Question about Samsung LE40R73BD 40 in. HD-Ready LCD Television
Screen is two different brightnesses
The left side of the screen is darker than the right
    Scholar:
  • 70 Answers
This can be an indication that one side of your back light inverter is getting weak and will need to be replaced. This can be a simple process of taking the back off and replacing a board. You may want to have it evaluated by a tech though. parts can be tricky to find so check ebay and maybe opt to have the board evaluated for repair.
Posted on May 08, 2010
    Novelist:
  • 145 Answers
You may have burned out one or more cold cathode fluorescent lamps "CCFL" and that is why the screen brightness varies. Each side L and R usually contains 2 for a total of 4 CCFLs If one burns out you will still have one lighting up the screen however since there is 2 on one side and only 1 lighting on the other side this may be the problem and you may need to seek a replacement CCFL or send your screen to the company for repair.
TCL L46E5300F flatscreen half right side screen is darker than left side
If it is an LED LCD TV, the backlight inverter board should be troubleshooted. Contact any service technician.
Jan 09, 2014 | Vizio VW46LFHDTV10A 46 in. LCD TV
My flat screen tv is darker on the left side than the right side why?
Change input device to some other like a DVD player and see. Look for loose contacts in RC jack, cable and socket.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 06, 2012 | Philips Televison & Video
Dark line down the middle of my flat screen tv
Most LCD and PLASMA sets use two boards (some combine them into one board) that drive the Display Panel (the entire front screen unit) so I would suspect one of yours is bad.
The other unpleasant possible cause is where the left board is connected to the Display Panel (entire front screen unit) you have a problem inside that Display Panel and that is fatal as there is no way to get INSIDE the panel---it can cause both lines and a dark picture on one side of the screen.
May 25, 2012 | Sylvania Televison & Video
How can I adjust screen brightness?, I acidentally brushed across the keys on the right side and it made the screen darker.
Hi.
Hold down the Fn key which is located at the bottom right of the keyboard and tap the "Home" key which will be on the right hand side of the keyboard, that will increase the brightness. Also to decrease the brightness hold down Fn and tap the "End" key.
Regards.
Jul 16, 2011 | IBM ThinkPad R51 Notebook
How to make the images darker
Push the 'OSD' ("On Screen Display") button on the bottom-edge of the monitor.
Use the LEFT/RIGHT buttons to select BRIGHTNESS or CONTRAST.
Use the OK button to choose that selection.
Use the LEFT/RIGHT buttons to decrease/increase the BRIGHTNESS.
Use the OK button to confirm the setting.
Use the LEFT/RIGHT buttons to select CONTRAST.
Use the LEFT/RIGHT buttons to decrease/increase the CONTRAST.
Push the 'OSD' button to exit from the OSD.
Jun 01, 2011 | Acer AL1916W 19" LCD Monitor
I have an Acer Aspire laptop 4810T. It turns on perfectly and everything appears on the screen but it is barely visible. The screen almost appears to be black.
It would seem that backlight for your screen is out. The light may be dead, have a poor connection, or your brightness may be down to zero. To see if the brightness is just low hold the function button "FN" and if you look on the left and right arrow keys there should be a Sun on each one. The left being brighter or filled in, the right darker or hollow. Press the left key while holding the "FN" button. Keep doing this to increase the brightness. If the screen doesn't get brighter there is an issue with the backlight. This is usually covered under warranty. If you still have a warranty contact Acer and they should repair your computer free of charge. If it is not under warranty you may need to replace the screen.
Mar 17, 2011 | Computers & Internet
I CAN READ MY SCREEN BUT ITS DARKER THEN ID LIKE IS THERE AN ADJUSTMENT SOMEWHERE ON MY ASPIRE 3690?
To adjust the brightness of your screen just press and hold Fn button while pressing the right arrow key to increase the brightness and Fn + left arrow key to decrease.
Regards,
Pete
Sep 21, 2010 | Acer Aspire 3690-2196 Notebook
Toshiba 57LX177: Right side of screen darker than left
I am not sure...but I have the identical problem. I believe the vertical lines are caused by the inverter board and the darkness is caused by the one of the back lights that needs to be replaced. I am tearing my unit apart now and will find out.
Feb 21, 2009 | Toshiba 57LX177 Television
New lamp, half screen is bright the other half is much darker
Greetings,
Correct, if you know how to, try re-connecting the lamp.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 12, 2008 | BenQ MP610 Multimedia Projector
Samsung LE40R73BD 40 in. HD-Ready LCD Television Logo
74 people viewed this question
Henry  Thomas
Henry Thomas
