1997 Chevrolet Malibu Logo
Anonymous Posted on May 08, 2010
1997 Chevy Malibu cooling fans problem
both fans on my V6 Malibu 1997 do not work. When the engine is running, I see the temperature going up and above the middle point of the gauge, indicating thyat the temperature sensor is ok. Since all the relays are checked fine, I thought that there may be a wiring problem between the relay box under the hood and the computer. I removed the PCM, found connector pins that go to these relays and shorted them to ground (one at a time). Both fans come on just fine.Made an assumption that transistors in PCM turning these relays are fried. Got a new PCM, made it to relearn the passcode, started the engine and got the same result - gauge shows rising temperature, but fans do not come on...I am perplexed!Does this engine have two temperature sensors - one connected to the gauge and another one to the PCM? Or is it possible that somehow signal from the sensors is reaching the gauge, but not the pcm?Will greatly appreciate your help!
Thanks,Vlad
  • Anonymous May 08, 2010
    I suspected something along this line. Thanks!!!
    I see one sensor near the thermostate. Does it go to PCM or to the guage? Where is the second sensor located?
    THANKS!!!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1379
Points
I don't have the solution but I have the same problem. You are not alone. I have done everything you have done and have run out of options as far as fixing it with OEM parts. I am going to over ride the system with a hot wire and toggle switch and tie into the led wire on the #1 fan so when temp starts to rise past 180 degrees I can turn the fans on. Freeway driving is ok for me, no fan needed, just when I get off the freeway and around town engine gets hot. My toggle switch has a L.E.D. light in it to indicate the switch is on.
  • Christian Martinez
    Christian Martinez Apr 14, 2018
    I an trying to wire it like you stated but i cant seem to figure out how to do it.
Anonymous
Level 3:
  • Master 2,317 Answers
  • Posted on May 08, 2010
Anonymous
Master
Level 3:
Answers
2317
Questions
Helped
787543
Points
7079
There is a coolant temperature sensor for the computer. And then there is a coolant temperature sending unit for the gauge. The coolant temperature sensor could be bad, telling the computer that the engine isn't as hot as it really is.
    I beleive the one you see is the coolant tempurature sensor for the computer.
Ned White
Level 3:
  • Chevrolet Master 2,100 Answers
Ned  White
Chevrolet Master
Level 3:
Answers
2100
Questions
0
Helped
811173
Points
6188
What did it used to do? Usually one fan will come on at start, sometimes it shuts off when the computer tells it to. Then the thermostats in the bottom hose will run the fans, when that water gets hot enough, they come on, if your engine does not get hot, they won't turn on. Did they come on before and stay on or what? I would check the thermostat, I have had a bunch of people complain about their fans lately. Hope this helps.
  • Ned  White
    Ned White May 09, 2010
    You have one in or near the hose at the bottom ,, it is the one to the fan.
2helpful
2answers
1997 Malibu 3L V6 Suddenly hard to start Suddenly hard to start
Could you give more detail as to what it's doing exactly? Is it having a hard time cranking the engine or does the engine crank but not want to get started?
1helpful
Where is the cooling fan switch located on my 2005 malibu 3.5liter v6
Cooling fan switch ? The cooling fans (2) on that motor are controlled by three relays . A coolant temp. sensor gives temp info to the PCM - engine computer .
During high speed operation the PCM supplies the ground path for the cooling fan 1 relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM supplies a ground path for the cooling fan 2 relay and the cooling fan S/P relay through the high speed cooling fan relay control circuit. This energizes the cooling fan 2 relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the cooling fan S/P relay coil is energized closing the relay contacts and provides battery positive voltage from the cool fan 2 fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have their own ground path. The result is a parallel circuit with both fans running at high speed.
The PCM commands Low Speed Fans on under the following conditions:
• Engine coolant temperature exceeds approximately 106°C (223°F).
• When A/C is requested and the ambient temperature is more than 50°C (122°F).
