Question about NetGear WGR614 Wireless Router
My wireless router will not pick up my modem connection nor will it let me go wireless, what is the problem?
  • 2,263 Answers
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Posted on May 09, 2010
How do i hook the dang think up to my computer?
Turn your cable-modem (or DSL-modem) off.
Turn the router off.
Turn your computer off.
Cable-modem <---- Ethernet cable ---> WAN (or 'Internet') port on the router.
LAN (or 'network') port #1 on router <---- Ethernet cable ---> network-port on your computer.
Turn the modem on. Wait for its lamps to settle-down to a repetitive pattern.
Turn the router on. Wait for its lamps to settle-down to a repetitive pattern.
Turn the computer on. Wait for Windows to start-up.
You now should have Internet access.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like "Default Gateway ... 192.168.xxx.yyy"
Start Internet Explorer
Type http://192.168.xxx.yyy
Press Enter
Login to the web-interface "inside" the router
Click to run the "Wireless Networking Setup Wizard" to configure the router's "wireless" configuration:
* pick an SSID
* pick an encryption-level, e.g., 'WPA'
* pick a password
Now, your "wireless" devices can connect to the router.
Dec 11, 2010 | D-Link DIR-615 Wireless Router
I need to connect my play station 3 to the internet wirelessly
Your RCA DCM425 modem is just that, a modem. you need to buy and plug a wireless router into it. That will broadcast your internet connection for your playstation to find.
Sep 29, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I bought belkin g wireless modem ruter but they didn't give me CD . How can i install this and how can i use my wireless ruter please. Thank you.
Power-off your cable-modem (or DSL-modem).
Use an Ethernet cable to connect from the modem to the WAN port on your router.
Use another Ethernet cable to connect from one LAN port on your router to the network-port on your computer (desktop/laptop).
Turn the modem on.
Turn the router on.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like:
Default Gateway . . . . . . . . . : 1234.678.0.1
Type http://1234.678.0.1
to access the web-server "inside" the router.
Run the Network Setup Wizard.
Run the Wireless Networking Setup Wizard,
to pick an SSID, an encryption-level (use 'WPA')
and to pick a network-password.
Now, you can disconnect the Ethernet cable from the computer, and try using the wireless-adapter inside your computer.
Sep 20, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
The wireless network is being picked up by the laptops in the house, but there is no internet connection between the modem and the router. MY router is a Belkin G Wireless
if you connect the computer directly to the modem, does it work?
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
Click Here for more information about the routers and network
Mar 06, 2010 | Belkin Wireless-G Plus MIMO Router with...
Laptop cannot pick up wireless from modem
Is your Wireless router integrated in the modem? If it is not, try to unplug the router for a few minutes then restore the power and see if it fixes the problem. If it is integrateddo the same for the modem. Try to connect using the laptop. If it does not work use the laptop to scan for new wireless locations and make sure you see the home location. If you do not your wireless router is not working, If so select the home location and enter any Web Encryption Protection and try to connect. If your wireless router is not working, make sure the preference for the router has the wireless function turned on. To do this use ether the software which you received with the router/modem or internet explorer to access the IP address of the router. If your router is configured for wireless use it may be a bad wireless router.
Feb 05, 2010 | NetGear CG814M (pn-3201155) Modem
Connecting to the wireless router
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 15, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
SPEEDSTREAM 4200 MODEM CONNECTED TO WRT54G ROUTER WIRELESS DONT
turn on the wireless option in the router...
plug your computer into the router type in
192.168.1.1
username: admin
Password: public
go to wireless tab
turn it on
END!
P.S.
Also you have to be in range!
Sep 25, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Belkin wireless problem
If you are connected straight from the modem, your router will not have internet access, only if your modem is connected to the router you will be able to go online wireless. connect your modem to the router nad router to the desktop, so that you can access both wired and wireless connection
Aug 12, 2008 | Belkin (F5D9230-4) Wireless Router...
NOT WORKING AFTER POWER OUTAGE.
are u getting all the lights on the router?if yes then connect the router with modem n if its wireless then turn off all three devices
then turn modem on first n wait till the lights on the modem get settelled,then turn the router back on n the computer,n check whether the computer is picking the wireless or not,if yes try the
internet.
Apr 20, 2008 | D-Link DI 514 Wireless Router (DI-514)
How to connect wireless router to adsl router?
You're wanting to connect the directly connect the DI-514 to the ASDL modem to give you a wireless network, right? If so here's what you do:
Connect an ethernet line from the modem to the Internet/Wan port of your DI-514 and then you're set. I recommend you then follow the directions in the manual to setup wireless security.
If you're wanting to have your DI-514 wirelessly connect to the ASDL modem, then connect your PC to one of the LAN ports of the DI-514 and open the administrative web interface (usually located at http://192.168.0.1) and go to the wireless section and select "Wireless Client" and input the MAC of the ASDL modem's wireless interface (you can find this on the administration web interface of the ASDL modem) and you should be good to go.
Feb 10, 2008 | D-Link DI 514 Wireless Router (DI-514)
NetGear WGR614 Wireless Router Logo
59 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
