Question about Siemens Cooktops
Trouble lighting gas hob
I have a Siemens EC715RB90E 5 ring gas hob and since installation last August it has been a tempramental lighter! It rarely lights first time and the central double ring wok burner is very difficult to light. It can be heard and seen to be 'sparking' and to gas switches on and looks to be burning well but as soon as you let go of the knob it goes out. I have held the knob down to give it a chance to warm up etc but it can still take in excess of 15 attempts to light.
  • 42 Answers
SOURCE: Cannot ignite central gas ring on smeg 5-ring kitchen hob
Still in warranty - get it repaired. Would not advise above solution as work needs to be carried out by CORGI engineer.
Posted on Jan 17, 2009
  • 73 Answers
SOURCE: When lighting one of the burners, the ingnition knob has to be held down over ten seconds for the flame to stay lit when the knob is released..
Lift the top of the Stove up.
Look for a Small line that goes to the Affected Burner.
At the end of that Line you will see a small Flathead Screw.
Turning That screw Clockwise Adjusts your Pilot Light for that Burner.
Be careful not to Adjust to High, it would just be a Waist of gas.
hope that helped.
Posted on May 20, 2009
  • 222 Answers
SOURCE: Gas hob is permanently igniting
hi gud day,try to clean the area of knobs by using vacium,remove all the knobs firts then clean it,unplug the unit before u clean.
tnx gerbee
Posted on May 22, 2009
  • 1531 Answers
SOURCE: Double ring burner won't light up.
the outer element may be broken if the center one is the only one getting hot
Posted on Apr 10, 2010
heatman101
  • 43501 Answers
SOURCE: R rear burner not sparking
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Posted on Aug 18, 2010
How do i unlock chidproof lock on my siemens induction hob
By holding down the key symbol for a period of 5 secs to remove lock
Oct 30, 2016 | Siemens Cooktops
Neff gas hob on T2124 not lightin when turning on ignition.
make sure you have gas to the hob then make sure all the rings are clean and not blocked and that the ignition electrodes are clean
Dec 09, 2010 | Neff 22 in. T2124 Gas Cooktop
Gas hob ignition firing, won't stop
not a solution I'm afraid - I'm having the same problem. How did you manage to fix it?
May 11, 2010 | Baumatic 27 in. B67 Gas Cooktop
tnx gerbee
May 19, 2009 | De Dietrich DTG775X Gas Hob 22 in. Cooktop
Miele KM 320 G gas cooktop ignitor
I had a similar problem and discovered that the control knob had fried itself, most likely due to liquid penetration down the shaft of the control knob and into the control knob electronics. Inside is a printed circuit board with resistor, diode and a rheostat. The surface of the board was charred beyond repair.
To trouble shoot the problem, open the cook top and hook the burner in question to one of the known good control knobs. If it ignites, then it is the control knob electronics. If it doesn’t, then there is something wrong with the igniter.
Note: The 2-zone Wok Burner had a different control knob that the other burners.
To open the cook top, do NOT loosen any of the Phillips screws on the sides. Here are the instructions from the user manual:
Disassembly
Shut off gas supply, disconnect the manifold pipe, disconnect the electrical power. Remove pan supports, burner heads and burner rings. Remove control knobs.
In the event that the hob is built in, undo the bracket clamps underneath the work surface. Lift the hob on to the work surface. Unscrew the venturis on the high-speed and super high-speed burners using a 20 mm wrench. Lift and remove the burner rings and burner base plates. Disconnect the wires from the ignition plugs. Keep the wire from dropping into the undertray by inserting it in one of the slots in the burner supports.
Remove the three screws securing the dual ring wok burner. Remove the wok burner base plate. Lift the ceramic tray from the hob.
Note: Each regulator shaft is equipped with a black ring. This ring may cling to the rubber seal in the ceramic tray. Check and remove the rings from the rubber seals.
To order parts, call 1-800-245-8215, 8:30 AM to 5:00 PM EST
Mar 04, 2009 | Miele 35 in. KM326G Gas Cooktop
Safety lock on Neff hob
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
Sep 27, 2008 | Neff 23 in. T4343 Electric Cooktop
Baumatic B40 Gas Hob : Gas not staying on.
we have the same problem... try removing the knob, ours works fine without the knobs ????
Dec 19, 2007 | Baumatic 24 in. B40 Gas Cooktop
Cooktops Logo
127 people viewed this question
Top Siemens Cooktops Experts
Paul Carew
Are you a Siemens Cooktop Expert? Answer questions, earn points and help others
