Question about Troy-Bilt 21AE682L766 Big Red 10 HP Electric Start Rear Tine Tiller
Runaway troybilt rototiller
Big red, on grass.free wheels when trying to cut ,or till it grabs and will run away with you. can i adjust it so i can use it to till new area [with grass]. with out being draged all over?
4 Suggested Answers
  • 25 Answers
SOURCE: Troybilt pony wont go into drive.
Not technically a solution, but there are Troybuilt tiller forums out there on the net. MTD bought them out some years back and some parts are still available. I had to go thru them to find a part number for a mid 80's Horse unit that had a broken drive coupling. Anyways, they have parts breakdowns and manuals on their site. And I've seen some on ebay if you need parts.
Posted on Jun 22, 2009
pippall
  • 1486 Answers
SOURCE: roper rally rototiller wont till
Check belts
Posted on Jul 06, 2009
vincob
  • 718 Answers
SOURCE: hello,im looking for a manual
Try this website psep.biz they have a lot of stuff there if you are willing to navigate a little.Good Luck...
Posted on Jun 04, 2011
My Earthquake Rear Tine Gas Rototiller - 196cc Viper Engine 4-cycle just makes a squeeling noise and tines won't rotate.
Sounds like the belt is slipping. Have you removed the belt cover and inspected the belt and the tensioner pulley ? If your model is like mine the tension can be adjusted just below the handles by looseneing the nut where the cable goes into the cable sheath and moving the cable cover further away from the handle. That takes up some slack and will make the tensioner pulley tighter on the belt. If the belt is shot tension isn't going to help.
Try "google" with "earthquake 5070 manual" first option should be a PDF copy of a model 5070 manual. Will have diagrams on how to adjust the cables.
May 08, 2014 | Earthquake 6015V Rear Tine Rototiller
Wheels 0n troybilt rototiller won't turn
Many Troybuilt Tillers have Pins on the Wheels and axle. Like troybuilt Bronco for instance. If you want the wheel to turn you need to set that pin so it goes through the rim and through the axle.
Aug 08, 2013 | Garden
I want to set the wheels for the deepest cut. In what direction should the wheels be adjusted-up or down?
If you move the wheels up, thereby lowering the cutting deck, it will cut the grass shorter on each pass.
If you move the wheels down, thereby raising the cutting deck, it will leave the grass longer on each pass.
May 04, 2011 | Garden
2010 Craftsman Lt 2000 deck height adjustment?
just bought a new craftsman riding mower. model lt1500. 17.5 hp with 42 inch deck. first time using I had the deck hight handle set on 6 the highest setting and still cuts grass to short, matter of fact it scalped the grass. anyway to set the deck higher. Its only 3 days old and still under warranty but the sears store is 20 miles away and I rented a trailer to go pick it up and hate to go rent another trailer to bring it back if its just a simple adjustment.
Jul 31, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Won,t move
Check the pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Husqvarna Zero Turn Mower Z5426
How do i adjust the hand brake on a e46 bmw
1st loossen up cable adjusters then remove rear wheels, remember safety 1st support car and through wheel stud hole you can turn adjuster star wheel with a small screwdriver till wheel locks then back off 4-6 clicks till wheel runs free next re adjust hand brake cable back up, again till wheels lock and again back of till free!
Apr 25, 2010 | 2001 BMW 3 Series
Jun 01, 2009 | Troy-Bilt Pony Garden Tiller
I bought my troybilt rear tine used. When I use it to till new ground (sod) it cuts fine for a few feet, then without warning, it gets on top of the ground, and I can't do anything to make it cut. The...
Hello, I think if you look at the depth setting bar you will find it clogged up with grass and roots. Once it clumps up you can't get it to drop to depth to make the cut. There are two speeds for the rear times for the toller which will make it go forward more slowly and allow the dirt clods to break up better. Also cut the grass as short as you can, make a shallow pass with the tiller 1" to 2 " to cut the heads off the roots and then go to depth with your next cut. This should pretty much break up the cloding when doing the tilling. Also watch it because it is hits a rock it will jump up and drag you away at the speed of the tines, because it lifts the drive wheels off the ground and the times drive the tiller instead. Other than that mine used to chew up everything including wet DG. Good Luck, RAC
Mar 31, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy-Bilt 21AE682L766 Big Red 10 HP Electric Start Rear Tine Tiller Logo
101 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
