Panasonic plasma th42ph10uk power red light blink twice
Panasonic plasma th42ph10uk power red light blinking twice, service manual anyone ?
    Sergeant:
  • 418 Answers
Manual says problem with SC, SS, or C boards. SC is large board at left when facing rear, SS is large board at right, and C is small long board at very top. You could check fuses on SC and SS. Also, SC and SS should make a buzzing noise(not too loud) if operating. If a fuse is blown, suspect that board is bad not just bad fuse. Search parts at encompassparts.
Posted on May 09, 2010
Panasonic tv Th5opz81b flashes red twice will not turn on
Two times blinks to Panasonic Plasma indicates 2 blinks 15v SOS D Board. Check this site for more details about blinking codes to Panasonic Plasma displays.
Jan 16, 2013 | Panasonic VIERA Televison & Video
Panasonic 42 inch plasma wont turn on. red light blinks 10 times
I unpluged mine and the light was still blinking when it was unpluged. I thought that was weird. So I pluged it back in and just heald the power button in untill the light went out. It went out within ten seconds. I pushed the power button again and the tv went on. WOOHOO!!! Just needed reset, I guess.
Dec 10, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
My tv does not turn on any more and the power light just blinks red twice i have a 50" panasonic plasma model number thp50s10p
A blinking light on your TV means it is on face mode because one of your parts is shorted out and the TV is protecting the other parts. I don't have the service manual for this TV but on the older Panasonics 2 blinks poited to the D board. You can do a search online for a service manual for that TV therir are a few retailers selling it. The D board is also know and the Logic board which is located under the signal board. On This TV I belive the logic and signal boards are just one board. You can get parts for this TV at www.interliquidparts.com
Jun 13, 2011 | Televison & Video
Plasma tv th-42pd50u not come on and keep blinking red light two times and then stop again blinking red light two times and then stop not come on
The light blinking twice means there is a fault within the system and it is a code to tell Panasonic where roughly the fault lies.
Go to Panasonic's web site and look for your set then input the fault code and hopefully they will tell you where the fault lies.
Oct 16, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic TH42PA20 - No Picture
If you have the flashing red light of death you can use the chart below to see what the blinks indicate and call Panasonic and have the part replaced, at the bottom of this page is the meaning of terms.
BLINKS PROBLEM MALFUNCTIONING PART
1 blink STV 5v sense DG Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Panel = Plasma Display Panel (Plasma Glass)
D Board = Format Converter / Plasma AL / Sub-Field Processor
DG Board = AC-DC Converter / Digital Signal Processor / Full HD
Microcumputer HDMI Interface / Peaks Lite 2
H Board = Speaker Out / Sound Processor
AV Terminal / AV Switch
P Board = Power Supply
PB Board = Fan Control
SC Board = Scan Drive
SD Board = Scan Out (Lower)
SS Board = Sustain Drive
SU Board = Scan Out (Upper)
Apr 13, 2009 | Panasonic (TH-50PZ700U) Television
Panasonic TH-42PX60U plasma TV: red blinking light
are you using a PC to feed a signal or maybe a cable with an adapter?
I had the same issue when I used one of the rear HDMI ports to show a PC display. Apparently there is a software difference between the rear and side/front ports. Inputting the PC through the side HDMI port has solved the problem for me (so far!)
Mar 12, 2009 | Panasonic Televison & Video
Panasonic TH-58px600u
I have the same problem, no picture or sound, just a flashing red led. Has anyone found a solution?
Feb 12, 2008 | Panasonic TH58PX600U 58 in. Plasma HDTV
Power light blinks, but tv won't come on
I have the 52" version of the Viera model. Mine went out last night and started blinking twice over and over again. I suspected overheating so i just went to bed and tried it in the morning with no luck. Then I unplugged it for more than ten minutes and plugged it back in and everything worked fine. I hope this helps.
Jan 08, 2008 | Panasonic Televison & Video
Televison & Video Logo
1,024 people viewed this question
Top Televison & Video Experts
