Question about GE Nautilus 24" Built-in Dishwasher
Leaks when i turn it on,not sure from where, - GE Nautilus 24" Built-in Dishwasher
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Posted on Sep 29, 2010
Easy way to replace it
Replacing a water heater is no very difficult if you follow the steps.
1. If it is electric turn of the breaker and check to be sure it is the right breaker. If it is gas turn off the valve close to the water heater.
2. Turn off both the hot water and cold water valves
3. Drain all water out of the heater.
4. Disconnect the electric wiring if electric and if gas disconnect the gas line.
5. Disconnect both water lines which may have to be cut depending on how they are connected.
6. Now you can remove the water heater and discard.
7. Place new heater where old one was removed and reconnect both water lines and be sure you have a new pressure valve installed on the water heater.
8. At this point you can turn on water and check for leaks. you should also open a hot water faucet to purge the air out.
9. If no leaks go ahead and hook up the electric or gas lines and if gas is used turn it on and check for leaks using a leak detector or a spray bottle of soapy water and look for bubbles. If no leaks you can go ahead and light the heater according to its instructions.
10. If electric is used turn it on.
11. Take a long hot shower.
Feb 01, 2016 | Water Heaters
Aqualisa aquastream - when I turn it on the water pours down the wall. When turned off no trickle or leaks.
Surely something is leaking. I am attaching a diagram of the parts inside the unit for your reference. See if you can access the parts to find out which one is leaking and replace the broken part.
Feb 16, 2014 | Home
Fridge leaks water on floor constantly
does it have an ice maker and or water dispensor? if so start by turning off the water supply, see if the leaking stops. if it stoped you may have a broken water line or the water level valve is leaking. if that isn't the issue check your seal around the door to make sure it isn't leaking in warm air. if that is ok you will need to look at the self defroster to make sure it isnt defrosting all of the time.
Jan 17, 2013 | Frigidaire Refrigerators
Air suspension not working
not sure on model but if there is a leak one of the hoses for the shockers will have split or have holes in them will have to be checked to find out where the leak is possibly near to where the hose enters the shocker or a junction box of sorts not sure but taking each wheel of in turn an listening for leaking air will give you a clue also make sure that the pump for the system is working but as stated not sure on model from uk hope this helps ivan
Oct 16, 2012 | 1997 Lincoln Town Car
Power steering failure on a 2004 mitsubishi endeavor.hard to turn wheel,is there a belt or other fixable way, owner manual says to bring it into the shop....
1st make a quick check, check fluid level on the pump,make sure the pump is not leaking fluid. check the belt make sure it has no cracks,make sure the belt is not slipping, it shoud not have any oil on it,should be tight. are the pulleys making noise,when the engine is running,does it make more noise when you try to turn. the belt could have stretched. if you jack the front end of your truck, turn engine on and turn power steering left and right with out any problem. if the pump is leaking very little, the lines could have air in them, and the leak would have to be eliminated before getting corrected. and there is the possibility of a bad pump. good luck!
Sep 26, 2011 | 2004 Mitsubishi Endeavor
Car makes a whinning noise when turning corner.
check the power steering pump fluid level. look on autozone website to see what it looks like and where it is. If it is empty, then you will end up replacing it, after you make sure the leak was not elsewhere. if the leak was not in the pump make sure you have the leak fixed before the new pump is installed.
Sep 20, 2010 | 2006 Buick LaCrosse
Every two days I have to fill up coolant with water.
first check for possible leak..if no leak present while the car running than turn off and check the engine oil to make sure it not leaking to the engine...if the oil is milky that you have a intake manifold leaks into the engine n check the oil cap for white spot and hope you don't have a blown head gasket..make sure the engine is not overheating...I recommend you used a radiator compression tool to check for leak before you go any further...good luck
Apr 21, 2010 | 1992 Cadillac DeVille
Diesel Leak
open and close the valve on the filter a few times be sure to make sure its closed fully
Jul 09, 2009 | 2002 Ford F250 Super Duty SuperCab
1988 Cadillac Power Steering Leak
BETWEEN THERESERVIOR AND PUMP ASSEMBLY THERE IS A O RING IT MAY BE MISSING OR CUT WHEN THIS PROBLEM IS CORRECTED (MAKE SURE PLASTIC RESIVOR(SP) IS NOT CRACKED) IF NO MORE LEAKS MAKE SURE IT IS FULL OF FLUID, RAISE FRONT WHEELS OFF GROUND KEY ON ENGINE OFF TURN STEERING WHEEL LOCK TO LOCK 50 TIMES. THIS FROM A CADILLAC SERVICE BULLETIN THIS WILL REMOVE AIR FROM THE SYSTEM
Oct 20, 2008 | 1988 Cadillac Sedan DeVille
GE Nautilus 24" Built-in Dishwasher Logo
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
