Question about Toshiba MD13P3 13 in. TV/DVD Combo
A power surge seems to have burned out my Toshiba TV/VCR combo.
It no longer responds when I push the on/off switch. None of the indicator lights show any signs of life. I'm wondering if there is a fuse somewhere that can be replaced, or if I should just go ahead and get a whole new unit.
    Scholar:
  • 70 Answers
The power supply does have fuses. They require removing the back cover of the unit. Note: High voltage is present so I recommend having a pro do this.
In units like this many times a part will fail and the fuses will be ok. At this point you will need a pro again.
I would replace the unit. The repair cost could be in the 60 dollar range depending on the severity of the problem and shop rates in your area.
Posted on May 08, 2010
No picture
If the unit powers at all and you hear some thing from the VCR, and then the unit powers off--problem is in the VCR.
If total dead a fuse is of course possible--If none of these then the TV has a problem in either the High Voltage circuit or the power supply.
To repair or to replace?
May 01, 2012 | Toshiba MV19N2 19 in. TV/VCR Combo
No sound, no picture
Try with external monitor and let me know did u see ur desktop with external monitor?
OK?
Nov 24, 2007 | Toshiba MW26G71 26 in. TV/VCR/DVD Combo
Hello i have a toshiba md9dm1 tv/dvd combo and i lost my remote I have a universal ge remote none of the codes work Do you know the code for my tv/dvd combo?
hi,
If you remote is a 4 digit one then the codes are
0394, 0924
If the remote is a 3 didgit one then the codes are
394, 902
MANUALLY ENTERING CODES
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
2. Press and hold the CODE SEARCH/SETUP button on the remote until the
INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming (TV, VCR,
DVD, etc.). For AUX, press AUX then the device button you are assigning to
AUX. The INDICATOR LIGHT will blink then remain lit.
4. Enter the three or four digit code for your device using the number buttons in the
GE Universal Remote. After your code is entered the INDICATOR LIGHT will
turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the POWER
button. Your device should turn off
OK
Aug 03, 2011 | Toshiba MD9DM1 9 in. TV/DVD Combo
I need the remote code for the toshiba MV13M3
Hello
Universal remote setup codes for Toshiba TV/VCR combo are:
0260 0358
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jul 14, 2011 | Toshiba MV13M3 / MV13M3W 13 in. TV/VCR...
I purchased a GE Universal remote and I do not know the code to set up for MV20FM4. Please help.
HelloHello
You haven't given the model number of GE remote you have purchased. Yet I hereby give you some universal remote codes for Toshiba TV/VCR combo. Try with these. If you fails to synchronise with; inform me the model number of your GE Universal remote:
Four digit codes for Toshiba TV/VCR combo are: 0260 0358
Three digit codes for Toshiba are: 013/ 049/ 089/ 105/ 109/ 117/ 118/ 120/ 159/ 178
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK. Thanks for using Fixya.
Apr 07, 2011 | Toshiba MV20FM4 20 in. TV/VCR Combo
Need code for toshiba flat screen tv
Hello
Three digit universal remote code for Toshiba are:-
Four digit universal remote codes for Toshiba are:-
0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
NB: Switch OFF and switch ON your TV, with its front panel power control switch each time before trying an other code.
Direct Code Entry
Mar 13, 2011 | Toshiba Televison & Video
Need the remote se up coed for Panasonic tv.vcr combo model PV-2061. The nine 5 digit codes provided by Comcast do not work
Hello
Just try with these four digit codes
0374 0381
Direct Code Entry
NB: Switch OFF and switch ON your combo with its FRONT PANEL POWER SWITCH EACH TIME before trying an other code. OK.
Feb 17, 2011 | Panasonic PV-C2061 20 in. TV/VCR Combo
Code for universal sony remote sony-v201
Hello
Sorry to say that Sansui is not listed to Sony V201 remote control. Anyway I'll give you some three digit and four diit conds for Sansui. I'm not sure will it work, but try these, sometimes you may get.
Three digit universal remote codes for Sansui are:
135/ 136
Four digit universal remote code for Sansui TV/VCR combo is
0310
Four digit universal remote code for Sansui TV are:
0135 0310
Direct Code Entry
NOTE: Switch OFF and switch ON your combo with its FRONT PANEL POWER ON-OFF SWITCH each time before trying an other code.
Hopes you will be helped.
OK.
Jan 27, 2011 | Sansui COM312AD 13" TV/VCR Combo
Looking for remote code for toshiba SD-P4000
Hello
Four digit Toshiba remote codes are
[0159 _ 0178_ 0109_ 0120_ 0181_ 0105_ 0049_ 0095_ 0170_ 0260_ 0358_ 0394_ 0924_ 0012_ 0095_ 0117_ 0141]
Three digit Toshiba Universal Remote Codes are
[013/ 049/ 089/ 105/ 109/ 117/ 118/ 120/ 159/ 178]
Direct Code Entry
Nov 19, 2010 | Toshiba SD-P4000 14 in. TV/DVD Combo
Samsung DVD-V4600A Combo DVD / VCR will no longer timer record to Videotape
Storms tend to fry most delicate electronics. Quality surge protection is required.
Ben
Jul 25, 2008 | Samsung DVD-V4600 DVD Player/VCR
Toshiba MD13P3 13 in. TV/DVD Combo Logo
144 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