• A/C refrigerant pressure exceeds 1 310 kPa (190 psi).
• After the vehicle is shut off if the engine coolant temperature at key-off is more than 140°C (284°F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The PCM commands High Speed Fans on under the following conditions:
• Engine coolant temperature reaches 110°C (230°F).
• A/C refrigerant pressure exceeds 1 655 kPa (240 psi).
• When certain DTCs set .
Watch this video ,it shows how it works !
Relay Driven Dual Cooling Fan Diagnostics
1helpful
Cooling fans won't come on in my 97 Chevy malibu
The PCM controls that activation of the cooling fans. I uses three relays to do this. The configuration of the relays is such that failure of any one of them should not result in total fan failure (one or both would still operate). Try this - with the engine running, turn on the A/C. If the fans work, then your problem is that the coolant temp sensor is not telling the PCM the coolant temperature properly. If they still don't work, then, although it doesn't seem likely, I would have the COOLING FAN RELAY, COOLING FAN RELAY 1, and MODE CONTROL RELAY checked. Reason being that the only other possibilities are the PCM and the circuit wiring itself.
Radiator fans do not work on my 1997 chevy malibu
There is a sensor on the top of the engine which turns the fans on. it is usually located near the thermostat housing but dont confuse it with the temperature sensor which can easily be tested in the same means by watching the temperature gauge as you ground it out. it may take several seconds to indicate it on your sensors.
If you by-pass and hook the fans up direct without an in-line fuse and there is resistance in the line from a bad fan motor you will melt the wires and the fan motor itself. Use a 30 or 40 amp fuse inline and put on a switch if you like but don't hook direct but only for a few seconds or so to see if is working well. Use very thick wire like booster cable wire.
Take the lead off the sensor and contact it to the ground on the engine. If the fans start up with car running even cold then replace this sensor.
If not check relay by switching with same numbered relays typical in most vehicles. Mark the original relay and note it's position, take pics if you like to aid in placement.
East Coast Canada Rules.
2answers
2002 chevy malibu heats up when running at low speeds
CHECK THE THERMOSTAT. THERMOSTAT IS THE ONE THAT SENSE THE ENGINE TEMPERATURE AND TURNS ON COOLING FAN WHEN THE ENGINE IS HOT.
I have a 2000 chevy malibu with obvious electrical problems. blinkers and flashers rarely work, no dash lights, terrible radio signal, and car runs hot when stopped for too long. We Just replaced the fans...
Cooling Fan Operation
The Electronic Control Module (ECM) regulates the voltage to the cooling fan relay. The relay operates the fan when the engine coolant temperature exceeds 106°C (223°F) The cooling fan will turn on automatically during extended idle conditions under 5 miles per hour. For diagnosis and location of the relay, refer to Electrical Diagnosis.
Electric Testing Techniques You Need to Know
Do you know what a wiring diagrams is ? free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model and engine ! Under system click on engine then under subsystem click on cooling fans . Click the search button then the blue link .
Test the electrical circuits before replacing parts !
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
How to Use Multimeter to Troubleshoot Common Problems
2answers
99 chevy Cooling fans wont come on Chevy Malibu ??? Can i wire them hot to come on ?
Yes, you could wire them to run anytime the ignition is on, but that is not a good idea. Have you checked the fuse? Have you checked to see if the fans actually work? Turn the A/C on and one fan should run continuously. Have you replaced the thermal relay for the cooling fan? You need to just find out why they do not work. Running them continuously is not a good idea. You want the engine to reach full operating temperature as soon as possible. And you do not want to be constantly cooling it down by running the fans all the time. This will cause poor fuel mileage.
3helpful
2answers
The heater blows out cold air only.
check the coolant level in the radiator it may be low
and starving the heater core
1helpful
2001 malibu 3.1 v6 cooling fans run all the time and temp gage
replace thermostat, this fixed my car, cooling fans keep coolant below temp guage parameters.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
