphon ballcock while Figure 2 shows the incorrect use.
To eliminate the risk or reverse flow in hoses, inexpensive, easy-to-install hose connection vacuum breakers should be installed (Figure 4). Air gaps should also be left between water outlets and sources of potential contamination such as sinks or tanks.
For more information visit to the given link..... http://www.cityofandrews.org/backflow.htm
http://www.oddtodd.com/message185.html
Posted on May 09, 2010
  • 10,319 Answers
You will see a screw on the valve. Tighten that screw inward to shut it off when the water level is were you want it at. It may take a few times to get it right were you want it
    President:
  • 1,561 Answers
You will notice that a float operated piston valve is mounted in the valve chamber to control water flow to the discharge chamber. A hush tube connected to the discharge chamber feeds the water to the bottom of the flush tank. A combined volume control and anti-siphon valve is mounted in the discharge chamber between the inlet and hush tube to regulate the rate of flow and to act as a vacuum break under conditions of negative pressure in the water supply line.
All you need to do is to adjust the valve to the water level you want it to reach.
Take care.
Posted on May 08, 2010
  • Sulaimon Jimoh Olayemi May 09, 2010
    I suggest you follow the link below in other to see how this could be fix. type the link below in your web browser to see the information it contain.
    http://www.doityourself.com/stry/h2repai...
    If the problem is not still solve with the information in the above link, then i suggest you contact where you bought it from to inform them because it is possible that it is a defected anti syphon ballock tub you bought.
    Take care
Why doesnt town water cut off and just keep filling the tanks till they overflow we have tryed everything
Troubleshoot Your Toilet Without a Plumber
www.popularmechanics.com/home/how-to/a4117/4303948/
Overflowing, constantly running and sweating toilets can test a home owner's sanity. ... take for granted--until we can't take a shower or make the toilet flush properly. ... If none of the above does the trick, you may have a misadjusted or faulty fill ... the waterlevel a half inch below the top of the overflow tube inside the tank." ...
Emergencies - Overflowing toilets - Toiletology 101
www.toiletology.com/emergenc.shtml
You can't just lower the water level in the tank; you need to displace some of ... and the ballcock and flapper are working properly and shut off when the tank is full. ... The bowl is filled with the water that goes into the overflow pipe. ... Unfortunately, when a toilet bowl is clogged and the water level rises and doesn't flush the ...
Nov 19, 2015 | Town Home
We have fitted a new ballcock on the watertank (cold) since then we have little cold water
Are you sure the ballcock is correctly adjusted to fill the tank to the required level? The float should have a screw on it which changes the height at which the valve is closed. if set too low you may not get enough head of water to feed the system. If set too high the tank will overflow.
This video deals with a toilet (WC) cistern but the principal is the same for any ballcock valve system.
How to adjust the cistern ballcock in your WC cistern get better flush
Apr 15, 2015 | Home
Running toliet
Then you either have to lower the water height so that it doesn't overflow the overflow tube, or you have to replace a seal on the ballcock or replace the ballcock with a modern style.
Nov 28, 2013 | Home
Water keeps running, toilet not shutting off totally, tank will fill then we have to pull up float and hold it a while to stop water, doesn't overflow, just keeps running, doesn't shut off...
Hi snowjobs847...
Try resetting your float level to a lower water level in the tank, the extra pressure put on the seal may make it reseal.
If the above did not work:
You need to replace your "ballcock"...the ballcock (inlet valve) is non-repairable, has to be replaced with a new one if you cannot get it to stop leaking.
Please take time to rate me
Sep 04, 2011 | Home
Float is adjusted to the proper height but water continues to slowly rise until it reaches the overflow
Hi lucy edwards...
Change the inlet valve (ballcock) it is leaking and non-repairable
Once you replace your ballcock with a new one and set the water level that will solve your problem.
Aug 30, 2011 | VitrA Aria Toilet with Round Bowl /...
I installed a new ballcock assy and float. the toilet fills and shuts off but i can still hear an intermittant water flow. there were no instructions with the new valve so i dont know how to adjust.this is...
Without knowing what type of ballcock assembly you used I can't tell you how to adjust it. However there is one easy thing that you can check. If you have a plastic line going from the ballcock to fill/overflow in tank make sure that the bottom of that line is not below the water in the tank or it can create a siphon and make the water to run a small amount nostop. Hope this helps you. Have a good day and thank you.
Apr 30, 2011 | Home
Kohler Toilet: Filling apparatus works OK, but constantly overflows.
Hi jgikirstein..
You need to reset your water level inside of the tank, lower the ball float and that should stop your overflow problem.
If it continues to leak then you must replace your "ballcock assembly"...if it is defective it will also cause your tank to overflow...
Free Answer...Please rate me
Apr 17, 2011 | Home
Valve to stop water from running
IF YOU HAVE A FLUIDMASTER BALLCOCK,AND IF THE WATER IS CONTINUING TO RUN ,YOU NEED TO ADJUST THE WATER LEVEL,MOST OS THE TIME ALL YOU HAVE TO DO IS OPEN THE TANK LID AND ON THE LEFT SIDE YOU'LL SEE THE BALLCOCK,AT THE TOP IT MIGHT HAVE A BLACK PIECE THAT YOU CAN SLIDE UP AND DOWN TO ADJUST THE WATER LEVEL,OR SOME HAVE A PIECE THAT LOOKS LIKE YOU CAN USE A PHILLIPS HEADS SCREWDRIVER,ALL YOU HAVE TO DO IS TURN IT A HALF OF TURN EACH TIME UNTIL THE WATER STOPS GOING INTO THE OVERFLOW TUBE ,WHICH IS USUALLY LOCATED IN THE CENTER OF THE TANK AND IT WILLBE 1INCH ROUND ,IT ALSO WILL HAVE YOUR FLAPPER OR BALL CONNECTER TO IT.
Apr 07, 2010 | Toto Toilet Onepiece Ultramax ...
When the toilet has been flushed (push button)it makes a hissing noise and then overfills so the water is going away in the overflow pipe. it was fitted 3 years ago. thankyou.
on your ballcock assembly there is an adjustment device (usually a screw) you just need to adjust the water level so it does not go over the overflow and have the "running" sound. there is a reccomended level usually stamped on the tank or the overflow tube.
hope this helps
Jul 07, 2009 | Home
Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Apr 20, 2008 | Washing Machines
Home Logo
151 people viewed this question
Top Danco Home Experts
Donni Steen
Andrew Bugbee
richie46
Are you a Danco Home Expert? Answer questions, earn points and help others
